ACADINFO (SUBR) ACADINFO.LSP : c:acadinfoACETUCS-BACK (SUBR) RTUCS.LSP : c:acetUcs-backACETUCS-BOTTOM (SUBR) RTUCS.LSP : c:acetUcs-bottomACETUCS-FRONT (SUBR) RTUCS.LSP : c:acetUcs-frontACETUCS-LEFT (SUBR) RTUCS.LSP : c:acetUcs-leftACETUCS-RIGHT (SUBR) RTUCS.LSP : c:acetUcs-rightACETUCS-TOP (SUBR) RTUCS.LSP : c:acetUcs-topACAD-POP-DBMOD (EXRXSUBR) ReferHelpFile: (acad-pop-dbmod)ACAD-PUSH-DBMOD (EXRXSUBR) ReferHelpFile: (acad-push-dbmod)ACAD_COLORDLG (EXRXSUBR) Core ReferHelpFile: (acad_colordlg colornum [flag])ACAD_HELPDLG (SUBR) ReferHelpFile: (acad_helpdlg helpfile topic)ACAD_STRLSORT (EXRXSUBR) Core ReferHelpFile: (acad_strlsort list)ACAD_TRUECOLORCLI (EXRXSUBR)ACAD_TRUECOLORDLG (EXRXSUBR)ACDIMENABLEUPDATE (EXRXSUBR)ACET-ACAD-REFRESH (SUBR)ACET-ACADREACTOR-ID-ADD (SUBR)ACET-ACADREACTOR-ID-REMOVE (SUBR)ACET-ACADREACTOR-ID-REMOVE-ALL(SUBR)ACET-ACADREACTOR-ID-SWAP (SUBR)ACET-ACADREACTOR-IDS-GET (SUBR)ACET-ADDGBINEXPRESS (SUBR)ACET-ALERT (SUBR)ACET-ALT-VIEWPORT (SUBR)ACET-ANGLE-EQUAL (SUBR)ACET-ANGLE-FORMAT (SUBR)ACET-APPID-DELETE (SUBR)ACET-ARX-RE-LOAD (SUBR)ACET-ARXLOAD-OR-BUST (SUBR)ACET-AUTOLOAD (SUBR)ACET-AUTOLOAD-APPLY (SUBR)ACET-AUTOLOAD-EXEC (SUBR)ACET-AUTOLOAD2 (SUBR)ACET-BLINK-AND-SHOW-OBJECT (SUBR)ACET-BLOCK-MAKE-ANON (SUBR)ACET-BLOCK-PURGE (SUBR)ACET-BS-STRIP (SUBR)ACET-CALC-BITLIST (SUBR)ACET-CALC-ROUND (SUBR)ACET-CALC-TAN (SUBR)ACET-CMD-CHECK (SUBR)ACET-CMD-EXIT (SUBR)ACET-CURRENTVIEWPORT-ENAME (SUBR)ACET-DCL-LIST-MAKE (SUBR)ACET-DICT-ENAME (SUBR)ACET-DICT-FILTER-MATCH (SUBR)ACET-DICT-MAKE (SUBR)ACET-DICT-NAME-LIST (SUBR)ACET-DISABLED-COMMAND (SUBR)ACET-DTOR (SUBR)ACET-DXF (SUBR)ACET-EDITOR-REACTOR-ADD (SUBR)ACET-ELIST-ADD-DEFAULTS (SUBR)ACET-ELIST-FILTER--4-MATCH (SUBR)ACET-ELIST-FILTER-AND-MATCH (SUBR)ACET-ELIST-FILTER-GC-MATCH (SUBR)ACET-ELIST-FILTER-MATCH (SUBR)ACET-ELIST-FILTER-NOT-MATCH (SUBR)ACET-ELIST-FILTER-OR-MATCH (SUBR)ACET-ENT-CURVEPOINTS (EXRXSUBR)ACET-ENT-GEOMEXTENTS (EXRXSUBR) AcetUtil.chm : (acet-ent-geomextents ename)ACET-ERROR (LIST)ACET-ERROR-INIT (SUBR) AcetUtil.chm : (acet-error-init args)ACET-ERROR-RESTORE (SUBR) AcetUtil.chm : (acet-error-restore)ACET-EXPLODE (SUBR)ACET-FILE-ATTR (EXRXSUBR) AcetUtil.chm : (acet-file-attr