Author Topic: Drawing with strange crosshair rotation  (Read 9953 times)
alanjt
  • Standby for witty remark...
« on: August 12, 2013, 07:19:58 AM »
I have a drawing (blank) that, when I correct the UCS icon and viewcube, the crosshairs are rotated. I've checked the ucs and snapang, but can't think of what else it might be. Any help on this would be greatly appreciated.
The attached drawing is saved in 2011 (civil 3d 2011).
Thanks guys.
Dropbox
Rob...
Re: Drawing with strange crosshair rotation
« Reply #1 on: August 12, 2013, 07:22:17 AM »
Set VIEW to plan.
CAD Tech
« Reply #2 on: August 12, 2013, 07:28:37 AM »
VIEWTWIST =/= 0
Rob...
« Reply #3 on: August 12, 2013, 07:32:04 AM »
VIEWTWIST is read only for me.
CAD Tech
alanjt
« Reply #4 on: August 12, 2013, 07:32:30 AM »
Set VIEW to plan.
That corrects it, but if you check your UCS, it's displayed as "Unknown" and if you reset it back to "World", it changes the ucs/viewcube back to the was.
Dropbox
« Reply #5 on: August 12, 2013, 07:33:51 AM »
Command: DVIEW
Select objects or <use DVIEWBLOCK>: [Enter]
Enter option [CAmera/TArget/Distance/POints/PAn/Zoom/TWist/CLip/Hide/Off/Undo]: TW
Specify view twist angle <3.09>: 0
alanjt
« Reply #6 on: August 12, 2013, 07:36:04 AM »
Viewtwist is zero.
I'm puzzled as to why "Top" would not be considered "world".
Dropbox
Rob...
« Reply #7 on: August 12, 2013, 07:36:15 AM »
I could have sworn that changing the view fixed it the first time I tried it. DVIEW does it.
CAD Tech
alanjt
« Reply #8 on: August 12, 2013, 07:40:38 AM »
Not on my end. DVIEW always displays as zero.
Lee, was that 3.09 what the drawing is displaying on your machine?
Dropbox
Rob...
« Reply #9 on: August 12, 2013, 07:41:54 AM »
I got 3.09, as Lee posted.
CAD Tech
« Reply #10 on: August 12, 2013, 07:42:14 AM »
Yes; drawing downloaded & opened, no other modifications performed other than using the DVIEW command.
alanjt
« Reply #11 on: August 12, 2013, 07:43:58 AM »
What the hell?!?
I checked that and the viewtwist is 0.
Dropbox
« Reply #12 on: August 12, 2013, 07:53:24 AM »
I see what you mean -
I believe it is standard behaviour that setting View to 'Top' will use an unnamed UCS until the user explicitely sets the UCS to WCS; however, in your drawing, when setting the UCS to World, the WCS axes rotate marginally clockwise...  :-(
alanjt
« Reply #13 on: August 12, 2013, 07:57:27 AM »
And we're back to square one.  :|
Dropbox
« Reply #14 on: August 12, 2013, 08:34:19 AM »
Have you done an Audit?
