Author Topic: Extend a closed polygon  (Read 2976 times)
jitupnair
« on: April 29, 2010, 05:03:13 AM »
I am new to this site.
I was looking for an lisp program which can EXTEND a closed polygon to any given object.
I will be always thankfull If some one can help me .
Thanks & regards
Jithesh P. Nair
Re: Extend a closed polygon
« Reply #1 on: April 29, 2010, 05:33:15 AM »
Welcome to TheSwamp :)
You may need to explain your requirements in a little more more detail.
jitupnair
« Reply #2 on: April 29, 2010, 06:05:58 AM »
Hi Kerry,
Now I am working in Urban planning project in UAE. In our masterplan (its a huge project) I have to show service reservation corridor and each service utility in closed polygons. Its a requirement to make it closed polygons becouse we will transfer this data to GIS later.
Now I have more than 17000 closed polygons in my drawing. Like that I have many drawings.
Now I have to extend some polygons to overlap with the other polygon (Ie in a junction I have to extend and connect a Main sewer line to the opposite side road side sewer line).
If I will do it manually it takes time. Still I tried to stretch, but if the end of the polygon is with a curve segment it will change the radius and other properties of that polygon. Only option there is extend.
I hope now you got the Idea.  Also attached a small portion of the project (partial utility).
Thanks & regards
Jithesh P. Nair
cmwade77
« Reply #3 on: April 29, 2010, 01:35:14 PM »
2011 will make this easier, but not quite what you are looking for. I don't know of anything that can do this at the moment, but I am sure one of the people here who are far more knowledgeable than I may have something.
