Author Topic: Creating Dictionary<AcRtm.RXClass, Type>  (Read 8248 times)
kaefer
Re: Creating Dictionary<AcRtm.RXClass, Type>
« Reply #15 on: August 22, 2012, 12:07:41 PM »
In AutoCAD 2013, RXClass has a new method that returns the managed wrapper type.
Even in 2013 there's one RXClass which doesn't allow calling GetRuntimeType on it: AcRxObject. It seems to bomb in a nested call to native_GetFactoryBase(AcRxClass* ).
@Andrey: If you still insist on doing something seemingly dangerous, what would happen when you skip the known troublemakers, that would be AcDbAnnotationScaleCollection and AcDbAnnotationScaleCollectionIterator?
Andrey Bushman
« Reply #16 on: August 22, 2012, 12:33:06 PM »
I do not know. I wanted to avoid exception processing ("try/catch" code block). I Hoped, that it's problem has a solution. I still not use it code in the my applications. I write Extended AutoCAD .Net API Libraries, which I will to use in my applications, and it code must was be there.
Jeff H
« Reply #17 on: August 22, 2012, 01:01:47 PM »
As kaefer mentioned skipping the troublemakers
Using RXClass.Create()
Two methods that created attached .txt files and only differ by filter and file name
Code - C#: [Select]
  1.        [CommandMethod("RxclassTypesDbo")]
  2.         public void RxclassTypesDbo()
  3.         {
  4.             Document doc = Application.DocumentManager.MdiActiveDocument;
  5.             Database db = doc.Database;
  6.             Editor ed = doc.Editor;
  7.             Dictionary<RXClass, Type> dic = new Dictionary<RXClass, Type>();
  8.                 RXClass rxEntity = RXClass.GetClass(typeof(DBObject));
  9.                 foreach (DictionaryEntry e in SystemObjects.ClassDictionary)
  10.                 {
  11.                     RXClass rxclass = e.Value as RXClass;
  12.                     if (rxclass.IsDerivedFrom(rxEntity))
  13.                     {
  14.                         RXObject rxo = rxclass.Create();
  15.                         if (rxo != null)
  16.                         {
  17.                             dic.Add(rxclass, rxo.GetType());
  18.                         }
  19.
  20.                     }
  21.                 }
  22.                 using (StreamWriter tw = new StreamWriter(@"C:\Testing\rxDbotypes.txt"))
  23.                 {
  24.                     foreach (var de in dic)
  25.                     {
  26.                         tw.WriteLine("{0,-45:D} -------- {1,-45:D}", de.Key.Name, de.Value.Name);
  27.                     }
  28.                 }
  29.
  30.         }
  31.
  32.         [CommandMethod("RxclassTypesEnt")]
  33.         public void RxclassTypesEnt()
  34.         {
  35.             Document doc = Application.DocumentManager.MdiActiveDocument;
  36.             Database db = doc.Database;
  37.             Editor ed = doc.Editor;
  38.             Dictionary<RXClass, Type> dic = new Dictionary<RXClass, Type>();
  39.             RXClass rxEntity = RXClass.GetClass(typeof(Entity));
  40.             foreach (DictionaryEntry e in SystemObjects.ClassDictionary)
  41.             {
  42.                 RXClass rxclass = e.Value as RXClass;
  43.                 if (rxclass.IsDerivedFrom(rxEntity))
  44.                 {
  45.                     RXObject rxo = rxclass.Create();
  46.                     if (rxo != null)
  47.                     {
  48.                         dic.Add(rxclass, rxo.GetType());
  49.                     }
  50.
  51.
  52.                 }
  53.             }
  54.             using (StreamWriter tw = new StreamWriter(@"C:\Testing\rxEnttypes.txt"))
  55.             {
  56.                 foreach (var de in dic)
  57.                 {
  58.                     tw.WriteLine("{0,-45:D} -------- {1,-45:D}", de.Key.Name, de.Value.Name);
  59.                 }
  60.             }
  61.         }
  62.
Results are very Impish
 AbsToolsDbFabrication                         -------- ImpCurve
AbsToolsDbHanger                              -------- ImpCurve
AcAecCamera                                   -------- ImpEntity
AcDb2dPolyline                                -------- Polyline2d
AcDb2dVertex                                  -------- Vertex2d
AcDb2LineAngularDimension                     -------- LineAngularDimension2
AcDb3dPolyline                                -------- Polyline3d
AcDb3dPolylineVertex                          -------- PolylineVertex3d
AcDb3dSolid                                   -------- Solid3d
AcDb3PointAngularDimension                    -------- Point3AngularDimension
rxDbotypes.txt created from DBObject filter
rxEnttypes.txt created from Entity filter
Andrey Bushman
« Reply #18 on: August 23, 2012, 09:31:08 AM »
I rewrote my code and supplied this with detailed comments. In the same place, in comments, I specified the questions. Respond me on them, please.
Code - C#: [Select]
  1. using System;
  2. using System.Collections.Generic;
  3. using System.Linq;
  4. using System.Text;
  5. using System.Collections;
  6. using acad = Autodesk.AutoCAD.ApplicationServices.Application;
  7. using AcApp = Autodesk.AutoCAD.ApplicationServices;
  8. using AcDb = Autodesk.AutoCAD.DatabaseServices;
  9. using AcEd = Autodesk.AutoCAD.EditorInput;
  10. using AcRtm = Autodesk.AutoCAD.Runtime;
  11.
