Author Topic: Zoom problem  (Read 5725 times)
steve.carson
Re: Zoom problem
« Reply #15 on: February 14, 2017, 05:49:12 PM »
You can set the "limits" to something reasonable and it fixes the zoom-all issue.
Rob...
Re: Zoom problem
« Reply #16 on: February 14, 2017, 06:01:15 PM »
... or just turn them off. It's an antiquated "feature".
CAD Tech
Re: Zoom problem
« Reply #17 on: February 14, 2017, 09:39:02 PM »
craigr
Re: Zoom problem
« Reply #18 on: February 15, 2017, 09:49:12 AM »
Sweet!
Like always, I can count on you folks for answers.
Many flowers to all of you for your help. I have learned quite a bit from this discussion. And that alone is worth much to me.
As always, thanks much.
craigr
Dommy2Hotty
Re: Zoom problem
« Reply #19 on: February 15, 2017, 10:35:54 AM »
Use -PU command. It has all the options to purge things:
<-PURGE
Enter type of unused objects to purge [Blocks/DEtailviewstyles/Dimstyles/Groups/LAyers/LTypes/MAterials/MUltileaderstyles/Plotstyles/SHapes/textSTyles/Mlinestyles/SEctionviewstyles/Tablestyles/Visualstyles/Regapps/Zero-length geometry/Empty text objects/All]: >
I didn't know that was an option for purge...that's the new thing I learned today!
craigr
Re: Zoom problem
« Reply #20 on: February 15, 2017, 10:48:06 AM »
<-PURGE
This is my modified Purge script that I have an Icon for - ^C^C_-PURGE;a;;n;
Isn't this doing the same Purge? - If not, I am missing the difference.
Rob...
Re: Zoom problem
« Reply #21 on: February 15, 2017, 04:14:04 PM »
Regapps
CAD Tech
Crank
Re: Zoom problem
« Reply #22 on: February 17, 2017, 03:07:30 PM »
Yes, it's the same purge. If you also want to purge nested items, then should edit your macro so it does 'PURGE ALL' 3 times:
^C^C_-PURGE;a;;n;_-PURGE;a;;n;_-PURGE;a;;n;
Rob...
Re: Zoom problem
« Reply #23 on: February 17, 2017, 04:12:27 PM »
I'm AFC but IIRC regular purge does not do regapps.
CAD Tech
