Author Topic: ( acad 2006 vanilla ) dynamic block & hatch  (Read 23114 times)
« on: December 07, 2007, 11:00:40 AM »
For some reason, in this one particular drawing, when ever I flip the block the solid hatch that's part of it stays behind. I've tried everything I can think of! *baffled*
Re: ( acad 2006 vanilla ) dynamic block & hatch
« Reply #1 on: December 07, 2007, 11:05:04 AM »
Dump the hatch object so we can see its data?
(   (lambda ( / ename )
        (if (setq ename (car (nentsel)))
                (vlax-dump-object (vlax-ename->vla-object ename))
                (mapcar 'print (entget ename '("*")))
daron
« Reply #2 on: December 07, 2007, 11:06:10 AM »
Could you post a drawing of the block itself?
Guest
« Reply #3 on: December 07, 2007, 11:06:51 AM »
The one thing I've noticed with hatch patterns in DBs is that AutoCAD sometimes needs to be reminded that something has changed.  Does it look correct if you do a REGEN after flipping it?  I have to do that sometimes even with '08.
« Reply #4 on: December 07, 2007, 11:09:33 AM »
; IAcadHatch2: AutoCAD Hatch2 Interface
; Property values:
;   Application (RO) = #<VLA-OBJECT IAcadApplication 00c2eb8c>
;   Area (RO) = 0.406802
;   AssociativeHatch = -1
;   Document (RO) = #<VLA-OBJECT IAcadDocument 07056f84>
;   Elevation = 0.0
;   GradientAngle = 0.0
;   GradientCentered = -1
;   GradientColor1 = #<VLA-OBJECT IAcadAcCmColor 0529fd40>
;   GradientColor2 = #<VLA-OBJECT IAcadAcCmColor 052982d0>
;   GradientName = "LINEAR"
;   Handle (RO) = "AE4E"
;   HasExtensionDictionary (RO) = 0
;   HatchObjectType = 0
;   HatchStyle = 0
;   Hyperlinks (RO) = #<VLA-OBJECT IAcadHyperlinks 0529f9c4>
;   ISOPenWidth = 100
;   Layer = "0"
;   Linetype = "ByLayer"
;   LinetypeScale = 1.0
;   Lineweight = -1
;   Normal = (0.0 0.0 1.0)
;   NumberOfLoops (RO) = 1
;   ObjectID (RO) = 2127543920
;   ObjectName (RO) = "AcDbHatch"
;   Origin = (0.0 0.0)
;   OwnerID (RO) = 2127543856
;   PatternAngle = 0.0
;   PatternDouble = 0
;   PatternName (RO) = "SOLID"
;   PatternScale = 1.0
;   PatternSpace = 1.0
;   PatternType (RO) = 1
;   PlotStyleName = "Color_51"
;   TrueColor = #<VLA-OBJECT IAcadAcCmColor 05251710>
;   Visible = -1
(-1 . <Entity name: 7ecfbe70>)
(0 . "HATCH")
(330 . <Entity name: 7ecfbe30>)
(5 . "AE4E")
(100 . "AcDbEntity")
(67 . 0)
(8 . "0")
(62 . 51)
(100 . "AcDbHatch")
(10 0.0 0.0 0.0)
(210 0.0 0.0 1.0)
(2 . "SOLID")
(70 . 1)
(71 . 1)
(91 . 1)
(92 . 7)
(72 . 1)
(73 . 1)
(93 . 9)
(10 0.497657 -0.620711 0.0)
(42 . 0.0)
(10 0.0 0.0 0.0)
(42 . 0.0)
(10 0.397657 -0.720711 0.0)
(42 . 0.0)
(10 0.397657 -0.855079 0.0)
(42 . 0.414214)
(10 0.447657 -0.905079 0.0)
(42 . 0.0)
(10 1.6048 -0.905079 0.0)
(42 . 0.414214)
(10 1.6548 -0.855079 0.0)
(42 . 0.0)
(10 1.6548 -0.670711 0.0)
(42 . 0.414214)
(10 1.6048 -0.620711 0.0)
(42 . 0.0)
(97 . 1)
(330 . <Entity name: 7ecfbe60>)
(75 . 0)
(76 . 1)
(47 . 0.00213631)
(98 . 1)
(10 0.583884 -0.680093 0.0)
(450 . 0)
(451 . 0)
(460 . 0.0)
(461 . 0.0)
(452 . 1)
(462 . 1.0)
(453 . 2)
(463 . 0.0)
(63 . 5)
(421 . 255)
(463 . 1.0)
(63 . 7)
(421 . 16777215)
(470 . "LINEAR")
(-3 ("ACAD" (1010 0.0 0.0 0.0)) ("AcDbBlockRepETag" (1070 . 1) (1071 . 3) (1005 . "AE4E")))
« Reply #5 on: December 07, 2007, 11:10:36 AM »
I could Daron but it works fine in every other drawing.
« Reply #6 on: December 07, 2007, 11:11:51 AM »
Nope! That works in other drawings, just not this one. :-)
« Reply #7 on: December 07, 2007, 11:13:12 AM »
So don't post the other drawings.
« Reply #8 on: December 07, 2007, 11:20:02 AM »
fine .... *sigh* :lol:
« Reply #9 on: December 07, 2007, 11:21:13 AM »
After deleting everything and purging the .dwg the block works fine in said drawing so .....
« Reply #10 on: December 07, 2007, 11:25:04 AM »
Mark,
Your stretch action makes the block look funky in 2008. I don't have any problem with the mirror?
Ron
« Reply #11 on: December 07, 2007, 11:33:12 AM »
If I open the block in the block editor then close and save, the hatch in the block updates and looks correct. But it's only good for one time.
« Reply #12 on: December 07, 2007, 11:33:54 AM »
Mark,
Ron
Thanks Ron.
« Reply #13 on: December 07, 2007, 11:42:37 AM »
Attached is the .dwg that's giving me the problems. I've stripped most everthing out of it and the block still does not work correctly.
« Reply #14 on: December 07, 2007, 11:55:09 AM »
That is strange...it breaks here too. I have still not figured out why my block completely loses its dynamic properties in certain drawings. Me thinks Autodesk needs a little bit more time developing them.
http://www.theswamp.org/index.php?topic=20186.0
