Author Topic: AutoCAD 2009  (Read 63635 times)
Vortical
Re: AutoCAD 2009
« Reply #75 on: February 13, 2008, 11:21:25 PM »
Is there any ability in 2009 to migrate tool pallettes in directly without having to import each and every tool pallete?
For me this is an extremely painful task with the sheer number of pallettes I have created.
rkmcswain
Re: AutoCAD 2009
« Reply #76 on: February 14, 2008, 08:53:28 AM »
You have always been able to do this, at least from 2006->7 and 2007->8.
Just set the path to your toolpalettes in Options. No "importing" or "migration" needed.
You just can't go backwards or share with older versions.
Guest
Re: AutoCAD 2009
« Reply #77 on: February 14, 2008, 09:17:32 AM »
Baza, I have to seriously try that, MEP is such a pig, if I can make a default ACAD profile that can still handle all the AEC garbage and load quicker, I am all for it.
Good luck with that!!  IF you figure something out, let me know!
Uggghhh....
Customization file loaded successfully. Customization Group: ABS
Customization file loaded successfully. Customization Group: ABS_DESIGN
Customization file loaded successfully. Customization Group: ABS_DOCUMENT
Customization file loaded successfully. Customization Group: ABS_CAD_MANAGER
Customization file loaded successfully. Customization Group: ABS_3DSOLIDS
Customization file loaded successfully. Customization Group: BSELECTRICAL
Customization file loaded successfully. Customization Group: BSHVAC
Customization file loaded successfully. Customization Group: BSPIPING
Customization file loaded successfully. Customization Group: BSPLUMBING
Customization file loaded successfully. Customization Group: BSSCHEMATIC
Customization file loaded successfully. Customization Group: EXPRESS
Customization file loaded successfully. Customization Group: BLUEBEAM
Customization file loaded successfully. Customization Group: DBCONNECT
Loading AEC Base...
Loading AEC Base Extended...
Loading AEC Project Base...
Loading AEC Schedule Data...
Loading AEC Base UI...
Loading AEC Base GUI...
Loading AEC Utilities...
Loading AEC Schedule Data UI...
Loading AEC Schedule...
Loading AEC Schedule UI...
Loading AEC Architectural Base...
Loading AEC Structural Base...
Loading AEC Structural UI...
Loading AEC Publish UI...
Loading AEC Layer Manager...
Loading AEC Project UI...
Loading AEC Project Palette...
Loading AEC Area Base...
Loading AEC Architectural UI...
Loading AEC Annotations UI...
Loading AEC Design Center UI...
Loading AEC Dimensions Base...
Loading AecAreaCalculation50...
Loading AEC Dimensions UI...
Loading AEC Object Explode...
Loading AEC Recipe Base...
Loading AEC Detail UI...
Loading AEC Detail Extended UI...
Loading AEC Detail Base...
Loading MEP Base...
Loading Modeler DLLs.
Loading MEP HVAC Base...
Loading MEP Pipe Base...
Loading MEP Electrical Base...
Loading MEP Part Services...
Loading MEP COLE Base...
Loading MEP Part Factory...
Loading MEP Plumbing Base...
Loading MEP Tools...
Loading MEP Base UI...
Loading MEP Base GUI...
Loading MEP Content Builder...
Loading MEP HVAC...
Loading MEP Piping...
Loading MEP Electrical...
Loading MEP Plumbing...Regenerating model.
KewlToyZ
Re: AutoCAD 2009
« Reply #78 on: February 14, 2008, 12:09:50 PM »
 :realmad: :ugly: :lmao:
Enough to test ones sanity it is...
I'm just trying to get a handle on what you are seeing there Matt.
Did you build a new profile (*.arg) file specific to Acroplot?
Meaning setup a workspace on initial load out, do not load ABS.cui, nor any of those other *.cui's?
Just the ACAD.cui & Acroplot.cui.
Then shortcut point at said profile?
I'm out of the office today to begin testing it and my g/f is harrassing me but I had started this until production demanded all of my attention a few months ago.
I am possibly being naive in beleiving object enablers are present without the cui's?
Could you give me an http link to download a test file that is causing your loadup like that?
I can build the cui's and profile for you to try once I have a test file.
or you could email it under 5MB to kewltoyz@hotmail.com or kewltoyz@yahoo.com
I have my own domains and web servers setup but I have yet to make the time to build my dotnetnuke site for handling this stuff in an easier format. www.kewltoyz.com, .net, .org
oh and one more thing, make sure you have the profile pointing to your plotters, drv, & plot styles folders normally used by your company standards.
