Author Topic: Creating Dictionary<AcRtm.RXClass, Type>  (Read 7813 times)
Andrey Bushman
« on: August 17, 2012, 02:38:57 AM »
Hi all.
Data:
AutoCAD 2009 SP3 Enu x86,
Windows XP SP3 x86
.Net Framework 3.5 SP1
I want to create Dictionary<AcRtm.RXClass, Type> for more quickly to define managed types for RXClasses. I wrote it code:
Dictionary<AcRtm.RXClass, Type> mngTypeDict = new Dictionary<AcRtm.RXClass, Type>();
//Names of RXClasses, which do not have manage wrapper.
StringBuilder sb = new StringBuilder();
foreach (DictionaryEntry item in AcRtm.SystemObjects.ClassDictionary) {
AcRtm.RXClass rx;
Type type;
AcRtm.RXObject obj;
try {
rx = (AcRtm.RXClass)item.Value;
obj = rx.Create();
if (obj != null) {
type = obj.GetType();
mngTypeDict.Add(rx, type);
else
sb.AppendLine(rx.Name);
catch (Exception ex) {
//oops..
But I get Fatall Error (try/catch doesn't help even):
INTERNAL ERROR:  !dbAnnotationScaleCollectioni.cpp@37: eNullObjectPointer
Regards
MexicanCustard
Re: Creating Dictionary<AcRtm.RXClass, Type>
« Reply #1 on: August 17, 2012, 07:29:21 AM »
What line of the code is execution crashing?
Andrey Bushman
« Reply #2 on: August 17, 2012, 07:43:28 AM »
obj = rx.Create();
MexicanCustard
« Reply #3 on: August 17, 2012, 10:37:22 AM »
I apologize if AcRtm is an AutoCAD class but I cannot find anything documenting it. Is this a custom class?
Edit:
Nevermind I see from another thread that you're using it as an alias for Autodesk.AutoCAD.Runtime.
I'd try
var rx = item.value as AcRtm.RXClass
if (rx != null)
  obj = rx.Create();
« Last Edit: August 17, 2012, 10:45:47 AM by MexicanCustard »
Andrey Bushman
« Reply #4 on: August 17, 2012, 10:46:15 AM »
No, it is namespace: using AcRtm = Autodesk.AutoCAD.Runtime;
MexicanCustard
« Reply #5 on: August 20, 2012, 07:56:45 AM »
Autodesk.AutoCAD.Runtime is the namespace
AcRtm is an alias you're using to represent that namespace.
fixo
« Reply #6 on: August 20, 2012, 08:37:31 AM »
Perhaps
obj = rx.Create(IntPtr.Zero);Or I'm missing something above, so, sorry
~'J'~
MexicanCustard
« Reply #7 on: August 20, 2012, 12:30:34 PM »
I didn't see it in the documentation but with Object Browser
Autodesk.AutoCAD.Runtime.DisposableWrapper.Create(System.Type, System.IntPtr, bool)
Autodesk.AutoCAD.Runtime.RXObject.Create(System.IntPtr, bool)
« Last Edit: August 20, 2012, 12:34:19 PM by MexicanCustard »
Jeff H
« Reply #8 on: August 20, 2012, 08:29:00 PM »
I am just guessing but you might need to filiter for objects because you will probably get a bunch of Imp****** objects.
Not sure what you are doing but you looks like you would still need iterate through dictionary and use a property of RxClasss to be able compare.
Some untested code?
Code - C#: [Select]
  1.
  2.          [CommandMethod("RxclassTypes")]
  3.         public void RxclassTypes()
  4.         {
  5.             Document doc = Application.DocumentManager.MdiActiveDocument;
  6.             Database db = doc.Database;
  7.             Editor ed = doc.Editor;
  8.             Dictionary<RXClass, Type> dic = new Dictionary<RXClass, Type>();
  9.                 RXClass rxEntity = RXClass.GetClass(typeof(Entity));
  10.                 foreach (DictionaryEntry e in SystemObjects.ClassDictionary)
  11.                 {
  12.                     RXClass rxclass = e.Value as RXClass;
  13.                     if (rxclass.IsDerivedFrom(rxEntity))
  14.                     {
  15.                         Type type = rxclass.GetRuntimeType();
  16.                         dic.Add(rxclass, type);
  17.                     }
  18.                 }
  19.
  20.         }
  21.
Andrey Bushman
« Reply #9 on: August 22, 2012, 03:48:12 AM »
Yes, I wrote it in my last message.
Andrey Bushman
« Reply #10 on: August 22, 2012, 04:27:38 AM »
Code - C#: [Select]
  1. Autodesk.AutoCAD.Runtime.DisposableWrapper.Create(System.Type, System.IntPtr, bool)
  2. Autodesk.AutoCAD.Runtime.RXObject.Create(System.IntPtr, bool)
It is very interesting. But AutoCAD 2009 .Net API has
Code - C#: [Select]
only. :(
I tried to get wrapper:
Code - C#: [Select]
  1. Dictionary<RXClass, Type> mngTypeDict = new Dictionary<RXClass, Type>();
  2.
  3. foreach (DictionaryEntry item in SystemObjects.ClassDictionary) {
  4.         RXClass rx;
  5.         Type type;
  6.         try {
  7.                 rx = (RXClass)item.Value;
  8.                 IntPtr ptr = rx.UnmanagedObject;
  9.                 DisposableWrapper wrap = Autodesk.AutoCAD.Runtime.DisposableWrapper.Create(typeof(Object), ptr, false);
  10.                 type = wrap.GetType();
  11.         }
  12.         catch (Exception ex) {
  13.                 //oops..
  14.         }
  15. }
  16.
but I got error:
Constructor on type 'System.Object' not found.
Andrey Bushman
« Reply #11 on: August 22, 2012, 04:35:03 AM »
Some untested code?
Code - C#: [Select]
  1.
  2. ...
  3. Type type = rxclass.GetRuntimeType();
  4. ...
  5.
Sorry, but AutoCAD 2009 .Net API has not GetRuntimeType method for RXClass class. :(
Andrey Bushman
« Reply #12 on: August 22, 2012, 04:56:00 AM »
Am I inventing a bicycle, maybe? I need to get wrapper type for each RXClass in Database. Is exists a simple and fast (for speed) solution to do it?
« Last Edit: August 22, 2012, 05:03:50 AM by Andrey »
TheMaster
« Reply #13 on: August 22, 2012, 07:30:37 AM »
Before AutoCAD 2013, the only way was to create an instance of the wrapper class, and even that wasn't foolproof if the native ARX that provides it is not available (then an ImpDBObject wrapper is created).
In AutoCAD 2013, RXClass has a new method that returns the managed wrapper type.
Andrey Bushman
« Reply #14 on: August 22, 2012, 12:03:24 PM »
Thank you for answer.
