Author Topic: Titleblock scale disclaimer  (Read 11543 times)
Re: Titleblock scale disclaimer
« Reply #15 on: March 25, 2015, 10:53:48 AM »
What if that were a comma? Could be a bad scan! *shrug*
Could be...and it would make the point about NOT scaling drawings even more relevant, wouldn't it?
Sweet irony there.....IF it were a comma.
Rob...
« Reply #16 on: March 25, 2015, 10:55:34 AM »
I don't think the note near the graphic scale is necessary. That is your reference no matter what scale it was printed at.
I've seen several versions of this:
CAD Tech
dtkell
« Reply #17 on: March 25, 2015, 10:59:15 AM »
I'm trying to add a disclaimer note/scale to our titleblock to the degree of "if this scale does not measure exactly 1 inch, please modify graphic scale blah blah or something..."
Does anyone have something like this in their titleblock they would mind sharing for the sake of example?
Something like this?
\"What sane person could live in this world and not be crazy?\" -Ursula K. Le Guin
« Reply #18 on: March 25, 2015, 10:59:30 AM »
That message is often meaningless, as the SHEET size MAY be exactly as noted, yet the image on that sheet might still be wrong and thus NOT TO SCALE.
I have also seen versions that want people to measure the area of the border; leading to possible errors as well, because now you are asking someone to
successfully measure greater than a typical single scale length without inducing errors.
« Reply #19 on: March 25, 2015, 11:05:25 AM »
I thought that is why you added a the scale in text(1/8" = 1') and a barscale for?
So if you lay a scale ruler down and if they match then you can know its wrong and get an idea by what factor.
Rob...
« Reply #20 on: March 25, 2015, 11:08:37 AM »
if they match then you can know its wrong.
That's my mantra for the day.
CAD Tech
« Reply #21 on: March 25, 2015, 11:09:51 AM »
Krush knows what I meant.
« Reply #22 on: March 25, 2015, 11:10:38 AM »
How about:
Warning - If a given dimension does not scale properly the drawing is no to scale.
« Reply #23 on: March 25, 2015, 11:11:27 AM »
LMAO ........
Krushert
  • FREE BEER Tomorrow!!
« Reply #24 on: March 25, 2015, 11:42:11 AM »
I picked up what you were putting down Jeff.
Translation:
If things are working like they are suppose to with no problems, then you know you are going about it all wrong.
« Reply #25 on: March 25, 2015, 12:10:42 PM »
alanjt
  • Standby for witty remark...
« Reply #26 on: March 25, 2015, 01:01:22 PM »
That's how I've always felt, but I guess this is a catch-all cya.
Dropbox
dgorsman
« Reply #27 on: March 25, 2015, 05:15:06 PM »
One of our clients had a note to the effect that the drawing scale only applies to the CAD file and not any hard copies.
That would be sort of silly, as no one really 'scales' a cad file....do they?
Hard for you to say, I guess, seeing as you've not seen the files.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
      {MasterBasics;}
jumpy
« Reply #28 on: March 26, 2015, 09:19:03 AM »
We have a convenient disclaimer:
"All dimensions must be checked on site and not scaled from this drawing."
Typically our plans are marked in our titleblock 1:100 @ A1, but seeing as you never know when a contractor has printed our drawing/pdf plot on his A3 plotter on site 'scaled to fit' it avoids being held responsible for the mistakes of others.
Acad 2018 / LT2018
« Reply #29 on: March 26, 2015, 09:36:19 AM »
A. SCALES AS STATED ARE VALID ON THE ORIGINAL DRAWING ONLY. DO NOT SCALE FROM
THESE DRAWINGS. WRITTEN DIMENSIONS TAKE PRECEDENCE OVER GRAPHIC
PRESENTATION. DETAIL DIMENSIONS TAKE PRECEDENCE OVER PLAN DIMENSIONS.
B. NOTIFY ARCHITECT OF ANY DIMENSIONAL DISCREPANCIES. ANY MODIFICATIONS OR
DEVIATION TO BE BROUGHT TO THE ATTENTION OF THE ARCHITECT FOR REVIEW AND
APPROVAL.
C. ALL VERTICAL DIMENSIONS SHALL BE TAKEN FROM A "BENCH MARK" OR OTHER SIMILAR
GUIDE ESTABLISHED PRIOR TO THE START OF CONSTRUCTION. HIGH POINTS, LOW POINTS,
IRREGULARITIES IN FLOOR SLAB WHICH COULD AFFECT FABRICATION / INSTALLATION,
WORK OF OTHER TRADES OR VENDORS SHALL BE BROUGHT TO THE ATTENTION OF
ARCHITECT.
