Author Topic: A diversion for the recreationally challenged.  (Read 35494 times)
« on: November 28, 2006, 08:43:21 PM »
These are SOME of the functions defined in Express and Bonus Tools
Who has  the function Definitions ??
ie
Purpose :
Parameters and types :
Side Effects :
Return Value :
I'll try to provide a link in this/these lists to each posted definition ..... lets see how long this takes :-)
The List < generated from AC2006 >:
ACADINFO                      (SUBR)
        ACADINFO.LSP :  c:acadinfo
ACETUCS-BACK                  (SUBR)
        RTUCS.LSP :  c:acetUcs-back
ACETUCS-BOTTOM                (SUBR)
        RTUCS.LSP :  c:acetUcs-bottom
ACETUCS-FRONT                 (SUBR)
        RTUCS.LSP :  c:acetUcs-front
ACETUCS-LEFT                  (SUBR)
        RTUCS.LSP :  c:acetUcs-left
ACETUCS-RIGHT                 (SUBR)
        RTUCS.LSP :  c:acetUcs-right
ACETUCS-TOP                   (SUBR)
        RTUCS.LSP :  c:acetUcs-top
ACAD-POP-DBMOD                (EXRXSUBR)
      ReferHelpFile:  (acad-pop-dbmod)
ACAD-PUSH-DBMOD               (EXRXSUBR)
      ReferHelpFile:  (acad-push-dbmod)
ACAD_COLORDLG                  (EXRXSUBR)                    Core
      ReferHelpFile:  (acad_colordlg colornum [flag])
ACAD_HELPDLG                  (SUBR)
      ReferHelpFile:  (acad_helpdlg helpfile topic)
ACAD_STRLSORT                 (EXRXSUBR)                    Core
      ReferHelpFile:  (acad_strlsort list)
ACAD_TRUECOLORCLI             (EXRXSUBR)
ACAD_TRUECOLORDLG             (EXRXSUBR)
ACDIMENABLEUPDATE             (EXRXSUBR)
ACET-ACAD-REFRESH             (SUBR)
ACET-ACADREACTOR-ID-ADD       (SUBR)
ACET-ACADREACTOR-ID-REMOVE    (SUBR)
ACET-ACADREACTOR-ID-REMOVE-ALL(SUBR)
ACET-ACADREACTOR-ID-SWAP      (SUBR)
ACET-ACADREACTOR-IDS-GET      (SUBR)
ACET-ADDGBINEXPRESS           (SUBR)
ACET-ALERT                    (SUBR)
ACET-ALT-VIEWPORT             (SUBR)
ACET-ANGLE-EQUAL              (SUBR)
ACET-ANGLE-FORMAT             (SUBR)
ACET-APPID-DELETE             (SUBR)
ACET-ARX-RE-LOAD              (SUBR)
ACET-ARXLOAD-OR-BUST          (SUBR)
ACET-AUTOLOAD                 (SUBR)
ACET-AUTOLOAD-APPLY           (SUBR)
ACET-AUTOLOAD-EXEC            (SUBR)
ACET-AUTOLOAD2                (SUBR)
ACET-BLINK-AND-SHOW-OBJECT    (SUBR)
ACET-BLOCK-MAKE-ANON          (SUBR)
ACET-BLOCK-PURGE              (SUBR)
ACET-BS-STRIP                 (SUBR)
ACET-CALC-BITLIST             (SUBR)
ACET-CALC-ROUND               (SUBR)
ACET-CALC-TAN                 (SUBR)
ACET-CMD-CHECK                (SUBR)
ACET-CMD-EXIT                 (SUBR)
ACET-CURRENTVIEWPORT-ENAME    (SUBR)
ACET-DCL-LIST-MAKE            (SUBR)
ACET-DICT-ENAME               (SUBR)
ACET-DICT-FILTER-MATCH        (SUBR)
ACET-DICT-MAKE                (SUBR)
ACET-DICT-NAME-LIST           (SUBR)
