Author Topic: Drawing with strange crosshair rotation  (Read 9586 times)
alanjt
  • Standby for witty remark...
Re: Drawing with strange crosshair rotation
« Reply #15 on: August 12, 2013, 08:36:57 AM »
Have you done an Audit?
Yes, but what might that do?
Dropbox
Rob...
« Reply #16 on: August 12, 2013, 08:38:30 AM »
I'm missing something here. I thought it was straightened with DView/TWist. Is that not working for you?
CAD Tech
alanjt
« Reply #17 on: August 12, 2013, 08:41:38 AM »
No. When I check DVIEW twist, it displays as zero. I never get the "3.09" twist. Nothing has been resolved on my end.
Would one of you mind saving the drawing (2011 format) and posting the drawing back so I can see?
Dropbox
« Reply #18 on: August 12, 2013, 08:45:42 AM »
If something was broken I thought it may allow you to fix it.
alanjt
« Reply #19 on: August 12, 2013, 08:49:17 AM »
No such luck. :oops:
Dropbox
Rob...
« Reply #20 on: August 12, 2013, 08:50:45 AM »
This is after changin DVIEWTWIST to zero.
CAD Tech
« Reply #21 on: August 12, 2013, 08:58:04 AM »
You can straighten the crosshairs with DVIEW/TWist, however, when setting the UCS to World, the WCS axes will be shifted in the opposite direction by the same amount (3.09 degrees); straightening the WCS axes will set VIEWTWIST back to 3.09.... and around we go again  :-(
« Last Edit: August 12, 2013, 09:01:11 AM by Lee Mac »
alanjt
« Reply #22 on: August 12, 2013, 09:04:44 AM »
I'm still beyond perplexed as to why I can't see the 3.09 value. So odd.
Dropbox
Rob...
« Reply #23 on: August 12, 2013, 09:06:41 AM »
That's not what is happening here, using ACADMEP 2011. The original file has UCS already set to World. DView changes it to be aligned with view. Quite odd that it works here.
CAD Tech
alanjt
« Reply #24 on: August 12, 2013, 09:07:54 AM »
Yes, but is your viewcube, ucs icon correct (see Lee's posted image)? Even when I open the drawing you posted, it looks just as the original I posted does.
Dropbox
Rob...
« Reply #25 on: August 12, 2013, 09:14:22 AM »
I now see. I had viewcube turned off for 2D. Turned it back on and while the UCS is aligned to the view, the viewcube is skewed by probably the 3.09.
CAD Tech
« Reply #26 on: August 12, 2013, 09:49:12 AM »
The GEOGRAPHICLOCATION north direction is not at 0.
alanjt
« Reply #27 on: August 12, 2013, 11:23:13 AM »
Fantastic. I wonder if newer versions of cad (or nonCivil3d) see that change in the viewtwist.
Does this have any adverse effect on the drawing if I just set it back to zero?
Thank you, Jeff!
Dropbox
« Reply #28 on: August 12, 2013, 12:59:14 PM »
I haven't seen anything bad occur due to this issue. I do know that the initial release of C3D2013 would set this strange rotation in every drawing I opened from an earlier version which had a Coordinate System set. I think they have fixed that, but it was definitely irritating. I think that to keep it from reoccurring I had to remove the CS and/or clear the GEO location then reset the CS.
alanjt
« Reply #29 on: August 12, 2013, 01:25:58 PM »
What a pain. Is there an easy way to access this database with a bit of code?
Dropbox
