Author Topic: Creating Dictionary<AcRtm.RXClass, Type>  (Read 7821 times)
Andrey Bushman
« on: August 17, 2012, 02:38:57 AM »
Hi all.
Data:
AutoCAD 2009 SP3 Enu x86,
Windows XP SP3 x86
.Net Framework 3.5 SP1
I want to create Dictionary<AcRtm.RXClass, Type> for more quickly to define managed types for RXClasses. I wrote it code:
Dictionary<AcRtm.RXClass, Type> mngTypeDict = new Dictionary<AcRtm.RXClass, Type>();
//Names of RXClasses, which do not have manage wrapper.
StringBuilder sb = new StringBuilder();
foreach (DictionaryEntry item in AcRtm.SystemObjects.ClassDictionary) {
AcRtm.RXClass rx;
Type type;
AcRtm.RXObject obj;
try {
rx = (AcRtm.RXClass)item.Value;
obj = rx.Create();
if (obj != null) {
type = obj.GetType();
mngTypeDict.Add(rx, type);
else
sb.AppendLine(rx.Name);
catch (Exception ex) {
//oops..
But I get Fatall Error (try/catch doesn't help even):
INTERNAL ERROR:  !dbAnnotationScaleCollectioni.cpp@37: eNullObjectPointer
Regards
MexicanCustard
Re: Creating Dictionary<AcRtm.RXClass, Type>
« Reply #1 on: August 17, 2012, 07:29:21 AM »
What line of the code is execution crashing?
Andrey Bushman
« Reply #2 on: August 17, 2012, 07:43:28 AM »
obj = rx.Create();
MexicanCustard
« Reply #3 on: August 17, 2012, 10:37:22 AM »
I apologize if AcRtm is an AutoCAD class but I cannot find anything documenting it. Is this a custom class?
Edit:
Nevermind I see from another thread that you're using it as an alias for Autodesk.AutoCAD.Runtime.
I'd try
var rx = item.value as AcRtm.RXClass
if (rx != null)
  obj = rx.Create();
« Last Edit: August 17, 2012, 10:45:47 AM by MexicanCustard »
Andrey Bushman
« Reply #4 on: August 17, 2012, 10:46:15 AM »
No, it is namespace: using AcRtm = Autodesk.AutoCAD.Runtime;
MexicanCustard
« Reply #5 on: August 20, 2012, 07:56:45 AM »
Autodesk.AutoCAD.Runtime is the namespace
AcRtm is an alias you're using to represent that namespace.
fixo
« Reply #6 on: August 20, 2012, 08:37:31 AM »
Perhaps
obj = rx.Create(IntPtr.Zero);Or I'm missing something above, so, sorry
~'J'~
MexicanCustard
« Reply #7 on: August 20, 2012, 12:30:34 PM »
I didn't see it in the documentation but with Object Browser
Autodesk.AutoCAD.Runtime.DisposableWrapper.Create(System.Type, System.IntPtr, bool)
Autodesk.AutoCAD.Runtime.RXObject.Create(System.IntPtr, bool)
« Last Edit: August 20, 2012, 12:34:19 PM by MexicanCustard »
Jeff H
« Reply #8 on: August 20, 2012, 08:29:00 PM »
I am just guessing but you might need to filiter for objects because you will probably get a bunch of Imp****** objects.
Not sure what you are doing but you looks like you would still need iterate through dictionary and use a property of RxClasss to be able compare.
Some untested code?
Code - C#: [Select]
  1.
  2.          [CommandMethod("RxclassTypes")]
  3.         public void RxclassTypes()
  4.         {
  5.             Document doc = Application.DocumentManager.MdiActiveDocument;
  6.             Database db = doc.Database;
  7.             Editor ed = doc.Editor;
  8.             Dictionary<RXClass, Type> dic = new Dictionary<RXClass, Type>();
  9.                 RXClass rxEntity = RXClass.GetClass(typeof(Entity));
  10.                 foreach (DictionaryEntry e in SystemObjects.ClassDictionary)
  11.                 {
  12.                     RXClass rxclass = e.Value as RXClass;
  13.                     if (rxclass.IsDerivedFrom(rxEntity))
  14.                     {
  15.                         Type type = rxclass.GetRuntimeType();
  16.                         dic.Add(rxclass, type);
  17.                     }
  18.                 }
  19.
  20.         }
  21.
