I don't remember where in the help file, I was searching for QLeader, settings, Suppress dialog box, etc....
The settings I change in the 'Leader Setttings' dialog box are -
Annotation tab: uncheck the 'Prompt for width', check 'Always left Justify', and check 'Frame Text'.
Leader Line & Arrow tab: Straight Leader Line, check the 'No Limit' for Number of Points,
The Attachment tab: Select 'Middle of Multi-line text' for both the text on the right side and on the left side.
I have some of these built into a template, but would like an icon for those instances when we don't start with that particular template.
This is a real dome scratcher. I have looked in the 'AutoCad Bible', but haven't found it yet.
craigr
