Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
CAD Forums
CAD General
Topic:
Hatch problem
« previous
next »
Print
Pages: [
1
2
3
All
Go Down
Author
Topic: Hatch problem (Read 7515 times)
42
Bull Frog
Hatch problem
on:
February 17, 2004, 09:56:57 AM »
Have a look at this drawing of a hatch problem. The one on the left is correct. What has happened to the righthand one?
http://theswamp.org/lilly.pond/42/hatch.dwg
It seems to be broken, the effect is the same for all hatch pattens.
Logged
Alastair Mallett Autodesk Certified Professional
Technical Director
Hunters South Architects
daron
Guest
Hatch problem
Reply #1 on:
February 17, 2004, 10:01:01 AM »
I don't know, but using match fixed it.
Logged
42
Bull Frog
Hatch problem
Reply #2 on:
February 17, 2004, 10:04:10 AM »
Unfortunately using match does not fix it on my machine, although I match the left one into the right one.
Logged
Technical Director
Craig
Guest
Hatch problem
Reply #3 on:
February 17, 2004, 10:07:37 AM »
One thing I noticed about the two is the following
One on the left
(70 . 0) (71 . 0) (91 . 4) (92 . 5) (93 . 4) (72 . 1)
One on the right
(70 . 0) (71 . 1) (91 . 1) (92 . 1) (93 . 4) (72 . 1)
71 - Associativity flag (associative = 1; non-associative = 0)
91 - Number of boundary paths (loops)
92 - Boundary path type flag (bit coded):0 = Default; 1 = External; 2 = Polyline;4 = Derived; 8 = Textbox; 16 = Outermost
72 - Edge type (only if boundary is not a polyline):1 = Line; 2 = Circular arc; 3 = Elliptic arc; 4 = Spline
93 - Number of edges in this boundary path
When I redid the same hatch on my machine they came in identical
Hope this helps some
Logged
42
Bull Frog
Hatch problem
Reply #4 on:
February 17, 2004, 10:29:25 AM »
That’s beautiful Craig, but I do not have a Scooby Doo what it means. Well yes I know that it refers to the hatch construction, but beyond that no clue. The hatch works fine in other drawings.
Logged
Technical Director
daron
Guest
Hatch problem
Reply #5 on:
February 17, 2004, 10:33:05 AM »
audit the drawing?
Logged
42
Bull Frog
Hatch problem
Reply #6 on:
February 17, 2004, 10:33:28 AM »
Yep done that
Logged
Technical Director
daron
Guest
Hatch problem
Reply #7 on:
February 17, 2004, 10:35:52 AM »
wblock it to another name and rename?
Lastly, start over?
Logged
42
Bull Frog
Hatch problem
Reply #8 on:
February 17, 2004, 10:44:45 AM »
Done that but no dice on effect on the hatch.
Not an option 3.5MB drawing.
Logged
Technical Director
Global Moderator
Seagull
Hatch problem
Reply #9 on:
February 17, 2004, 10:47:49 AM »
I noticed that the one on the right is associative.
Your Scale factor does not work for me. Maybe my
arconc hatch is different but when I edit the hatch on the right
change the scale to 20 it redraws as correct.
Logged
daron
Guest
Hatch problem
Reply #10 on:
February 17, 2004, 10:54:19 AM »
Have you tried deleting the bad hatch, redrawing its boundary, then re-hatching it as non-associative. It seems to be associative when listing it, but doen't appear to be associative when selecting it.
Logged
Craig
Guest
Hatch problem
Reply #11 on:
February 17, 2004, 10:57:42 AM »
Well I found something else that might be your problem. Did you create the rectangles differently? Notice the difference between the two LWPOLYLINE's?
The left one
((-1 . <Entity name: 40a0be30>) (0 . "LWPOLYLINE") (330 . <Entity name: 40a86c10>)
The right one
((-1 . <Entity name: 40a0be20>) (0 . "LWPOLYLINE") (5 . "9AC") (102 . "{ACAD_REACTORS") (330 . <Entity name: 40a0be28>)
102 - Start of application-defined group "{application_name". For example, "{ACAD_REACTORS" indicates the start of the AutoCAD persistent reactors group. This group exists only if persistent reactors have been attached to this object.
Logged
42
Bull Frog
Hatch problem
Reply #12 on:
February 17, 2004, 10:58:10 AM »
I rehatched both areas in the original drawing using associative and non-associative hatching, it makes no differance.
Daron, this also makes on differance. I can draw a new hatch boundary and either hatch it by point or object. What is frustrating is that hatching done earlier is fine.
Logged
Technical Director
42
Bull Frog
Hatch problem
Reply #13 on:
February 17, 2004, 11:03:00 AM »
Craig. I can copy a rectangle that containes correct hatch, rehatch the second rectangle and obtain the incorrect hatch.
Logged
Technical Director
daron
Guest
Hatch problem
Reply #14 on:
February 17, 2004, 11:08:51 AM »
It seems that you have something setting reactors in your drawing, as Craig pointed out. I had your drawing open and was in here. I went in to cad and noticed it had frozen up. Has anybody else experienced this?
List your rectangles. Are they containing any reactors? Are they both unassociative?
Logged
Print
Pages: [
1
2
3
All
Go Up
« previous
next »
TheSwamp
CAD Forums
CAD General
Topic:
Hatch problem
