You can set the "limits" to something reasonable and it fixes the zoom-all issue.
Use -PU command. It has all the options to purge things:<-PURGEEnter type of unused objects to purge [Blocks/DEtailviewstyles/Dimstyles/Groups/LAyers/LTypes/MAterials/MUltileaderstyles/Plotstyles/SHapes/textSTyles/Mlinestyles/SEctionviewstyles/Tablestyles/Visualstyles/Regapps/Zero-length geometry/Empty text objects/All]: >
Quote from: dtkell on February 14, 2017, 01:38:20 PMUse -PU command. It has all the options to purge things:<-PURGEEnter type of unused objects to purge [Blocks/DEtailviewstyles/Dimstyles/Groups/LAyers/LTypes/MAterials/MUltileaderstyles/Plotstyles/SHapes/textSTyles/Mlinestyles/SEctionviewstyles/Tablestyles/Visualstyles/Regapps/Zero-length geometry/Empty text objects/All]: >I didn't know that was an option for purge...that's the new thing I learned today!
[...]This is my modified Purge script that I have an Icon for - ^C^C_-PURGE;a;;n; Isn't this doing the same Purge? - If not, I am missing the difference.
^C^C_-PURGE;a;;n;_-PURGE;a;;n;_-PURGE;a;;n;
