Author Topic: Titleblock scale disclaimer  (Read 12777 times)
alanjt
  • Standby for witty remark...
« on: March 25, 2015, 09:41:07 AM »
I'm trying to add a disclaimer note/scale to our titleblock to the degree of "if this scale does not measure exactly 1 inch, please modify graphic scale blah blah or something..."
Does anyone have something like this in their titleblock they would mind sharing for the sake of example?
Dropbox
Re: Titleblock scale disclaimer
« Reply #1 on: March 25, 2015, 09:52:58 AM »
I have seen such notes however; I often wonder WHY they are there, other than issues with reproductions and possible changes in scale (distortion)
One could use something like this.
This drawing is (SCALE) only when the graphic scale shown hereon is EXACTLY 1" from 0 to 100 (scale 1"=100')
If the graphic scale is found to NOT be EXACTLY 1" DO NOT SCALE FROM THE DRAWING.
Or everything you build will be wrong an it will not be our problem.
To request a REPRINT of this plan contact us at youremailorphonenumber@here.com
  • Custom Title
« Reply #2 on: March 25, 2015, 10:00:39 AM »
Perhaps something like this?
« Reply #3 on: March 25, 2015, 10:03:33 AM »
Please Correct and return... :2funny:
« Reply #4 on: March 25, 2015, 10:19:46 AM »
We have this as part of the barscale block: "SCALE MUST MEASURE 1 INCH OR DRAWING IS NOT TO SCALE."
« Reply #6 on: March 25, 2015, 10:28:18 AM »
alanjt
« Reply #7 on: March 25, 2015, 10:29:26 AM »
You just put it as a chunk of text under the graphic scale?
Dropbox
« Reply #8 on: March 25, 2015, 10:32:05 AM »
Yup.
« Reply #9 on: March 25, 2015, 10:32:21 AM »
What side of the pond are you on ?  ::)
I've been on both....so either is acceptable to me...and Websters.  Also part of the 'humor'.
dgorsman
« Reply #10 on: March 25, 2015, 10:34:56 AM »
One of our clients had a note to the effect that the drawing scale only applies to the CAD file and not any hard copies.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
« Reply #11 on: March 25, 2015, 10:38:06 AM »
Yes I saw that ... when casting stones (from whatever side of the pond you're on) at least take the time to make your point look somewhat presentable.
And this is the point where MJ has to have the final say no matter what so I'm ducking out ...
  • Custom Title
« Reply #12 on: March 25, 2015, 10:39:18 AM »
What if that were a comma? Could be a bad scan! *shrug*
« Reply #13 on: March 25, 2015, 10:46:36 AM »
That would be sort of silly, as no one really 'scales' a cad file....do they?
« Reply #14 on: March 25, 2015, 10:52:02 AM »
I wasn't 'casting stones'.....It was a small poke...yet some of you have decided that anything and everything I post must be put under a scanning tunneling electron microscope; to what end I'll never understand...nor do I much concern myself with.
Have a happy springtime day!  I know I will.
« Reply #15 on: March 25, 2015, 10:53:48 AM »
Could be...and it would make the point about NOT scaling drawings even more relevant, wouldn't it?
Sweet irony there.....IF it were a comma.
Rob...
« Reply #16 on: March 25, 2015, 10:55:34 AM »
I don't think the note near the graphic scale is necessary. That is your reference no matter what scale it was printed at.
I've seen several versions of this:
CAD Tech
dtkell
« Reply #17 on: March 25, 2015, 10:59:15 AM »
Something like this?
\"What sane person could live in this world and not be crazy?\" -Ursula K. Le Guin
« Reply #18 on: March 25, 2015, 10:59:30 AM »
That message is often meaningless, as the SHEET size MAY be exactly as noted, yet the image on that sheet might still be wrong and thus NOT TO SCALE.
I have also seen versions that want people to measure the area of the border; leading to possible errors as well, because now you are asking someone to
successfully measure greater than a typical single scale length without inducing errors.
Jeff H
« Reply #19 on: March 25, 2015, 11:05:25 AM »
I thought that is why you added a the scale in text(1/8" = 1') and a barscale for?
So if you lay a scale ruler down and if they match then you can know its wrong and get an idea by what factor.
Rob...
« Reply #20 on: March 25, 2015, 11:08:37 AM »
if they match then you can know its wrong.
That's my mantra for the day.
CAD Tech
Jeff H
« Reply #21 on: March 25, 2015, 11:09:51 AM »
Krush knows what I meant.
« Reply #22 on: March 25, 2015, 11:10:38 AM »
How about:
Warning - If a given dimension does not scale properly the drawing is no to scale.
  • Custom Title
« Reply #23 on: March 25, 2015, 11:11:27 AM »
LMAO ........
Krushert
  • FREE BEER Tomorrow!!
« Reply #24 on: March 25, 2015, 11:42:11 AM »
I picked up what you were putting down Jeff.
Translation:
If things are working like they are suppose to with no problems, then you know you are going about it all wrong.
« Reply #25 on: March 25, 2015, 12:10:42 PM »
alanjt
« Reply #26 on: March 25, 2015, 01:01:22 PM »
That's how I've always felt, but I guess this is a catch-all cya.
