Welcome to TheSwamp
You may need to explain your requirements in a little more more detail.
Hi Kerry,
Now I am working in Urban planning project in UAE. In our masterplan (its a huge project) I have to show service reservation corridor and each service utility in closed polygons. Its a requirement to make it closed polygons becouse we will transfer this data to GIS later.
Now I have more than 17000 closed polygons in my drawing. Like that I have many drawings.
Now I have to extend some polygons to overlap with the other polygon (Ie in a junction I have to extend and connect a Main sewer line to the opposite side road side sewer line).
If I will do it manually it takes time. Still I tried to stretch, but if the end of the polygon is with a curve segment it will change the radius and other properties of that polygon. Only option there is extend.
I hope now you got the Idea. Also attached a small portion of the project (partial utility).
Thanks & regards
Jithesh P. Nair