Andrey Bushman
« Reply #9 on: August 22, 2012, 03:48:12 AM »
Yes, I wrote it in my last message.
Andrey Bushman
« Reply #10 on: August 22, 2012, 04:27:38 AM »
Code - C#: [Select]
  1. Autodesk.AutoCAD.Runtime.DisposableWrapper.Create(System.Type, System.IntPtr, bool)
  2. Autodesk.AutoCAD.Runtime.RXObject.Create(System.IntPtr, bool)
It is very interesting. But AutoCAD 2009 .Net API has
Code - C#: [Select]
only. :(
I tried to get wrapper:
Code - C#: [Select]
  1. Dictionary<RXClass, Type> mngTypeDict = new Dictionary<RXClass, Type>();
  2.
  3. foreach (DictionaryEntry item in SystemObjects.ClassDictionary) {
  4.         RXClass rx;
  5.         Type type;
  6.         try {
  7.                 rx = (RXClass)item.Value;
  8.                 IntPtr ptr = rx.UnmanagedObject;
  9.                 DisposableWrapper wrap = Autodesk.AutoCAD.Runtime.DisposableWrapper.Create(typeof(Object), ptr, false);
  10.                 type = wrap.GetType();
  11.         }
  12.         catch (Exception ex) {
  13.                 //oops..
  14.         }
  15. }
  16.
but I got error:
Constructor on type 'System.Object' not found.
Andrey Bushman
« Reply #11 on: August 22, 2012, 04:35:03 AM »
Some untested code?
Code - C#: [Select]
  1.
  2. ...
  3. Type type = rxclass.GetRuntimeType();
  4. ...
  5.
Sorry, but AutoCAD 2009 .Net API has not GetRuntimeType method for RXClass class. :(
Andrey Bushman
« Reply #12 on: August 22, 2012, 04:56:00 AM »
Am I inventing a bicycle, maybe? I need to get wrapper type for each RXClass in Database. Is exists a simple and fast (for speed) solution to do it?
« Last Edit: August 22, 2012, 05:03:50 AM by Andrey »
TheMaster
« Reply #13 on: August 22, 2012, 07:30:37 AM »
Before AutoCAD 2013, the only way was to create an instance of the wrapper class, and even that wasn't foolproof if the native ARX that provides it is not available (then an ImpDBObject wrapper is created).
In AutoCAD 2013, RXClass has a new method that returns the managed wrapper type.
Andrey Bushman
« Reply #14 on: August 22, 2012, 12:03:24 PM »
Thank you for answer.
kaefer
« Reply #15 on: August 22, 2012, 12:07:41 PM »
Even in 2013 there's one RXClass which doesn't allow calling GetRuntimeType on it: AcRxObject. It seems to bomb in a nested call to native_GetFactoryBase(AcRxClass* ).
@Andrey: If you still insist on doing something seemingly dangerous, what would happen when you skip the known troublemakers, that would be AcDbAnnotationScaleCollection and AcDbAnnotationScaleCollectionIterator?
Andrey Bushman
« Reply #16 on: August 22, 2012, 12:33:06 PM »
I do not know. I wanted to avoid exception processing ("try/catch" code block). I Hoped, that it's problem has a solution. I still not use it code in the my applications. I write Extended AutoCAD .Net API Libraries, which I will to use in my applications, and it code must was be there.
Jeff H
« Reply #17 on: August 22, 2012, 01:01:47 PM »
As kaefer mentioned skipping the troublemakers
Using RXClass.Create()
Two methods that created attached .txt files and only differ by filter and file name
Code - C#: [Select]
  1.        [CommandMethod("RxclassTypesDbo")]
  2.         public void RxclassTypesDbo()
  3.         {
  4.             Document doc = Application.DocumentManager.MdiActiveDocument;
  5.             Database db = doc.Database;
  6.             Editor ed = doc.Editor;
  7.             Dictionary<RXClass, Type> dic = new Dictionary<RXClass, Type>();
  8.                 RXClass rxEntity = RXClass.GetClass(typeof(DBObject));
  9.                 foreach (DictionaryEntry e in SystemObjects.ClassDictionary)
  10.                 {
  11.                     RXClass rxclass = e.Value as RXClass;
  12.                     if (rxclass.IsDerivedFrom(rxEntity))
  13.                     {
  14.                         RXObject rxo = rxclass.Create();
  15.                         if (rxo != null)
  16.                         {
  17.                             dic.Add(rxclass, rxo.GetType());
  18.                         }
  19.
