If you do mechanical design using plain AutoCAD then isi it right to not purchase MDT?
There is a HUGE difference between using a tool AS IT WAS DESIGNED for different uses, and using an inappropriatly modified tool for something it was never designed to do. Using plain AutoCAD "as it is designed" is different from using a "cracked" version of MDT. IS popping open the cable box and hot-wiring it to pick up un-susribed stations morally acceptable? I, personally, don't think so, and I view LTE the same.
Is it right that you should use them instead of buying the appropriate development package from Autodesk?
Yes, that is how the software is designed and marketed. If they disabled the lisp functionality to preclude such developement, then it would not... but then it would be LT.
I see this as a ploy to force people to purchase the programs they want you to use and in the end create great wealth for the company.
I can't speak for anyone else, but that's why I'm in business.
Show of hands, who is not in business to make money??
The "right" thing to do would be for Autodesk to drop pending lawsuits (if they are still pending ... that was Oct 2003) and embrace the ingenuity and development of more third party applications.
Then what about those of us who over the years have needed the advanced customization capailities of the software, and have paid for that privilege? Our original investment and periodic upgrade fees have been for nought? I doubt that AutoDESK wishes to alienate that large a portion of the current user base, and I think doing so would do great harm to their profit margin.
The simple fact is that anyone with a little bit of windows programming knowledge can write programming that will work with any program, regardless of whether the original developer ever intended it to work that way or not.
The same truth is that nearly anyone with a little specific knowledge can crack nearly any program on the market. The capability of something is separate from it's morality.
Quite honestly I am proud that I continually produce software that works with AutoCAD, extending it's capabilities beyond that which Autodesk originally designed. In my line of work, if I were to purchase the Autodesk software using the premise that it is not "right" to develop applications that are not within the intent of use of the program, then I would be morally obligated to buy LDD, ADT, MDT and Inventor .... Clearly this is NOT what I am doing and nor will I.
discussed and dismissed above.
I support the actions of LT-Extender as a viable option to the overpriced software we now currently are relegated to use.
Would you support, as well, any other "cracked", "hacked" or pirated software? I mean $500 for an office suite is insane. Would it be okay if we just bought a cracked version for our once a week use?