filename [attr])ACET-FILE-BACKUP (SUBR)ACET-FILE-BACKUP-DELETE (SUBR)ACET-FILE-BACKUP-RESTORE (SUBR)ACET-FILE-CHDIR (EXRXSUBR) AcetUtil.chm : (acet-file-chdir directory)ACET-FILE-COPY (EXRXSUBR) AcetUtil.chm : (acet-file-copy from to [force])ACET-FILE-CWD (EXRXSUBR) AcetUtil.chm : (acet-file-cwd)ACET-FILE-DIR (EXRXSUBR) AcetUtil.chm : (acet-file-dir pattern [attributes] [starting-directory])ACET-FILE-FIND (SUBR)ACET-FILE-FIND-FONT (SUBR)ACET-FILE-FIND-IMAGE (SUBR)ACET-FILE-FIND-ON-PATH (SUBR)ACET-FILE-MKDIR (EXRXSUBR) AcetUtil.chm : (acet-file-mkdir directory)ACET-FILE-MOVE (EXRXSUBR) AcetUtil.chm : (acet-file-move from to)ACET-FILE-OPEN (SUBR)ACET-FILE-READDIALOG (EXRXSUBR)ACET-FILE-REMOVE (EXRXSUBR) AcetUtil.chm : (acet-file-remove filespec [force])ACET-FILE-RMDIR (EXRXSUBR) AcetUtil.chm : (acet-file-rmdir directory)ACET-FILE-SYSTIME-COMPARE (SUBR)ACET-FILE-WRITEDIALOG (EXRXSUBR)ACET-FILENAME-ACAD-ROOT (SUBR)ACET-FILENAME-ASSOCIATED-APP (SUBR)ACET-FILENAME-DIR-ON-PATH (SUBR)ACET-FILENAME-DIRECTORY (SUBR)ACET-FILENAME-EXT-REMOVE (SUBR)ACET-FILENAME-EXTENSION (SUBR)ACET-FILENAME-PATH-REMOVE (SUBR)ACET-FILENAME-SUPPORTPATH-REMOVE(SUBR)ACET-FILENAME-VALID (SUBR)ACET-FSCREEN-OFF (EXRXSUBR)ACET-FSCREEN-ON (EXRXSUBR)ACET-FSCREEN-OPTIONS (EXRXSUBR)ACET-FSCREEN-STATUS (EXRXSUBR)ACET-FSCREEN-TOGGLE (EXRXSUBR)ACET-FULL-DWGNAME (SUBR)ACET-GENERAL-PROPS-GET (SUBR)ACET-GENERAL-PROPS-GET-PAIRS (SUBR)ACET-GENERAL-PROPS-SET (SUBR)ACET-GENERAL-PROPS-SET-PAIRS (SUBR)ACET-GEOM-ANGLE-TO-ELLIPSEANGLE(SUBR)ACET-GEOM-ANGLE-TRANS (SUBR)ACET-GEOM-ARBITRARY-X (SUBR)ACET-GEOM-ARC-3P-D-ANGLE (SUBR)ACET-GEOM-ARC-BULGE (SUBR)ACET-GEOM-ARC-CENTER (SUBR)ACET-GEOM-ARC-D-ANGLE (SUBR)ACET-GEOM-ARC-DELTA-ANGLE (SUBR)ACET-GEOM-ARC-POINT-LIST (SUBR)ACET-GEOM-CALC-ARC-ERROR (SUBR)ACET-GEOM-CROSS-PRODUCT (SUBR)ACET-GEOM-DELTA-VECTOR (SUBR)ACET-GEOM-ELLIPSE-ARC-LIST (SUBR)ACET-GEOM-ELLIPSE-POINT-AT-ANGLE(SUBR)ACET-GEOM-ELLIPSE-POINT-AT-E-ANGLE(SUBR)ACET-GEOM-ELLIPSE-POINT-LIST (SUBR)ACET-GEOM-ELLIPSE-TO-PLINE (SUBR)ACET-GEOM-ELLIPSEANGLE-TO-ANGLE(SUBR)ACET-GEOM-EXTENTS (SUBR)ACET-GEOM-IMAGE-BOUNDS (SUBR)ACET-GEOM-IMAGE-CLIP-LIST (SUBR)ACET-GEOM-INSERT-CLIP-LIST (SUBR)ACET-GEOM-INSERT-POINT-LIST (SUBR)ACET-GEOM-INTERSECTWITH (SUBR)ACET-GEOM-IS-ARC (SUBR)ACET-GEOM-LIST-EXTENTS (SUBR)ACET-GEOM-LIST-FUZ (SUBR)ACET-GEOM-M-TRANS (SUBR)ACET-GEOM-MATRIX-TRANS (SUBR)ACET-GEOM-MIDPOINT (SUBR)ACET-GEOM-MTXTBOX (SUBR)ACET-GEOM-OBJECT-END-POINTS (SUBR)ACET-GEOM-OBJECT-FUZ (SUBR)ACET-GEOM-OBJECT-NORMAL-VECTOR(SUBR)ACET-GEOM-OBJECT-POINT-LIST (SUBR)ACET-GEOM-OBJECT-Z-AXIS (SUBR)ACET-GEOM-PIXEL-UNIT (SUBR)ACET-GEOM-PLINE-ARC-INFO (SUBR)ACET-GEOM-PLINE-POINT-LIST (SUBR)ACET-GEOM-POINT-FUZ (SUBR)ACET-GEOM-POINT-INSIDE (SUBR)ACET-GEOM-POINT-ROTATE (SUBR)ACET-GEOM-POINT-SCALE (SUBR)ACET-GEOM-RECT-POINTS (SUBR)ACET-GEOM-SELF-INTERSECT (SUBR)ACET-GEOM-SPLINE-POINT-LIST (SUBR)ACET-GEOM-SS-EXTENTS (SUBR)ACET-GEOM-SS-EXTENTS-ACCURATE (SUBR)ACET-GEOM-SS-EXTENTS-FAST (SUBR)ACET-GEOM-TEXTBOX (SUBR)ACET-GEOM-TRANS-IMAGE-TO-UCS (SUBR)ACET-GEOM-TRANS-UCS-TO-IMAGE (SUBR)ACET-GEOM-TXTBOX (SUBR)ACET-GEOM-UNIT-VECTOR (SUBR)ACET-GEOM-VECTOR-ADD (SUBR)ACET-GEOM-VECTOR-D-ANGLE (SUBR)ACET-GEOM-VECTOR-PARALLEL (SUBR)ACET-GEOM-VECTOR-SCALE (SUBR)ACET-GEOM-VECTOR-SIDE (SUBR)ACET-GEOM-VERTEX-LIST (SUBR)ACET-GEOM-VIEW-POINTS (SUBR)ACET-GEOM-Z-AXIS (SUBR)ACET-GEOM-ZOOM-FOR-SELECT (SUBR)ACET-GETVAR (SUBR)ACET-GETVAR-CPROFILE (SUBR)ACET-GETVAR-DWG (SUBR)ACET-GETVAR-FIXED-PROFILE (SUBR)ACET-GO-TO-EXPRESS-PAGE (SUBR)ACET-GROUP-MAKE-ANON (SUBR)ACET-HATCH-LOOP-MAKE (SUBR)ACET-HATCH-LOOP-MAKE-DATA-GET (SUBR)ACET-HATCH-LOOPEDGE-MAKE (SUBR)
ACET-HELP (EXRXSUBR) AcetUtil.chm : (acet-help [topic])ACET-HELP-TRAP (EXRXSUBR) AcetUtil.chm : (acet-help-trap command [topic [file]])ACET-HOW-TO-GET-EXPRESS (SUBR)ACET-INI-GET (EXRXSUBR) AcetUtil.chm : (acet-ini-get inifile [section [key [default]]])ACET-INI-SET (EXRXSUBR) AcetUtil.chm : (acet-ini-set inifile section [key [value]])ACET-INIT (SUBR)ACET-INIT-ACETUTIL-ARX (SUBR)ACET-INIT-ADD-LIB-DIR (SUBR)ACET-INIT-EXCLUDE-LIST (SUBR)ACET-INIT-EXPRESS-INSTALLED (SUBR)ACET-INIT-EXPRESS-NOT-INSTALLED-MSG(SUBR)ACET-INIT-FAS-LIB (SUBR)ACET-INIT-FORCE-LOAD-ARX-LIB (SUBR)ACET-INIT-GET-LIB-DIR (SUBR)ACET-INIT-PLACEMENU (SUBR)ACET-INIT-PRODKEY (SUBR)ACET-INSERT-ATTRIB-GET (SUBR)ACET-INSERT-ATTRIB-MOD (SUBR)ACET-INSERT-ATTRIB-SET (SUBR)ACET-INSERT-SPACIAL-FILTER (SUBR)ACET-IS-SYMBOL-TABLE (SUBR)ACET-LAYER-LOCKED (SUBR)ACET-LAYER-LOCKED-LIST (SUBR)ACET-LAYER-UNLOCK-ALL (SUBR)ACET-LAYERP-MARK (EXRXSUBR)ACET-LAYERP-MODE (EXRXSUBR)ACET-LIST-ASSOC-APPEND (SUBR)ACET-LIST-ASSOC-PUT (SUBR)ACET-LIST-ASSOC-REMOVE (SUBR)ACET-LIST-GROUP-BY-ASSOC (SUBR)ACET-LIST-INSERT-NTH (SUBR)ACET-LIST-IS-DOTTED-PAIR (SUBR)ACET-LIST-ISORT (SUBR)ACET-LIST-M-ASSOC (SUBR)ACET-LIST-PUT-NTH (SUBR)ACET-LIST-REMOVE-ADJACENT-DUPS(SUBR)ACET-LIST-REMOVE-DUPLICATES (SUBR)ACET-LIST-REMOVE-NTH (SUBR)ACET-LIST-SPLIT (SUBR)ACET-LIST-TO-SS (SUBR)ACET-LSP-IS-COMMAND (SUBR)ACET-LSP-IS-FUNCTION (SUBR)ACET-LSP-LOAD (SUBR)ACET-LSP-PRINC (SUBR)ACET-LWPLINE-MAKE (SUBR)ACET-MENU-LOAD (SUBR)ACET-MENU-LOAD2 (SUBR)ACET-MS-TO-PS (EXRXSUBR)ACET-PARTIAL-MENU-STATUS-GET (SUBR)ACET-PARTIAL-MENU-STATUS-SET (SUBR)ACET-PATH-TO-LIST (SUBR)ACET-PLINE-IS-2D (SUBR)ACET-PLINE-MAKE (SUBR)ACET-PLINE-SEGMENT-LIST (SUBR)ACET-PLINE-SEGMENT-LIST-APPLY (SUBR)ACET-PLINES-EXPLODE (SUBR)ACET-PLINES-EXPLODE-WIDTH-DATA-GET(SUBR)ACET-PLINES-REBUILD (SUBR)ACET-PLINES-REBUILD-APPLY-WIDTHS(SUBR)ACET-PLINES-REBUILD-SET-ELEVATION(SUBR)ACET-POINT-FLAT (SUBR)ACET-PREF-SUPPORTPATH-LIST (SUBR)ACET-PS-TO-MS (EXRXSUBR)ACET-PSPACE-VIEWPORT-ENAME (SUBR)ACET-R12-DXF-CONVERT (SUBR)ACET-RE-MAKE (SUBR)ACET-REACTOR-EXISTS (SUBR)ACET-REACTOR-REMOVE (SUBR)ACET-REG-DEL (EXRXSUBR) AcetUtil.chm : (acet-reg-del key [name])ACET-REG-GET (EXRXSUBR) AcetUtil.chm : (acet-reg-get key [name])ACET-REG-PRODKEY (EXRXSUBR) AcetUtil.chm : (acet-reg-prodkey)ACET-REG-PUT (EXRXSUBR) AcetUtil.chm : (acet-reg-put key [name value])ACET-REG-SETACTIVEX (SUBR)ACET-REG-TREE-GET (SUBR)ACET-REG-TREE-SET (SUBR)ACET-RTOD (SUBR)ACET-SAFE-COMMAND (SUBR)ACET-SCRIPTPRO-NOTFOUND-MSG (SUBR)ACET-SET-CMDECHO (SUBR)ACET-SETVAR (SUBR)ACET-SETVAR-CPROFILE (SUBR)ACET-SETVAR-DWG (SUBR)ACET-SETVAR-FIXED-PROFILE (SUBR)ACET-SPINNER (SUBR)ACET-SS-ANNOTATION-FILTER (SUBR)ACET-SS-CLEAR-PREV (SUBR)ACET-SS-CONVERT-ELLIPSES-TO-PLINES(SUBR)ACET-SS-DRAG-MOVE (EXRXSUBR) AcetUtil.chm : (acet-ss-drag-move ss pt [prompt] [highlight [cursor]])ACET-SS-DRAG-ROTATE (EXRXSUBR) AcetUtil.chm : (acet-ss-drag-rotate ss pt [prompt] [highlight [cursor]])ACET-SS-DRAG-SCALE (EXRXSUBR) AcetUtil.chm : (acet-ss-drag-scale ss pt [prompt] [highlight [cursor]])ACET-SS-ENTDEL (SUBR)ACET-SS-FILTER (SUBR)ACET-SS-FILTER-CURRENT-UCS (SUBR)ACET-SS-FILTER-ITEM (SUBR)ACET-SS-FILTER-VALIDATE (SUBR)ACET-SS-FLT-CSPACE (SUBR)ACET-SS-INTERSECTION (SUBR)ACET-SS-NEW (SUBR)ACET-SS-REDRAW (SUBR)ACET-SS-REMOVE (SUBR)ACET-SS-REMOVE-DUPS (SUBR)ACET-SS-REMOVE-DUPS-EXTENTS-LIST(SUBR)ACET-SS-REMOVE-DUPS-GENERALIZE-ENT(SUBR)ACET-SS-REMOVE-DUPS-REVERSE (SUBR)ACET-SS-SCALE-TO-FIT (SUBR)ACET-SS-SCALE-TO-FIT-BASE (SUBR)ACET-SS-SORT (SUBR)ACET-SS-SSGET-FILTER (SUBR)ACET-SS-TO-LIST (SUBR)ACET-SS-UNION (SUBR)ACET-SS-VISIBLE (SUBR)ACET-SS-ZOOM-EXTENTS (SUBR)ACET-STR-COLLATE (EXRXSUBR) AcetUtil.chm : (acet-str-collate left right [matchCase])ACET-STR-ENV-EXPAND (SUBR)ACET-STR-EQUAL (EXRXSUBR) AcetUtil.chm : (acet-str-equal left right [matchCase])ACET-STR-ESC-WILDCARDS (SUBR)ACET-STR-FIND (EXRXSUBR) AcetUtil.chm : (acet-str-find find string [ignoreCase [useRegExp]])ACET-STR-FORMAT (EXRXSUBR) AcetUtil.chm : (acet-str-format format [arg ...])ACET-STR-IS-PRINTABLE (SUBR)ACET-STR-LIST-SELECT (SUBR)ACET-STR-LR-TRIM (SUBR)ACET-STR-M-FIND (SUBR)ACET-STR-REPLACE (EXRXSUBR) AcetUtil.chm : (acet-str-replace find replace string [ignoreCase [useRegExp [count]]])ACET-STR-SPACE-TRIM (SUBR)ACET-STR-TO-LIST (SUBR)ACET-STR-WCMATCH (EXRXSUBR) AcetUtil.chm : (acet-str-wcmatch string pattern [matchCase])ACET-SYS-BEEP (EXRXSUBR) AcetUtil.chm : (acet-sys-beep sound)ACET-SYS-COMMAND (EXRXSUBR) AcetUtil.chm : (acet-sys-command shell-command)ACET-SYS-CONTROL-DOWN (SUBR)ACET-SYS-FOREGROUND (EXRXSUBR) AcetUtil.chm : (acet-sys-foreground)ACET-SYS-KEYSTATE (EXRXSUBR) AcetUtil.chm : (acet-sys-keystate keycode)ACET-SYS-LASTERR (EXRXSUBR) AcetUtil.chm : (acet-sys-lasterr)ACET-SYS-LMOUSE-DOWN (SUBR)ACET-SYS-PROCID (EXRXSUBR) AcetUtil.chm : (acet-sys-procid)ACET-SYS-SHIFT-DOWN (SUBR)ACET-SYS-SLEEP (EXRXSUBR) AcetUtil.chm : (acet-sys-sleep msecs)ACET-SYS-SPAWN (EXRXSUBR) AcetUtil.chm : (acet-sys-spawn flags command [argument ...])ACET-SYS-TERM (EXRXSUBR) AcetUtil.chm : (acet-sys-term processID)ACET-SYS-WAIT (EXRXSUBR) AcetUtil.chm : (acet-sys-wait processID [time])ACET-SYSVAR-RESTORE (SUBR)ACET-SYSVAR-SET (SUBR)ACET-TABLE-NAME-LIST (SUBR)ACET-TABLE-PURGE (SUBR)ACET-TEMP-SEGMENT (SUBR)ACET-TJUST (SUBR)ACET-TJUST-GROUP-CODES (SUBR)ACET-TJUST-KEYWORD (SUBR)ACET-UCS-CAPTURE-VIEWPORTS (SUBR)ACET-UCS-CMD (SUBR)ACET-UCS-GET (SUBR)ACET-UCS-RESTORE-VIEWPORTS (SUBR)ACET-UCS-SET (SUBR)ACET-UCS-SET-Z (SUBR)ACET-UCS-TO-OBJECT (SUBR)ACET-UI-DRAG (SUBR)ACET-UI-ENTSEL (SUBR)ACET-UI-FENCE-SELECT (SUBR)ACET-UI-GET-LONG-NAME (SUBR)ACET-UI-GETCORNER (SUBR)ACET-UI-GETFILE (SUBR)ACET-UI-M-GET-NAMES (SUBR)ACET-UI-MESSAGE (EXRXSUBR) AcetUtil.chm : (acet-ui-message message [caption [type]])ACET-UI-PICKDIR (EXRXSUBR) AcetUtil.chm : (acet-ui-pickdir [message [startDir [caption]]])ACET-UI-POLYGON-SELECT (SUBR)ACET-UI-PROGRESS (EXRXSUBR) AcetUtil.chm : (acet-ui-progress [label [max]])ACET-UI-PROGRESS-DONE (SUBR)ACET-UI-PROGRESS-INIT (SUBR)ACET-UI-PROGRESS-SAFE (SUBR)ACET-UI-SINGLE-SELECT (SUBR)ACET-UI-STATUS (EXRXSUBR) AcetUtil.chm : (acet-ui-status [message [caption]])ACET-UI-TABLE-NAME-CHECK-FLAGS(SUBR)ACET-UI-TABLE-NAME-FORMAT (SUBR)ACET-UI-TABLE-NAME-GET (SUBR)ACET-UI-TABLE-NAME-GET-CMD (SUBR)ACET-UI-TABLE-NAME-GET-CMD-LIST(SUBR)ACET-UI-TABLE-NAME-GET-DLG (SUBR)ACET-UI-TABLE-NAME-GET-ENAME (SUBR)ACET-UI-TABLE-NAME-GET-IS-VALID(SUBR)ACET-UI-TABLE-NAME-GET-ITEM-LIST(SUBR)ACET-UI-TABLE-NAME-GET-PICKIT (SUBR)ACET-UI-TABLE-NAME-OBJECT-DATA(SUBR)ACET-UI-TXTED (EXRXSUBR) AcetUtil.chm : (acet-ui-txted [text [caption [note]]])ACET-UNDO-BEGIN (SUBR)ACET-UNDO-END (SUBR)ACET-UNDO-INIT (SUBR)ACET-UNDO-RESTORE (SUBR)ACET-UTIL-VER (EXRXSUBR) AcetUtil.chm : (acet-util-ver)ACET-VAR-GETVAR (EXRXSUBR)ACET-VAR-SETVAR (EXRXSUBR)ACET-VBALOAD (SUBR)ACET-VIEWPORT-FROZEN-LAYER-LIST(SUBR)ACET-VIEWPORT-FROZEN-LAYER-LIST-SET(SUBR)ACET-VIEWPORT-LOCK-SET (SUBR)ACET-VIEWPORT-NEXT-PICKABLE (SUBR)ACET-VIEWPORT-VPFREEZE (SUBR)ACET-WMFIN (SUBR)ACET-XDATA-GET (SUBR)ACET-XDATA-SET (SUBR)ACET-XREF-CPROJECT-PATH (SUBR)ACET:OLD-ERROR (SUBR)ACETAI_FFILE (SUBR)ACETAI_NOFILE (SUBR)ACETAUTOARXACEDLOAD (SUBR)ACETAUTOARXLOAD (SUBR)ACETAUTOLOAD (SUBR)ACETAUTONATIVELOAD (SUBR)