Dropbox
dgorsman
« Reply #27 on: March 25, 2015, 05:15:06 PM »
Hard for you to say, I guess, seeing as you've not seen the files.
try {GreatPower;}
   finally
      {MasterBasics;}
jumpy
« Reply #28 on: March 26, 2015, 09:19:03 AM »
We have a convenient disclaimer:
"All dimensions must be checked on site and not scaled from this drawing."
Typically our plans are marked in our titleblock 1:100 @ A1, but seeing as you never know when a contractor has printed our drawing/pdf plot on his A3 plotter on site 'scaled to fit' it avoids being held responsible for the mistakes of others.
Acad 2018 / LT2018
« Reply #29 on: March 26, 2015, 09:36:19 AM »
A. SCALES AS STATED ARE VALID ON THE ORIGINAL DRAWING ONLY. DO NOT SCALE FROM
THESE DRAWINGS. WRITTEN DIMENSIONS TAKE PRECEDENCE OVER GRAPHIC
PRESENTATION. DETAIL DIMENSIONS TAKE PRECEDENCE OVER PLAN DIMENSIONS.
B. NOTIFY ARCHITECT OF ANY DIMENSIONAL DISCREPANCIES. ANY MODIFICATIONS OR
DEVIATION TO BE BROUGHT TO THE ATTENTION OF THE ARCHITECT FOR REVIEW AND
APPROVAL.
C. ALL VERTICAL DIMENSIONS SHALL BE TAKEN FROM A "BENCH MARK" OR OTHER SIMILAR
GUIDE ESTABLISHED PRIOR TO THE START OF CONSTRUCTION. HIGH POINTS, LOW POINTS,
IRREGULARITIES IN FLOOR SLAB WHICH COULD AFFECT FABRICATION / INSTALLATION,
WORK OF OTHER TRADES OR VENDORS SHALL BE BROUGHT TO THE ATTENTION OF
ARCHITECT.
« Reply #30 on: March 26, 2015, 09:49:40 AM »
Believe it or not it was once suggested by someone, that we should scale ALL our cad files to reduce the file sizes on the server..... :idiot2:
cadtag
« Reply #31 on: March 26, 2015, 09:55:48 AM »
APPROVAL.
ARCHITECT.
however -- there are no 'original' drawings anymore.  the real original is the CAD file, bits 'n bytes'.  First generation prints from that electronic file direct to a hard copy are _all_ originals in the old sense of the term, but just copies of the digital original.  Prints from PDF or blackline copies of one of the hardcopy originals are second generation copies.
The only thing more dangerous to the liberty of a free people than big government is big business
Jeff H
« Reply #32 on: March 26, 2015, 10:57:56 AM »
I pretty sure your being sarcastic because if you work around people I do, instead of changing a site plan INUNITS to feet they scale by 12, and it does not mater what it is detail, notes, a sheet completely done with notes, or detail drawn to size , ANYTHING, if they have to add 1 word or line everything gets exploded and viewport changed to 1/8" = 1'-0' and everything scaled.
I have had this conversation like 35 times.
DumbAss 1 to 10: Text height is 10"
Me: You mean at 1/8" = 1'-0' ?
DumbAss 1 to 10: Text height is 10" always
Me: So printed its 0.10416666666666666666666666666667" or ≈ 27/256"?
DumbAss 1 to 10: We set text height to 10"
Me: If you have a 11x17 paper and each letter is 10" high you would not get many letters to fit, and easier to define the height printed ....... ahh fu*k it.
« Reply #33 on: March 26, 2015, 11:01:35 AM »
it appears you work with some autocad-stupid DIMASO individuals
dgorsman
« Reply #34 on: March 26, 2015, 07:03:47 PM »
Not really being sarcastic.  The intent of the note (it was a client border) is that any measuring should be done against the CAD file and no scaling should be done on hard copies.  Not to say that we haven't had clients who want CAD files in model space that print 1:1, so everything is scaled.  More to the point is we at least *try* to comply with what the client wants, even when its CAD-stupid - including disclaimers.
try {GreatPower;}
   finally
      {MasterBasics;}
danallen
« Reply #35 on: March 26, 2015, 08:28:42 PM »
Yall seem to forget that distortion could be in different directions. X might be 1" but the Y could be foobar...
Better have two scales in each direction.
Cathy
« Reply #36 on: March 27, 2015, 03:31:49 PM »
I once slapped a scale ruler out of an engineer's hand, telling him that we put the dimensions on the drawing for a reason.  If he needed to scale something, then he should tell me to add a dimension.
« Reply #37 on: March 27, 2015, 04:04:07 PM »
would this cover it?   :whistling:
alanjt
« Reply #38 on: March 27, 2015, 04:27:20 PM »
I think I'll just create a secondary cover sheet that's nothing but a long disclaimer and 10-15 graphic scales.
Dropbox
dgorsman
« Reply #39 on: March 27, 2015, 06:33:36 PM »
Who needs a long disclaimer?  Just put "NO" in large block letters covering the entire sheet.  If they require clarification, in smaller text underneath "Just... no.".    :laugh:
try {GreatPower;}
   finally
      {MasterBasics;}
