0 Members and 4 Guests are viewing this topic.
( (lambda ( / ename ) (if (setq ename (car (nentsel))) (progn (vlax-dump-object (vlax-ename->vla-object ename)) (mapcar 'print (entget ename '("*"))) ) ) (princ) ))
For some reason, in this one particular drawing, when ever I flip the block the solid hatch that's part of it stays behind. I've tried everything I can think of! *baffled*
Dump the hatch object so we can see its data?
; IAcadHatch2: AutoCAD Hatch2 Interface; Property values:; Application (RO) = #<VLA-OBJECT IAcadApplication 00c2eb8c>; Area (RO) = 0.406802; AssociativeHatch = -1; Document (RO) = #<VLA-OBJECT IAcadDocument 07056f84>; Elevation = 0.0; GradientAngle = 0.0; GradientCentered = -1; GradientColor1 = #<VLA-OBJECT IAcadAcCmColor 0529fd40>; GradientColor2 = #<VLA-OBJECT IAcadAcCmColor 052982d0>; GradientName = "LINEAR"; Handle (RO) = "AE4E"; HasExtensionDictionary (RO) = 0; HatchObjectType = 0; HatchStyle = 0; Hyperlinks (RO) = #<VLA-OBJECT IAcadHyperlinks 0529f9c4>; ISOPenWidth = 100; Layer = "0"; Linetype = "ByLayer"; LinetypeScale = 1.0; Lineweight = -1; Normal = (0.0 0.0 1.0); NumberOfLoops (RO) = 1; ObjectID (RO) = 2127543920; ObjectName (RO) = "AcDbHatch"; Origin = (0.0 0.0); OwnerID (RO) = 2127543856; PatternAngle = 0.0; PatternDouble = 0; PatternName (RO) = "SOLID"; PatternScale = 1.0; PatternSpace = 1.0; PatternType (RO) = 1; PlotStyleName = "Color_51"; TrueColor = #<VLA-OBJECT IAcadAcCmColor 05251710>; Visible = -1(-1 . <Entity name: 7ecfbe70>) (0 . "HATCH") (330 . <Entity name: 7ecfbe30>) (5 . "AE4E") (100 . "AcDbEntity") (67 . 0) (8 . "0") (62 . 51) (100 . "AcDbHatch") (10 0.0 0.0 0.0) (210 0.0 0.0 1.0) (2 . "SOLID") (70 . 1) (71 . 1) (91 . 1) (92 . 7) (72 . 1) (73 . 1) (93 . 9) (10 0.497657 -0.620711 0.0) (42 . 0.0) (10 0.0 0.0 0.0) (42 . 0.0) (10 0.397657 -0.720711 0.0) (42 . 0.0) (10 0.397657 -0.855079 0.0) (42 . 0.414214) (10 0.447657 -0.905079 0.0) (42 . 0.0) (10 1.6048 -0.905079 0.0) (42 . 0.414214) (10 1.6548 -0.855079 0.0) (42 . 0.0) (10 1.6548 -0.670711 0.0) (42 . 0.414214) (10 1.6048 -0.620711 0.0) (42 . 0.0) (97 . 1) (330 . <Entity name: 7ecfbe60>) (75 . 0) (76 . 1) (47 . 0.00213631) (98 . 1) (10 0.583884 -0.680093 0.0) (450 . 0) (451 . 0) (460 . 0.0) (461 . 0.0) (452 . 1) (462 . 1.0) (453 . 2) (463 . 0.0) (63 . 5) (421 . 255) (463 . 1.0) (63 . 7) (421 . 16777215) (470 . "LINEAR") (-3 ("ACAD" (1010 0.0 0.0 0.0)) ("AcDbBlockRepETag" (1070 . 1) (1071 . 3) (1005 . "AE4E")))
Could you post a drawing of the block itself?
Does it look correct if you do a REGEN after flipping it?
I could Daron but it works fine in every other drawing.
Quote from: Mark Thomas on December 07, 2007, 11:10:36 AMI could Daron but it works fine in every other drawing.So don't post the other drawings.
Mark,Your stretch action makes the block look funky in 2008. I don't have any problem with the mirror?Ron
