Hey guys,
I decided today that I would finally begin working in 2008. I had noticed a difference in cycling while playing around but now that I'm really drawing it was very annoying. I cycle through objects by holding down control and left mouse but now it doesn't work. Maybe this was introduced in 2007 for 3d but I just discovered there is a new variable listed below FYI ahhhh not it's back:
LEGACYCTRLPICK
Specifies the keys for selection cycling and the behavior for CTRL + left-click.
0
CTRL + left-click is used to select subobjects (faces, edges, and vertices) on 3D solids.
1
CTRL + left-click is used to cycle through overlapping objects. Disallows using CTRL + left-click to select subobjects on 3D solids.
