I suppose then it comes down to the allegations that Autodesk makes that LTE used proprietary code.
I have said often that if LTE DID use Autodesk code, then it would be wrong to sell a product based on that code without approval from Autodesk.
It comes down to whom do you believe ...
LTE, a small company by any standard
ManuSoft (also party to the suit), another small company
Autodesk, a large corporation...
No, being a large company does not make Autodesk bad ... attempting to force compliance with copyright and licensing issues does not make them bad ... however, if LTE and ManuSoft are exhonerated then Autodesk is indeed the bad guy.
Personally, I am still one of those people that holds judgement until an accusation has been proven.
Our system of law has always been based on the presumption of innocence, unfortunately there are those who would burn someone at the stake for merely being accused of wrong-doing.
CADaver, I'll make a deal with you...when and if Autodesk proves their case in court, I'll agree that LTE was wrong, however, if Autodesk cannot prove their case, I'd like you to agree with me that Autodesk was wrong in pursuing this case.
What do you say?
