Author Topic: Dynamic Offset  (Read 46176 times)
ozimad
Re: Dynamic Offset
« Reply #90 on: March 09, 2010, 03:30:37 AM »
Function is great but it would be great if osnap function was working during stretching.
Zhenja dobavj pozhalujsta osnap  :-)
Re: Dynamic Offset
« Reply #91 on: March 09, 2010, 03:33:17 AM »
That's one of the major downsides of using the grRead loop - it takes quite a bit of coding to 'imitate' the ObjectSnap (as well as other ACAD functionality), without moving to Arx/.Net for solutions.
jitupnair
Re: Dynamic Offset
« Reply #92 on: April 29, 2010, 07:35:19 AM »
Its a very good program. I like it. Could you please make a program that will extend a closed polygon towards any given object. Its some thing like normal extend. But the condition in this case the object will be closed polygon. If you could do this it will be a greate help for me.
Please note that if the end of the polygon is with any arc segment the radius should not be changed.
Thanks & regards
Jithesh P. Nair
Re: Dynamic Offset
« Reply #93 on: April 29, 2010, 08:43:45 AM »
I see that you have already posted this question here.
Please do not double-post, it just confuses matters, and your question is not likely to get anwered any quicker, in fact, it is irritating for most when a question is posted multiple times.
Furthermore, your question is unrelated to the thread in which you have posted it.
hmspe
Re: Dynamic Offset
« Reply #94 on: April 29, 2010, 09:25:45 AM »
Lee,  do you know of an ARX or .NET replacement for GRREAD?  Two things I'd like to see in GRREAD are the option to get scan codes/key codes for all keys, and working OSNAPS.  My search hasn't turned up an ARX/.NET equivalent.  I could probably extend working code to handle the scan code issue, but I don't know enough about modern C++ or c# to program from scratch.
Martin
"Science is the belief in the ignorance of experts." - Richard Feynman
Re: Dynamic Offset
« Reply #95 on: April 29, 2010, 01:43:33 PM »
Hi Martin,
There is DynDraw.arx on here by Alexander Rivellis - it is pretty much GrRead with OSnap, plus a lot more. I've dabbled with it, but haven't really played with it enough to use it in a program.
Lee
hmspe
Re: Dynamic Offset
« Reply #96 on: May 01, 2010, 10:43:09 AM »
Thanks, Lee.
Re: Dynamic Offset
« Reply #97 on: May 01, 2010, 01:07:38 PM »
You're welcome :-)
jitupnair
Re: Dynamic Offset
« Reply #98 on: May 04, 2010, 01:13:13 AM »
Sorry Lee,
My sincere appology.
Thanks & regards
Jithesh P. nair
