Author Topic: Dynamic Blocks Losing Dynamic Properties  (Read 6921 times)
« on: November 27, 2007, 12:59:54 PM »
Has anyone else had a problem with this? I have a drawing with about 300 dynamic blocks in it and some of the blocks just lost it!
thanks,
Ron
Here is a test drawing: If a block it rotated, it loses it's dynamic properties.
« Last Edit: November 27, 2007, 01:11:37 PM by ronjonp »
Crank
Re: Dynamic Blocks Losing Dynamic Properties
« Reply #1 on: November 27, 2007, 04:10:51 PM »
Non Autodesk DWG.  This DWG file was saved by a software application that was
not developed or licensed by Autodesk.  Autodesk cannot guarantee the
application compatibility or integrity of this file.
« Reply #2 on: November 27, 2007, 04:40:47 PM »
Yeah I saw that too....the scary part about this is it kills all other drawings that it is xreffed into.
FengK
« Reply #3 on: November 27, 2007, 06:09:14 PM »
i opened the dwg in AutoCAD 2007. the dyn block still works.
« Reply #4 on: November 27, 2007, 06:10:21 PM »
Even after you rotate it? (using the rotate command)
Atook
  • AKA Tim
« Reply #5 on: November 27, 2007, 07:07:54 PM »
2008 Vanilla here, and it died when I rotated it. What did you use to create it?
I deleted your invisible attributes, saved, and it worked... Rework your attributes, and let us know what you find eh?
smudge
« Reply #6 on: May 10, 2011, 03:52:19 AM »
Hi guys
I had the same problem today (DB's worked okay in 2011 but if they were rotated in 2007 they lost their Dynamicness (tm)) and it drove me nuts. I thought that I tried everything to solve it and nothing worked.
When I shut down Acad and rebooted the computer DB's were back to working in 2007 the way that they should (i.e. you could rotate them and they'd still be working).
Hopefully the solution is that simple for everyone else (the blocks were created in 2007)
alanjt
  • Standby for witty remark...
« Reply #7 on: May 10, 2011, 07:21:59 AM »
I used to have the same problem with a bubble dynamic block I created when I would rotate it in v2008. From what I remember, there was a hotfix for 2008, but beyond that, I can't really remember if it fully resolved it.
Dropbox