ACET-DISABLED-COMMAND         (SUBR)
ACET-DTOR                     (SUBR)
ACET-DXF                      (SUBR)
ACET-EDITOR-REACTOR-ADD       (SUBR)
ACET-ELIST-ADD-DEFAULTS       (SUBR)
ACET-ELIST-FILTER--4-MATCH    (SUBR)
ACET-ELIST-FILTER-AND-MATCH   (SUBR)
ACET-ELIST-FILTER-GC-MATCH    (SUBR)
ACET-ELIST-FILTER-MATCH       (SUBR)
ACET-ELIST-FILTER-NOT-MATCH   (SUBR)
ACET-ELIST-FILTER-OR-MATCH    (SUBR)
ACET-ENT-CURVEPOINTS          (EXRXSUBR)
ACET-ENT-GEOMEXTENTS          (EXRXSUBR)
        AcetUtil.chm : (acet-ent-geomextents ename)
ACET-ERROR                    (LIST)
ACET-ERROR-INIT               (SUBR)
        AcetUtil.chm : (acet-error-init args)
ACET-ERROR-RESTORE            (SUBR)
        AcetUtil.chm : (acet-error-restore)
ACET-EXPLODE                  (SUBR)
ACET-FILE-ATTR                (EXRXSUBR)
        AcetUtil.chm : (acet-file-attr filename [attr])
ACET-FILE-BACKUP              (SUBR)
ACET-FILE-BACKUP-DELETE       (SUBR)
ACET-FILE-BACKUP-RESTORE      (SUBR)
ACET-FILE-CHDIR               (EXRXSUBR)
        AcetUtil.chm : (acet-file-chdir directory)
ACET-FILE-COPY                (EXRXSUBR)
        AcetUtil.chm : (acet-file-copy from to [force])
ACET-FILE-CWD                 (EXRXSUBR)
        AcetUtil.chm : (acet-file-cwd)
ACET-FILE-DIR                 (EXRXSUBR)
        AcetUtil.chm : (acet-file-dir pattern [attributes] [starting-directory])
ACET-FILE-FIND                (SUBR)
ACET-FILE-FIND-FONT           (SUBR)
ACET-FILE-FIND-IMAGE          (SUBR)
ACET-FILE-FIND-ON-PATH        (SUBR)
ACET-FILE-MKDIR               (EXRXSUBR)
        AcetUtil.chm : (acet-file-mkdir directory)
ACET-FILE-MOVE                (EXRXSUBR)
        AcetUtil.chm : (acet-file-move from to)
ACET-FILE-OPEN                (SUBR)
ACET-FILE-READDIALOG          (EXRXSUBR)
ACET-FILE-REMOVE              (EXRXSUBR)
        AcetUtil.chm : (acet-file-remove filespec [force])
ACET-FILE-RMDIR               (EXRXSUBR)
        AcetUtil.chm : (acet-file-rmdir directory)
ACET-FILE-SYSTIME-COMPARE     (SUBR)
ACET-FILE-WRITEDIALOG         (EXRXSUBR)
ACET-FILENAME-ACAD-ROOT       (SUBR)
ACET-FILENAME-ASSOCIATED-APP  (SUBR)
ACET-FILENAME-DIR-ON-PATH     (SUBR)
ACET-FILENAME-DIRECTORY       (SUBR)
ACET-FILENAME-EXT-REMOVE      (SUBR)
ACET-FILENAME-EXTENSION       (SUBR)
ACET-FILENAME-PATH-REMOVE     (SUBR)
ACET-FILENAME-SUPPORTPATH-REMOVE(SUBR)
ACET-FILENAME-VALID           (SUBR)
ACET-FSCREEN-OFF              (EXRXSUBR)
ACET-FSCREEN-ON               (EXRXSUBR)
ACET-FSCREEN-OPTIONS          (EXRXSUBR)
ACET-FSCREEN-STATUS           (EXRXSUBR)
ACET-FSCREEN-TOGGLE           (EXRXSUBR)
ACET-FULL-DWGNAME             (SUBR)
ACET-GENERAL-PROPS-GET        (SUBR)
ACET-GENERAL-PROPS-GET-PAIRS  (SUBR)
ACET-GENERAL-PROPS-SET        (SUBR)
ACET-GENERAL-PROPS-SET-PAIRS  (SUBR)
