The nice thing here is being able to change these setting from the right-click menu, without having to go into the Drafting setting Dialog box.
Quote from: BazzaCAD on February 12, 2008, 07:07:18 PMThe nice thing here is being able to change these setting from the right-click menu, without having to go into the Drafting setting Dialog box.You can already set those from a right click on the bottom status bar in 2008, this isn't a functional difference, just the visual, instead of it saying OSNAP now you get a glyph, big whoop.
Try the multitab arx file with it. See if it still works.I'm really curious because this is a no brainer if they really wanted to impress with the lipstick...
http://mindstalk.net/vinge/vinge-sing.html
How about tool palettes vs. AEC library palettes, did they separate them using the ribbon and can I manage them with the cui now?
I like the osnap addition finally a shortcut, but how about turning toolbars on and off?The old mnu/mns quick toolbar toggle is sorely missed.