Other than that everything can be a very small limited support folder for your bare minimum needs to run acroplot.
« Last Edit: February 14, 2008, 12:22:09 PM by KewlToyZ »
Krushert
  • FREE BEER Tomorrow!!
Re: AutoCAD 2009
« Reply #79 on: February 19, 2008, 11:52:02 AM »
I wish Autocad's next addition to the user interface is a mind reader.
dim command pick point
ah carp wrong layer.
escape, change layers
dim command pick point, pick next point
ah double carp, wrong dim style.
escape change dim style.
dim command pick point, pick next point, pick point.
I don't think it is too much to ask.  I am only sitting 3 feet away from the software.
Maybe I should go over and stir up AUGI with this "wish".  :wink:
deegeecees
Re: AutoCAD 2009
« Reply #80 on: February 19, 2008, 02:07:45 PM »
You could fix the layer thing with some VBA.
Rub a little VBA on it, and VOILA!
Atook
  • AKA Tim
Re: AutoCAD 2009
« Reply #81 on: February 19, 2008, 02:20:17 PM »
I wish Autocad's next addition to the user interface is a mind reader...
I'd probably get fired for all sorts of things if CAD read my mind! :)
ELOQUINTET
Re: AutoCAD 2009
« Reply #82 on: February 19, 2008, 03:49:02 PM »
vortical,
here is an easy way to import multiple palettes at once:
open explorer to the folder that contains all of your palettes.
turn off autohide for your palettes
right click the blue bar and select customize
while the customize dialogue box is open maximize explorer then drag your xtp files into your palette.
this will import all of your palette to the current palette
just regroup if you have groups and you're done
KewlToyZ
Re: AutoCAD 2009
« Reply #83 on: February 20, 2008, 07:06:24 PM »
Add that speak or sayit.lsp file with a few choice words   :lmao:
"Not my fault, its AutoCAD saying those things...."
Re: AutoCAD 2009
« Reply #84 on: February 20, 2008, 07:10:25 PM »
You want to STIR them up at AUGI?  Ask them why they banned me and when they will end it?
That will get them in a stir for sure!
KewlToyZ
Re: AutoCAD 2009
« Reply #85 on: February 20, 2008, 07:13:05 PM »
They really need better libraries in the main tools for error catching in XREF's.
#1 cause for multiple crashes per day are XREF failures.
  • Custom Title
Re: AutoCAD 2009
« Reply #86 on: February 28, 2008, 09:11:46 AM »
Question for you '09 users. Can you 'copy' cell data from a table in AutoCAD and 'paste' it into Excel?
rkmcswain
Re: AutoCAD 2009
« Reply #87 on: February 28, 2008, 10:54:24 AM »
One cell at a time, yes.
I don't see any way to take an existing table and create a data link from it.
However you can still export the AutoCAD table to a CSV, of course you lose the formatting.
KewlToyZ
Re: AutoCAD 2009
« Reply #88 on: February 28, 2008, 12:05:02 PM »
Loading AEC Base...
Customization file loaded successfully. Customization Group: ACAD
Customization file loaded successfully. Customization Group: CUSTOM
Customization file loaded successfully. Customization Group: ACROPLOT
Regenerating model.
AutoCAD Express Tools Copyright © 2002-2004 Autodesk, Inc.
Loading AcroPlot Commands
AcroPlot Command Loaded
AutoCAD menu utilities loaded.
Smart Insert Loaded!!!!CMDECHO
Enter new value for CMDECHO <1>: 0
Dialog Control Variables set!!
MSpace & PSpace LTScale Varaibles set to 0!! Defaults to LTSCALE settings now!
Layer Handling variables set!!
KTA Menus Loaded!!
AcroPlot Commands Loaded
*Cancel*
Enter new value for MSLTSCALE <1>:
Command:
I can trim it down further but I was just using some extra functionality to run it as AutoCAD 2008.
KewlToyZ
Re: AutoCAD 2009
« Reply #89 on: February 28, 2008, 12:30:16 PM »
Here we go:
Loading AEC Base...
Customization file loaded successfully. Customization Group: PDF-MINI
Regenerating model.
AcroPlot Menus loaded.
Command: COMMANDLINE
Unzip this to the root of the C: drive.
Use the PDF-Mini shortcut inside the _KTA MEP folder.
It should load Acroplot menus and toolbars with a small AutoCAD cui.
From there you can run Acroplot fairly quickly.
You will have to update the plot styles and plotters folders with your own stuff as well as your fonts etc...
Have you downloaded the most current version of Acroplot?
