Author Topic: Zoom Scale factor  (Read 11233 times)
ML
Zoom Scale factor
« Reply #30 on: September 17, 2004, 10:36:01 PM »
I mile is 5680' I believe
Assuming that,
If 1" = 5680'
Then
12 X 5680' = 68,160
If you divide 68,160 by 4
Then
I believe you will have 4" = 1 Mile
Scale Factor 17,040
CADaver
Zoom Scale factor
« Reply #31 on: September 18, 2004, 08:59:19 AM »
4" = 5280'
1" = 1320'
1" = 15840"
15840
3/8" = 1'-0"
3" = 8'
3" = 96"
1" = 32"
32
1/4" = 1'-0"
1" = 4'
1" = 48"
48
1" = 1'-0"
1" = 12"
12
3/4" = 1'-0"
3/4" = 12"
3" = 48"
1" = 16"
16
1" = 300'
1" = 3600"
3600
1" = 20'
1" = 240"
240
1/8" = 1'-0"
1" = 8'
1" = 96"
96
ML
Zoom Scale factor
« Reply #32 on: September 18, 2004, 09:04:29 AM »
OK, next topic :)
CADaver
Zoom Scale factor
« Reply #33 on: September 18, 2004, 09:07:54 AM »
Test it
IN MS draw a line 5280 feet long
Go to PS, zoom the viewport to 1/15480XP
Measure the line, it'll be 4"
zoom the VP to 1/17040xp
measure the line.
ML
Zoom Scale factor
« Reply #34 on: September 18, 2004, 11:37:07 AM »
Well, I did something almost exactly like that
I had drawn grids within grids, all on different layers with different colors.
One grid was 100 yards per square and the other grid was a mile per square, it was cool.
So, when I plotted, I had to go to 4" = 1 mile in order to plot to a D size sheet and still be able to scale with a scale rule
Hey, draw a rectangle, whatever size, then put this little macro I created into a custom button and try it
^C^Chatch;Ansi37;\45;
It utlizes Hatch pattern Ansi37 to draw a grid.
After you initiate the macro, you will be prompted for a scale factor, enteer the scale factor at the command line then pick the rectangle. You can use these scale factors below -----> Hope you like
Grid Size              Scale Factor
1/8"                          1
1/4"                          2
1/2"                          4
1"                             8
3"                            24
6"                            48
1'                             96
1 Yard (3')               288
1 Mile  (5,280')     506880
ML
Zoom Scale factor
« Reply #35 on: September 18, 2004, 11:39:26 AM »
Ps
You were right about the feet per mile 5,280'
Sorry about that. it is rhe correct scale factor above that I posted with the macro
ML
Zoom Scale factor
« Reply #36 on: September 18, 2004, 11:43:39 AM »
Also, your above scale factor was written  15480xp
I believe you meant 15840 which is
12 X 5,280' (1mile)  / 4 = Scale factor 15840 (4" = 1 Mile)
It works great for scaled site plans
ML
Zoom Scale factor
« Reply #37 on: September 18, 2004, 11:58:06 AM »
Last thing,
The Scale Factor is 63360 for a mile. Sorry again
CADaver
Zoom Scale factor
« Reply #38 on: September 18, 2004, 12:16:20 PM »
Quote from: ML
Typo, I can type faster than I can think.. and I type real sloooowwww.
ML
Zoom Scale factor
« Reply #39 on: September 18, 2004, 12:18:52 PM »
I made a few also as you can see  LOL
Did you try the little grid macro? It works great!
I think my brain is cooked at the moment
If we were doing 1" = 1mile, wouldn't the scale factor be 63360?
ML
Zoom Scale factor
« Reply #40 on: September 18, 2004, 12:25:41 PM »
One more correction   LOL
OK, 1 mile X 12 = 63360 if we are doing 1" = 1mile however
If you are using my above macro, keep in mind that the grid by default is 1/8" therefore, you need to do 63360 X 8 to get your grids to equal 1 mile each square. Therefore the scale factor is 506880
All scale factors i posted with that macro are correct because of the grid defaulting to 1/8"
ML
Zoom Scale factor
« Reply #41 on: September 28, 2004, 07:54:30 PM »
Or, you create your own partial menu.
Example -------->
***MENUGROUP=Scale
***POP1
                 [->&Scale Viewport]
                 [1/1]^C^Cz;1/1xp;
                 [1/4"=1']^C^Cz;1/48xp;
                 [1/8"=1']^C^C_z;1/96xp;
                 [1/16"=1']^C^C_z;1/192xp;
                 [1"=10']^C^C_z;1/120xp;
                 [1"=20']^C^C_z;1/240xp;
                 [1"=30']^C^C_z;1/360xp;
                 [1"=40']^C^C_z;1/480xp;
                 [1"=50']^C^C_z;1/600xp;
                 [<-1"=60']^C^C_z;1/720xp;