  20.                     }
  21.                 }
  22.                 using (StreamWriter tw = new StreamWriter(@"C:\Testing\rxDbotypes.txt"))
  23.                 {
  24.                     foreach (var de in dic)
  25.                     {
  26.                         tw.WriteLine("{0,-45:D} -------- {1,-45:D}", de.Key.Name, de.Value.Name);
  27.                     }
  28.                 }
  29.
  30.         }
  31.
  32.         [CommandMethod("RxclassTypesEnt")]
  33.         public void RxclassTypesEnt()
  34.         {
  35.             Document doc = Application.DocumentManager.MdiActiveDocument;
  36.             Database db = doc.Database;
  37.             Editor ed = doc.Editor;
  38.             Dictionary<RXClass, Type> dic = new Dictionary<RXClass, Type>();
  39.             RXClass rxEntity = RXClass.GetClass(typeof(Entity));
  40.             foreach (DictionaryEntry e in SystemObjects.ClassDictionary)
  41.             {
  42.                 RXClass rxclass = e.Value as RXClass;
  43.                 if (rxclass.IsDerivedFrom(rxEntity))
  44.                 {
  45.                     RXObject rxo = rxclass.Create();
  46.                     if (rxo != null)
  47.                     {
  48.                         dic.Add(rxclass, rxo.GetType());
  49.                     }
  50.
  51.
  52.                 }
  53.             }
  54.             using (StreamWriter tw = new StreamWriter(@"C:\Testing\rxEnttypes.txt"))
  55.             {
  56.                 foreach (var de in dic)
  57.                 {
  58.                     tw.WriteLine("{0,-45:D} -------- {1,-45:D}", de.Key.Name, de.Value.Name);
  59.                 }
  60.             }
  61.         }
  62.
Results are very Impish
 AbsToolsDbFabrication                         -------- ImpCurve
AbsToolsDbHanger                              -------- ImpCurve
AcAecCamera                                   -------- ImpEntity
AcDb2dPolyline                                -------- Polyline2d
AcDb2dVertex                                  -------- Vertex2d
AcDb2LineAngularDimension                     -------- LineAngularDimension2
AcDb3dPolyline                                -------- Polyline3d
AcDb3dPolylineVertex                          -------- PolylineVertex3d
AcDb3dSolid                                   -------- Solid3d
AcDb3PointAngularDimension                    -------- Point3AngularDimension
rxDbotypes.txt created from DBObject filter
rxEnttypes.txt created from Entity filter
Andrey Bushman
« Reply #18 on: August 23, 2012, 09:31:08 AM »
I rewrote my code and supplied this with detailed comments. In the same place, in comments, I specified the questions. Respond me on them, please.
Code - C#: [Select]
  1. using System;
  2. using System.Collections.Generic;
  3. using System.Linq;
  4. using System.Text;
  5. using System.Collections;
  6. using acad = Autodesk.AutoCAD.ApplicationServices.Application;
  7. using AcApp = Autodesk.AutoCAD.ApplicationServices;
  8. using AcDb = Autodesk.AutoCAD.DatabaseServices;
  9. using AcEd = Autodesk.AutoCAD.EditorInput;
  10. using AcRtm = Autodesk.AutoCAD.Runtime;
  11.
  12. [assembly: AcRtm.CommandClass(typeof(Testing.Class1))]
  13.
  14. namespace Testing {
  15.
  16.         public class Class1 {
  17.
  18.                 //In this method code I try to create dictionary, which for every RXClass contains according it wrapper type.
  19.                 //
  20.                 //The error occurs after a while after cmd was finished:
  21.                 //FATAL ERROR:  Unhandled Access Violation Reading 0x0008 Exception at 63972160h
  22.                 //
  23.                 //QUESTION: Why I get it error?
  24.                 [AcRtm.CommandMethod("cmd")]
  25.                 public void Cmd() {
  26.                         AcApp.Document doc = acad.DocumentManager.MdiActiveDocument;
  27.                         AcDb.Database db = doc.Database;
  28.                         AcEd.Editor ed = doc.Editor;
  29.
  30.                         //target dictionary
  31.                         Dictionary<AcRtm.RXClass, Type> mngTypeDict = new Dictionary<AcRtm.RXClass, Type>();
  32.