ACET-GEOM-ANGLE-TO-ELLIPSEANGLE(SUBR)
ACET-GEOM-ANGLE-TRANS         (SUBR)
ACET-GEOM-ARBITRARY-X         (SUBR)
ACET-GEOM-ARC-3P-D-ANGLE      (SUBR)
ACET-GEOM-ARC-BULGE           (SUBR)
ACET-GEOM-ARC-CENTER          (SUBR)
ACET-GEOM-ARC-D-ANGLE         (SUBR)
ACET-GEOM-ARC-DELTA-ANGLE     (SUBR)
ACET-GEOM-ARC-POINT-LIST      (SUBR)
ACET-GEOM-CALC-ARC-ERROR      (SUBR)
ACET-GEOM-CROSS-PRODUCT       (SUBR)
ACET-GEOM-DELTA-VECTOR        (SUBR)
ACET-GEOM-ELLIPSE-ARC-LIST    (SUBR)
ACET-GEOM-ELLIPSE-POINT-AT-ANGLE(SUBR)
ACET-GEOM-ELLIPSE-POINT-AT-E-ANGLE(SUBR)
ACET-GEOM-ELLIPSE-POINT-LIST  (SUBR)
ACET-GEOM-ELLIPSE-TO-PLINE    (SUBR)
ACET-GEOM-ELLIPSEANGLE-TO-ANGLE(SUBR)
ACET-GEOM-EXTENTS             (SUBR)
ACET-GEOM-IMAGE-BOUNDS        (SUBR)
ACET-GEOM-IMAGE-CLIP-LIST     (SUBR)
ACET-GEOM-INSERT-CLIP-LIST    (SUBR)
ACET-GEOM-INSERT-POINT-LIST   (SUBR)
ACET-GEOM-INTERSECTWITH       (SUBR)
ACET-GEOM-IS-ARC              (SUBR)
ACET-GEOM-LIST-EXTENTS        (SUBR)
ACET-GEOM-LIST-FUZ            (SUBR)
ACET-GEOM-M-TRANS             (SUBR)
ACET-GEOM-MATRIX-TRANS        (SUBR)
ACET-GEOM-MIDPOINT            (SUBR)
ACET-GEOM-MTXTBOX             (SUBR)
ACET-GEOM-OBJECT-END-POINTS   (SUBR)
ACET-GEOM-OBJECT-FUZ          (SUBR)
ACET-GEOM-OBJECT-NORMAL-VECTOR(SUBR)
ACET-GEOM-OBJECT-POINT-LIST   (SUBR)
ACET-GEOM-OBJECT-Z-AXIS       (SUBR)
ACET-GEOM-PIXEL-UNIT          (SUBR)
ACET-GEOM-PLINE-ARC-INFO      (SUBR)
ACET-GEOM-PLINE-POINT-LIST    (SUBR)
ACET-GEOM-POINT-FUZ           (SUBR)
ACET-GEOM-POINT-INSIDE        (SUBR)
ACET-GEOM-POINT-ROTATE        (SUBR)
ACET-GEOM-POINT-SCALE         (SUBR)
ACET-GEOM-RECT-POINTS         (SUBR)
ACET-GEOM-SELF-INTERSECT      (SUBR)
ACET-GEOM-SPLINE-POINT-LIST   (SUBR)
ACET-GEOM-SS-EXTENTS          (SUBR)
ACET-GEOM-SS-EXTENTS-ACCURATE (SUBR)
ACET-GEOM-SS-EXTENTS-FAST     (SUBR)
ACET-GEOM-TEXTBOX             (SUBR)
ACET-GEOM-TRANS-IMAGE-TO-UCS  (SUBR)
ACET-GEOM-TRANS-UCS-TO-IMAGE  (SUBR)
ACET-GEOM-TXTBOX              (SUBR)
ACET-GEOM-UNIT-VECTOR         (SUBR)
ACET-GEOM-VECTOR-ADD          (SUBR)
ACET-GEOM-VECTOR-D-ANGLE      (SUBR)
ACET-GEOM-VECTOR-PARALLEL     (SUBR)
ACET-GEOM-VECTOR-SCALE        (SUBR)
ACET-GEOM-VECTOR-SIDE         (SUBR)
ACET-GEOM-VERTEX-LIST         (SUBR)
ACET-GEOM-VIEW-POINTS         (SUBR)
ACET-GEOM-Z-AXIS              (SUBR)
ACET-GEOM-ZOOM-FOR-SELECT     (SUBR)
ACET-GETVAR                   (SUBR)
ACET-GETVAR-CPROFILE          (SUBR)
ACET-GETVAR-DWG               (SUBR)
ACET-GETVAR-FIXED-PROFILE     (SUBR)
ACET-GO-TO-EXPRESS-PAGE       (SUBR)
ACET-GROUP-MAKE-ANON          (SUBR)
ACET-HATCH-LOOP-MAKE          (SUBR)
ACET-HATCH-LOOP-MAKE-DATA-GET (SUBR)
ACET-HATCH-LOOPEDGE-MAKE      (SUBR)
« Last Edit: November 29, 2006, 11:01:38 PM by Kerry Brown »
Re: A diversion for the recreationally challenged.