BNS_ADD_LAYERSTATE (SUBR)BNS_ANNOTATION_SS (SUBR)BNS_BLINK_AND_SHOW_OBJECT (SUBR)BNS_BLK_MATCH (SUBR)BNS_BLKTBL_MATCH (SUBR)BNS_C_DELETE_LAYERSTATE (SUBR)BNS_C_EXPORT_LAY (SUBR)BNS_C_IMPORT_LAY (SUBR)BNS_C_RENAME_LAYERSTATE (SUBR)BNS_C_RESTORE_LAYERSTATE (SUBR)BNS_C_SAVE_LAYERSTATE (SUBR)BNS_D_LAYERSTATE (SUBR)BNS_DD_LMAN (SUBR)BNS_DL (SUBR)BNS_DLG_DL (SUBR)BNS_DLG_EDIT (SUBR)BNS_DLG_EXPORT (SUBR)BNS_DLG_IMPORT (SUBR)BNS_DLG_RENAME (SUBR)BNS_DLG_RL (SUBR)BNS_DLG_SL (SUBR)BNS_EXPORT (SUBR)BNS_FILTER_MATCH (SUBR)BNS_GET_ATT (SUBR)BNS_GET_CUR_LMANMODE (SUBR)BNS_GET_LA_STATUS (SUBR)BNS_GET_LAYERSTATES (SUBR)BNS_GET_LAYERSTATES_ALL (SUBR)BNS_GET_LMANMODE (SUBR)BNS_GET_LMANMODE_CMD (SUBR)BNS_GET_LMANMODE_DD (SUBR)BNS_GET_NEXTNAME (SUBR)BNS_GROUPS_SEL (SUBR)BNS_GROUPS_UNSEL (SUBR)BNS_LIST_LAYERSTATES (SUBR)BNS_LIST_PICK (SUBR)BNS_LMAN_IMPORT (SUBR)BNS_LMAN_LTYPEFX (SUBR)BNS_LMAN_RENAME (SUBR)BNS_LMAN_RENAME_DD (SUBR)BNS_LOCAL_LTYPE (SUBR)BNS_MOD_ATT (SUBR)BNS_NEW_STATE (SUBR)BNS_PRINC_LMANMODE (SUBR)BNS_R_LAYERSTATE (SUBR)BNS_REG_IT (SUBR)BNS_RENAME_LAYERSTATE (SUBR)BNS_RL (SUBR)BNS_SL (SUBR)BNS_SS_MOD (SUBR)BNS_TBL_MATCH (SUBR)BNS_TJUST (SUBR)BNS_TRUNCATE_2_VIEW (SUBR)BNS_VP_ON_SCREEN (SUBR)BNS_WARNING (SUBR)BNS_WRITE_IT (SUBR)
ai_abortai_acadappai_alertai_angleai_angtosai_apploadedai_aselectai_aselect1ai_autossget1ai_beepai_circtanai_circtanstartai_common_stateai_dclai_deselectai_dim_cenai_draworderai_entity_lockedai_entsnapai_errorai_ffileai_helpfileai_hideedge_alertai_nofileai_notransai_numai_onoffai_popmenucfgai_putmenucfgai_refedit_alertai_returnai_rootmenusai_rtosai_showedge_alertai_ssgetai_sslengthai_strltrimai_strrtrimai_strtrimai_tableai_tiledvpai_tiledvp_chkai_transai_transdai_undo_offai_undo_onai_undo_popai_undo_pushai_viewports_alertCTOJDTOJJTOCJTODJTOWC:DATEc:JTEST
The expresstools function chm, I think still is available here on Jimmy B. site..http://www.jtbworld.com/download/acetutil.zip
Luis, the point I am trying to get across is that there is no documentation for the majority of the express Tools, and the functions like AI_xxxx etc ... except in the defining file .... which I believe a lot of people have never looked at.
... ... ... :realmad: ... :pissed: ... :ugly:The 6 steps to working with acet-****.Very difficult to work with. Maybe its time for me to get into C# and such to do this ARX stuff.
