Author Topic: Zoom Scale factor  (Read 10650 times)
Artisan
Zoom Scale factor
« on: September 07, 2004, 01:36:44 PM »
Ok, it has been forever since I tried to use the scale factor in the zoom command. (zoom;scale) The surveyor here is using Field Survey from Autodesk and cannot get his drawing to a scale in Paperspace. When he activates a viewport, the only way he could set it's scale to say 1:20 is to use the scale factor in the zoom command. My question is how is that done? I cannot remember how to do this to save my life. I remember something about xp is paperspace and x is model, but I am not sure. I currently use AutoCad Map and I have a toolbar called Viewports that has a drop down box to set the scale of a viewport in paperspace when activated. He doesn't have this toolbar, so there is no way to set the scale. I have never used Field Survey and he's the surveyor, so I'm just trying to be the CAD all here and fix everyone's problem. Thanks
PDJ
Zoom Scale factor
« Reply #1 on: September 07, 2004, 01:54:26 PM »
zoom
1/20xp
You were SOOOO close..
hyposmurf
Zoom Scale factor
« Reply #2 on: September 07, 2004, 02:03:58 PM »
I cant believe I was taught this method when I first started out!Much easier to just change the scale of the vport in properties.
CADaver
Zoom Scale factor
« Reply #3 on: September 07, 2004, 02:05:52 PM »
Quote from: hyposmurf
I cant believe I was tought this method when I first started out!Much easier to just change the scale of the vport in properties.
Only if the PROPERTIES window is already open.  I keep the screen-eatin' PITB closed unless I really need it.
hyposmurf
Zoom Scale factor
« Reply #4 on: September 07, 2004, 03:02:18 PM »
With 2004 its just a moments click away :) .PITB?Punjab Information Technology Board is the nearest I can find for that. :lol:
Zoom Scale factor
« Reply #5 on: September 07, 2004, 05:21:28 PM »
:lol: that would be
Pain In The Butt
hyposmurf
Zoom Scale factor
« Reply #6 on: September 07, 2004, 05:37:58 PM »
:lol: Aha! I was trying to think of some technical CAD term!
Zoom Scale factor
« Reply #7 on: September 07, 2004, 05:52:59 PM »
This is what I use for scaling VP's.
(defun c:zx (/ zf)
    (= (caar (vports)) 1)
      (prompt "\nYour not in an active viewport....")
      (exit)
      ); progn
    (setq zf (strcat "1/"(itoa (getint "\nEnter Scale Factor :"))"XP"))
    ); if
  (command "_zoom" zf)
  ); defun
PDJ
Zoom Scale factor
« Reply #8 on: September 07, 2004, 06:00:11 PM »
Umm, I keep that properties tool bar open on my left monitor.. :D
Zoom Scale factor
« Reply #9 on: September 07, 2004, 06:05:48 PM »
The problem with the VP toolbar in acad is that it's not setup for scales like we civil people use. i.e. 1:500, 1:1000, etc.........
that's a good idea. :D
CADaver
Zoom Scale factor
« Reply #10 on: September 07, 2004, 06:33:14 PM »
Around here it is a technical term. :)
CADaver
Zoom Scale factor
« Reply #11 on: September 07, 2004, 06:36:26 PM »
Quote from: PDJ
Not enough desktop for two monitors, the second would have to be on top.  We're squeezed for space right now.  Maybe next year we'll add a new building and we can spread out a little.
sinc
Zoom Scale factor
« Reply #12 on: September 07, 2004, 08:17:31 PM »
At least with 2004 and up, you can set the properties window to autohide.  Then you only have a long vertical strip covering the screen.  I have some toolbars on the left side of my screen, and put the properties strip right next to them; it takes up only as much space as a vertical toolbar, and is easily accessible (just mouseover to expand it).
CADaver
Zoom Scale factor
« Reply #13 on: September 07, 2004, 09:06:30 PM »
Quote from: sinc
We have 6 contracts in house that started with R2002, three of them will run another 18-24 months, so R2007 may be our next upgrade.
:cry:
:horror:
:sot:
:rip:
:crazy:
:choke:
(:fart: + solids)
PDJ
Zoom Scale factor
« Reply #14 on: September 08, 2004, 12:11:25 PM »
You don't have anough room for dual flat screens??  That's gotta be one SMALL desk..  and here I thought everything was BIG in Texas.. heheh..