« Reply #1 on: November 28, 2006, 09:10:58 PM »
Had a few too many characters in the post, so ...
List 2 ...
ACET-HELP                     (EXRXSUBR)
        AcetUtil.chm : (acet-help [topic])
ACET-HELP-TRAP                (EXRXSUBR)
        AcetUtil.chm : (acet-help-trap command [topic [file]])
ACET-HOW-TO-GET-EXPRESS       (SUBR)
ACET-INI-GET                  (EXRXSUBR)
        AcetUtil.chm : (acet-ini-get inifile [section [key [default]]])
ACET-INI-SET                  (EXRXSUBR)
        AcetUtil.chm : (acet-ini-set inifile section [key [value]])
ACET-INIT                     (SUBR)
ACET-INIT-ACETUTIL-ARX        (SUBR)
ACET-INIT-ADD-LIB-DIR         (SUBR)
ACET-INIT-EXCLUDE-LIST        (SUBR)
ACET-INIT-EXPRESS-INSTALLED   (SUBR)
ACET-INIT-EXPRESS-NOT-INSTALLED-MSG(SUBR)
ACET-INIT-FAS-LIB             (SUBR)
ACET-INIT-FORCE-LOAD-ARX-LIB  (SUBR)
ACET-INIT-GET-LIB-DIR         (SUBR)
ACET-INIT-PLACEMENU           (SUBR)
ACET-INIT-PRODKEY             (SUBR)
ACET-INSERT-ATTRIB-GET        (SUBR)
ACET-INSERT-ATTRIB-MOD        (SUBR)
ACET-INSERT-ATTRIB-SET        (SUBR)
ACET-INSERT-SPACIAL-FILTER    (SUBR)
ACET-IS-SYMBOL-TABLE          (SUBR)
ACET-LAYER-LOCKED             (SUBR)
ACET-LAYER-LOCKED-LIST        (SUBR)
ACET-LAYER-UNLOCK-ALL         (SUBR)
ACET-LAYERP-MARK              (EXRXSUBR)
ACET-LAYERP-MODE              (EXRXSUBR)
ACET-LIST-ASSOC-APPEND        (SUBR)
ACET-LIST-ASSOC-PUT           (SUBR)
ACET-LIST-ASSOC-REMOVE        (SUBR)
ACET-LIST-GROUP-BY-ASSOC      (SUBR)
ACET-LIST-INSERT-NTH          (SUBR)
ACET-LIST-IS-DOTTED-PAIR      (SUBR)
ACET-LIST-ISORT               (SUBR)
ACET-LIST-M-ASSOC             (SUBR)
ACET-LIST-PUT-NTH             (SUBR)
ACET-LIST-REMOVE-ADJACENT-DUPS(SUBR)
ACET-LIST-REMOVE-DUPLICATES   (SUBR)
ACET-LIST-REMOVE-NTH          (SUBR)
ACET-LIST-SPLIT               (SUBR)
ACET-LIST-TO-SS               (SUBR)
ACET-LSP-IS-COMMAND           (SUBR)
ACET-LSP-IS-FUNCTION          (SUBR)
ACET-LSP-LOAD                 (SUBR)
ACET-LSP-PRINC                (SUBR)
ACET-LWPLINE-MAKE             (SUBR)
ACET-MENU-LOAD                (SUBR)
ACET-MENU-LOAD2               (SUBR)
ACET-MS-TO-PS                 (EXRXSUBR)
ACET-PARTIAL-MENU-STATUS-GET  (SUBR)
ACET-PARTIAL-MENU-STATUS-SET  (SUBR)
ACET-PATH-TO-LIST             (SUBR)
ACET-PLINE-IS-2D              (SUBR)
ACET-PLINE-MAKE               (SUBR)
ACET-PLINE-SEGMENT-LIST       (SUBR)
ACET-PLINE-SEGMENT-LIST-APPLY (SUBR)
ACET-PLINES-EXPLODE           (SUBR)
