Author Topic: Variable Naming Convention  (Read 4640 times)
mmason
« on: May 19, 2009, 10:26:09 PM »
My wandering mind is wondering this evening as I was doing my usual stumbling through some happy vlisp.  It occurred to me that for myself and maybe others a discussion regarding variable names might be a good thing.
I see many different methods people use when naming variables.  Special characters, prefixes and such.  Which begs the question; Is there some sort of semi-standard or (somewhat) universally accepted naming convention for variables in a lisp program?
Some examples might be:
*active-document*, SelectedLayer$, ^IterationList, eb:BlockCollection (where 'eb:' ties the variable to a function such as 'EraseBlock').
Would one format be used for global variables and another for locals?  Another format for collections?
Ideas?  Opinions?
Re: Variable Naming Convention
« Reply #1 on: May 19, 2009, 11:00:54 PM »
*big* topic, *many* considerations.
no convention just personal preferences and current uses/structures.
sleep needed.
*lol*
« Reply #2 on: May 20, 2009, 12:21:08 AM »
Welcome to The Swamp mlm.
I too am off to bed, see you tomorrow.  ZZzzzz.....
Chuck Gabriel
« Reply #3 on: May 20, 2009, 07:33:05 AM »
If you see an asterisk at the beginning and end of a variable name, there is a good chance it is a global variable.  I've also seen the prefix (like the eb: you mentioned) used on globals to identify what function they belong to.  I can see how that would ease some maintenance woes.  Other than that, what I've seen seems pretty arbitrary.
Oh yeah, welcome to the swamp.
« Last Edit: May 20, 2009, 07:36:39 AM by Chuck Gabriel »
« Reply #4 on: May 20, 2009, 07:55:27 AM »
I normally use the format:
<function_name> : <variable_name>
for my globals, (and sometimes chuck a few special chars in there for good measure), but as for local names...
ent  = ename
ss   = selection set
elst  = entget return
obj  = vla-object
cObj = curve object...
I get lazy though...
mmason
« Reply #5 on: May 20, 2009, 08:09:05 AM »
sleep needed.
*lol*
OK, so we've got 7 seein' stars and at the end of the day, Mr. B likes some Z's  :wink:
Matt__W
  • I like my water diluted.
« Reply #6 on: May 20, 2009, 08:12:41 AM »
I've always been kinda partial to the VB naming conventions - although, admittedly, I don't always stick to it.   :|
http://support.microsoft.com/kb/110264
Autodesk Expert Elite
mmason
« Reply #7 on: May 20, 2009, 08:18:16 AM »
I hear that.  In the old days, we did the ol'...
(if (= (+ n1 n2) x) (princ str))
Now I tend to use more like...
(if (= (+ ThisNumberThatIPulledOutOfSomeWhere ThatNumberThatIGotSomeWhereElse) SomeNumberSomeOneToldMeWasWhatIShouldUse) (princ SomeSillyConvolutedMessageToTheUser))
« Reply #8 on: May 20, 2009, 08:25:56 AM »
I have adopted a more descriptive like the later mlm demonstrated.
I tend to shy away from global variables however if needed, i prefix them with a special char.
mmason
« Reply #9 on: May 20, 2009, 09:17:21 AM »
Now, this makes sense!  Those of us in varying degrees of migrations to and intergrations with .NET along with AutoLISP could employ a somewhat similar methodology to variable naming.  That way the LISP'ers and the .NET'ers could (sort of) understand each other.
Wait!  But then Matt and I would have to start being consistent!?  I'm not sure my wandering mind is up to that task.
Matt__W
« Reply #10 on: May 20, 2009, 10:27:01 AM »
What if we were consistently inconsistent?  That way, we'd still be consistent, but on a different level.    :lol:
SEANT
« Reply #11 on: May 20, 2009, 11:07:39 AM »
Wait a minute; I thought the best way to bolster job security, as well as encourage a relaxed work environment, was to give variables friendly names like Fred, Helga, Spanky, etc.  Isn’t it also recommended to set the same variable to several different names, as a variety enhancement to alleviate boredom?
I actually stole this concept from a hilarious list somewhere that encourages sensible coding techniques by expounding the “virtues” of the opposite.  I don’t suppose anyone has recalls that link?
Sean Tessier
AutoCAD 2016 Mechanical
Matt__W
« Reply #12 on: May 20, 2009, 11:32:50 AM »
I think this is it
« Last Edit: May 20, 2009, 11:42:26 AM by CAB »
« Reply #13 on: May 20, 2009, 11:37:56 AM »
I think this is it.
ahah not funny... I was stuck on that for about 5 mins... keeps jumpin round..
« Last Edit: May 20, 2009, 11:41:38 AM by CAB »
Matt__W
« Reply #14 on: May 20, 2009, 11:39:37 AM »
I think this is it.
Like I said... I THINK this is it.  I wasn't sure.   :roll:
