Author Topic: Why did they change cycling in 2008  (Read 4107 times)
ELOQUINTET
« on: May 30, 2007, 10:52:00 AM »
Hey guys,
I decided today that I would finally begin working in 2008. I had noticed a difference in cycling while playing around but now that I'm really drawing it was very annoying. I cycle through objects by holding down control and left mouse but now it doesn't work. Maybe this was introduced in 2007 for 3d but I just discovered there is a new variable listed below FYI ahhhh not it's back:
LEGACYCTRLPICK
Specifies the keys for selection cycling and the behavior for CTRL + left-click.
0
 CTRL + left-click is used to select subobjects (faces, edges, and vertices) on 3D solids.
1
 CTRL + left-click is used to cycle through overlapping objects. Disallows using CTRL + left-click to select subobjects on 3D solids.
Guest
Re: Why did they change cycling in 2008
« Reply #1 on: May 30, 2007, 11:11:11 AM »
Nice.  Although I've gotten used to the new and "improved" way, it's nice to know there's a way to go back!
Thanks.
Kate M
« Reply #2 on: May 30, 2007, 12:53:31 PM »
Just be aware of the 3D selection implications...and that the variable doesn't exist in LT. :pissed:
ELOQUINTET
« Reply #3 on: May 30, 2007, 01:47:19 PM »
Matt,
What is the new and "improved" way? I accidentally checked to not show the box again  :? Kate explain what you mean by 3d implications? Do you mean that I can toggle it back when doing 3d. We don't do much 3d here and when we do we don't use Autocad.
Guest
« Reply #4 on: May 30, 2007, 01:50:09 PM »
The new and improved way is the more complicated way (IMHO): pressing CTRL + SPACE.
It was a joke.  I haven't seen any benefit from pressing C + S to cycle between entities.  Just more confusion (and questions from users).
ELOQUINTET
« Reply #5 on: May 30, 2007, 01:53:45 PM »
While I'm here Can I ask a non related question. I have my dashboard set to Autohide but I also want to add to ability to have it expand by shortcut key like there is for the other palettes (ctrl+3). Sometimes I get annoyed with having to hover over it all the time. How can I do this?
ELOQUINTET
« Reply #6 on: May 30, 2007, 02:00:23 PM »
ummm Matt just out of curiousity I switched the variable back and tried to figure out the new way and can't. Let's say I have two lines very close to one another, How do I toggle through them to erase the one I want? I couldn't get it to work???
Guest
« Reply #7 on: May 30, 2007, 02:21:31 PM »
'Spose to be SHIFT + SPACE, not ctrl + space like I mentioned earlier.
Guest
« Reply #8 on: May 30, 2007, 02:24:22 PM »
Do you have it docked or anchored?
ELOQUINTET
« Reply #9 on: May 30, 2007, 02:44:03 PM »
I had it anchored but suppose I could dock it. I was thinking about creating a temporary override but doesn't a command need to be active for those to work. Basically I want to put my toolbars in the dashboard and want to be able to quickly access them from the keyboard as well as hover method. I have also added dashboard to my right click menu.
Guest
« Reply #10 on: May 30, 2007, 02:49:36 PM »
The reason I was asking is because anchored palettes seem to open MUCH faster than docked palettes (in my experience).  As soon as I hover over the icon the palette is displayed...there's no lag time at all.  It just seems to me that that would be faster than pressing CTRL + 3.
Krushert
  • FREE BEER Tomorrow!!
« Reply #11 on: May 30, 2007, 02:58:18 PM »
Doesn't answer your question directly I know but may be of help.
AutoCAD Tool Palette Rollup and Rollout Speed
Guest
« Reply #12 on: May 30, 2007, 03:07:10 PM »
I thought about that, but when the palettes are anchored and you hover over them BAM! they show up automatically so I don't know what the big difference is between docking and anchoring that makes them show up slower when docked.
Kate M
« Reply #13 on: May 30, 2007, 04:45:40 PM »
LEGACYCTRLPICK
1
If you don't do 3D in AutoCAD (we don't either), then you won't miss it. I have to learn the new way, though, 'cause my LT users can't switch it back. :|
The new and improved way is the more complicated way (IMHO): pressing SHIFT + SPACE.
Now that I've gotten used to it (which actually didn't take very long), I don't mind it. It's just as easy to hold down Shift and thumb through Spaces as to click, and the new version works with the selection preview highlight, which I like too.
ELOQUINTET
« Reply #14 on: May 30, 2007, 04:46:32 PM »
yeah I was playing around with the Rollup/out speed too. I'm trying to find the right combo. See I don't reall like my dashboard to appear the instant I hover over it as I accidently hover over it alot and it's always expanding when I don't want and the reverse applies too I don't want it collapsing as soon as I take my pointer off it. I just need to find the right setting for me i think thanks