  12. [assembly: AcRtm.CommandClass(typeof(Testing.Class1))]
  13.
  14. namespace Testing {
  15.
  16.         public class Class1 {
  17.
  18.                 //In this method code I try to create dictionary, which for every RXClass contains according it wrapper type.
  19.                 //
  20.                 //The error occurs after a while after cmd was finished:
  21.                 //FATAL ERROR:  Unhandled Access Violation Reading 0x0008 Exception at 63972160h
  22.                 //
  23.                 //QUESTION: Why I get it error?
  24.                 [AcRtm.CommandMethod("cmd")]
  25.                 public void Cmd() {
  26.                         AcApp.Document doc = acad.DocumentManager.MdiActiveDocument;
  27.                         AcDb.Database db = doc.Database;
  28.                         AcEd.Editor ed = doc.Editor;
  29.
  30.                         //target dictionary
  31.                         Dictionary<AcRtm.RXClass, Type> mngTypeDict = new Dictionary<AcRtm.RXClass, Type>();
  32.
  33.                         //errors log
  34.                         StringBuilder sb = new StringBuilder();
  35.
  36.                         //It is necessary to exclude some types from processing, differently we will receive the errors:
  37.                         //Error message:
  38.                         //INTERNAL ERROR:  !dbAnnotationScaleCollectioni.cpp@546: eNullEntityPointer
  39.                         //or
  40.                         //INTERNAL ERROR:  !dbAnnotationScaleCollectioni.cpp@37: eNullObjectPointer
  41.                         //
  42.                         //QUESTION: Why I get it errors?
  43.                         String[] types = new String[] { "AcDbAnnotationScaleCollection", "AcDbAnnotationScaleCollectionIterator" };
  44.
  45.                         foreach (DictionaryEntry item in AcRtm.SystemObjects.ClassDictionary) {
  46.                                 AcRtm.RXClass rxClass = null;
  47.                                 Type type = null;
  48.                                 try {
  49.                                         if (item.Value != null) {
  50.                                                 rxClass = (AcRtm.RXClass)item.Value;
  51.                                                 if (!types.Contains(rxClass.Name)) {
  52.                                                         //I use such code:
  53.                                                         AcRtm.RXObject rxObj = rxClass.Create();
  54.                                                         type = rxObj.GetType();
  55.
  56.                                                         //But I can't use such code, because AutoCAD right there will finish the operation without the error message:
  57.                                                         //using (AcRtm.RXObject rxObj = rxClass.Create()) {
  58.                                                         //    type = rxObj.GetType();
  59.                                                         //}
  60.                                                         //
  61.                                                         //QUESTION: Why I get it error?
  62.                                                 }
  63.                                         }
  64.                                         else {
  65.                                                 sb.AppendLine(String.Format("{0} key value is null.", item.Key));
  66.                                         }
  67.                                 }
  68.                                 catch (Exception ex) {
  69.                                         if (rxClass != null)
  70.                                                 sb.AppendLine(String.Format("Can't to create instance of {0}. Error: {1}", rxClass.Name, ex.Message));
  71.                                 }
  72.                         }
  73.                 }
  74.
  75.                 //I try to find instances of "AcDbAnnotationScaleCollection" or "AcDbAnnotationScaleCollectionIterator"
  76.                 //
  77.                 //QUESTION: Why I can't find it?
  78.                 [AcRtm.CommandMethod("cmd2")]
  79.                 public void Cmd2() {
  80.                         AcApp.Document doc = acad.DocumentManager.MdiActiveDocument;
  81.                         AcDb.Database db = doc.Database;
  82.                         AcEd.Editor ed = doc.Editor;
  83.                         //I use such array, like in Cmd method:
  84.                         String[] types = new String[] { "AcDbAnnotationScaleCollection", "AcDbAnnotationScaleCollectionIterator" };
  85.
  86.                         using (AcDb.Transaction tr = db.TransactionManager.StartTransaction()) {
  87.                                 //I execute iteration on all database objects:
  88.                                 for (long i = db.BlockTableId.Handle.Value; i < db.Handseed.Value; i++) {
  89.                                         AcDb.ObjectId id = AcDb.ObjectId.Null;
  90.                                         AcDb.DBObject dbObj = null;
  91.                                         Type type = null;
  92.                                         AcDb.Handle h = new AcDb.Handle(i);
  93.                                         bool result = db.TryGetObjectId(h, out id);
  94.
  95.                                         //But I can't find instances of "AcDbAnnotationScaleCollection" or "AcDbAnnotationScaleCollectionIterator":
  96.                                         //the condition is never executed.
  97.                                         if (result && id.IsValid && !id.IsNull && types.Contains(id.ObjectClass.Name)) {
  98.                                                 dbObj = tr.GetObject(id, AcDb.OpenMode.ForRead);
  99.                                                 type = dbObj.GetType();
  100.                                         }
  101.                                 }
  102.                                 tr.Abort();
  103.                         }
  104.                 }
  105.         }
  106. }
  107.
« Last Edit: August 23, 2012, 09:53:14 AM by Andrey »
Andrey Bushman
« Reply #19 on: August 23, 2012, 09:47:43 AM »
Yes, this is an interesting decision, thanks. But if there is a filter, then it means, what are eliminated some types and consequently we receive not complete result.
« Last Edit: August 23, 2012, 09:51:47 AM by Andrey »
