uh, what do you mean it was supposed to create THREE different notes?
one user defined property each for [desc]STNSET,[col1]this, [col2]is,[col3]just a test ?
and then one label element each for the contents
or were trying to get three different labels based on something else?
[/quote]
What you have said is correct and what was shown earlier is correct. I can not get any of the comments to show up. The initial reason for the 3 columns was that the data collector had been placing a date and time stamp on every code. We had defined the setup to show all 3 columns of information to make the data show up in C3D. I would be happy if I could get the current data to work correctly. We will only need to have the 1 column added to the end of the string of information. We have found out how to remove the date and time stamp from the notes prior to the exporting of the data.