  33.                         //errors log
  34.                         StringBuilder sb = new StringBuilder();
  35.
  36.                         //It is necessary to exclude some types from processing, differently we will receive the errors:
  37.                         //Error message:
  38.                         //INTERNAL ERROR:  !dbAnnotationScaleCollectioni.cpp@546: eNullEntityPointer
  39.                         //or
  40.                         //INTERNAL ERROR:  !dbAnnotationScaleCollectioni.cpp@37: eNullObjectPointer
  41.                         //
  42.                         //QUESTION: Why I get it errors?
  43.                         String[] types = new String[] { "AcDbAnnotationScaleCollection", "AcDbAnnotationScaleCollectionIterator" };
  44.
  45.                         foreach (DictionaryEntry item in AcRtm.SystemObjects.ClassDictionary) {
  46.                                 AcRtm.RXClass rxClass = null;
  47.                                 Type type = null;
  48.                                 try {
  49.                                         if (item.Value != null) {
  50.                                                 rxClass = (AcRtm.RXClass)item.Value;
  51.                                                 if (!types.Contains(rxClass.Name)) {
  52.                                                         //I use such code:
  53.                                                         AcRtm.RXObject rxObj = rxClass.Create();
  54.                                                         type = rxObj.GetType();
  55.
  56.                                                         //But I can't use such code, because AutoCAD right there will finish the operation without the error message:
  57.                                                         //using (AcRtm.RXObject rxObj = rxClass.Create()) {
  58.                                                         //    type = rxObj.GetType();
  59.                                                         //}
  60.                                                         //
  61.                                                         //QUESTION: Why I get it error?
  62.                                                 }
  63.                                         }
  64.                                         else {
  65.                                                 sb.AppendLine(String.Format("{0} key value is null.", item.Key));
  66.                                         }
  67.                                 }
  68.                                 catch (Exception ex) {
  69.                                         if (rxClass != null)
  70.                                                 sb.AppendLine(String.Format("Can't to create instance of {0}. Error: {1}", rxClass.Name, ex.Message));
  71.                                 }
  72.                         }
  73.                 }
  74.
  75.                 //I try to find instances of "AcDbAnnotationScaleCollection" or "AcDbAnnotationScaleCollectionIterator"
  76.                 //
  77.                 //QUESTION: Why I can't find it?
  78.                 [AcRtm.CommandMethod("cmd2")]
  79.                 public void Cmd2() {
  80.                         AcApp.Document doc = acad.DocumentManager.MdiActiveDocument;
  81.                         AcDb.Database db = doc.Database;
  82.                         AcEd.Editor ed = doc.Editor;
  83.                         //I use such array, like in Cmd method:
  84.                         String[] types = new String[] { "AcDbAnnotationScaleCollection", "AcDbAnnotationScaleCollectionIterator" };
  85.
  86.                         using (AcDb.Transaction tr = db.TransactionManager.StartTransaction()) {
  87.                                 //I execute iteration on all database objects:
  88.                                 for (long i = db.BlockTableId.Handle.Value; i < db.Handseed.Value; i++) {
  89.                                         AcDb.ObjectId id = AcDb.ObjectId.Null;
  90.                                         AcDb.DBObject dbObj = null;
  91.                                         Type type = null;
  92.                                         AcDb.Handle h = new AcDb.Handle(i);
  93.                                         bool result = db.TryGetObjectId(h, out id);
  94.
  95.                                         //But I can't find instances of "AcDbAnnotationScaleCollection" or "AcDbAnnotationScaleCollectionIterator":
  96.                                         //the condition is never executed.
  97.                                         if (result && id.IsValid && !id.IsNull && types.Contains(id.ObjectClass.Name)) {
  98.                                                 dbObj = tr.GetObject(id, AcDb.OpenMode.ForRead);
  99.                                                 type = dbObj.GetType();
  100.                                         }
  101.                                 }
  102.                                 tr.Abort();
  103.                         }
  104.                 }
  105.         }
  106. }
  107.
« Last Edit: August 23, 2012, 09:53:14 AM by Andrey »
Andrey Bushman
« Reply #19 on: August 23, 2012, 09:47:43 AM »
Yes, this is an interesting decision, thanks. But if there is a filter, then it means, what are eliminated some types and consequently we receive not complete result.
« Last Edit: August 23, 2012, 09:51:47 AM by Andrey »