ACET-PLINES-EXPLODE-WIDTH-DATA-GET(SUBR)
ACET-PLINES-REBUILD           (SUBR)
ACET-PLINES-REBUILD-APPLY-WIDTHS(SUBR)
ACET-PLINES-REBUILD-SET-ELEVATION(SUBR)
ACET-POINT-FLAT               (SUBR)
ACET-PREF-SUPPORTPATH-LIST    (SUBR)
ACET-PS-TO-MS                 (EXRXSUBR)
ACET-PSPACE-VIEWPORT-ENAME    (SUBR)
ACET-R12-DXF-CONVERT          (SUBR)
ACET-RE-MAKE                  (SUBR)
ACET-REACTOR-EXISTS           (SUBR)
ACET-REACTOR-REMOVE           (SUBR)
ACET-REG-DEL                  (EXRXSUBR)
        AcetUtil.chm : (acet-reg-del key [name])
ACET-REG-GET                  (EXRXSUBR)
        AcetUtil.chm : (acet-reg-get key [name])
ACET-REG-PRODKEY              (EXRXSUBR)
        AcetUtil.chm : (acet-reg-prodkey)
ACET-REG-PUT                  (EXRXSUBR)
        AcetUtil.chm : (acet-reg-put key [name value])
ACET-REG-SETACTIVEX           (SUBR)
ACET-REG-TREE-GET             (SUBR)
ACET-REG-TREE-SET             (SUBR)
ACET-RTOD                     (SUBR)
ACET-SAFE-COMMAND             (SUBR)
ACET-SCRIPTPRO-NOTFOUND-MSG   (SUBR)
ACET-SET-CMDECHO              (SUBR)
ACET-SETVAR                   (SUBR)
ACET-SETVAR-CPROFILE          (SUBR)
ACET-SETVAR-DWG               (SUBR)
ACET-SETVAR-FIXED-PROFILE     (SUBR)
ACET-SPINNER                  (SUBR)
ACET-SS-ANNOTATION-FILTER     (SUBR)
ACET-SS-CLEAR-PREV            (SUBR)
ACET-SS-CONVERT-ELLIPSES-TO-PLINES(SUBR)
ACET-SS-DRAG-MOVE             (EXRXSUBR)
        AcetUtil.chm : (acet-ss-drag-move ss pt [prompt] [highlight [cursor]])
ACET-SS-DRAG-ROTATE           (EXRXSUBR)
        AcetUtil.chm : (acet-ss-drag-rotate ss pt [prompt] [highlight [cursor]])
ACET-SS-DRAG-SCALE            (EXRXSUBR)
        AcetUtil.chm : (acet-ss-drag-scale ss pt [prompt] [highlight [cursor]])
ACET-SS-ENTDEL                (SUBR)
ACET-SS-FILTER                (SUBR)
ACET-SS-FILTER-CURRENT-UCS    (SUBR)
ACET-SS-FILTER-ITEM           (SUBR)
ACET-SS-FILTER-VALIDATE       (SUBR)
ACET-SS-FLT-CSPACE            (SUBR)
ACET-SS-INTERSECTION          (SUBR)
ACET-SS-NEW                   (SUBR)
ACET-SS-REDRAW                (SUBR)
ACET-SS-REMOVE                (SUBR)
ACET-SS-REMOVE-DUPS           (SUBR)
ACET-SS-REMOVE-DUPS-EXTENTS-LIST(SUBR)
ACET-SS-REMOVE-DUPS-GENERALIZE-ENT(SUBR)
ACET-SS-REMOVE-DUPS-REVERSE   (SUBR)
ACET-SS-SCALE-TO-FIT          (SUBR)
ACET-SS-SCALE-TO-FIT-BASE     (SUBR)
ACET-SS-SORT                  (SUBR)
ACET-SS-SSGET-FILTER          (SUBR)
ACET-SS-TO-LIST               (SUBR)
ACET-SS-UNION                 (SUBR)
ACET-SS-VISIBLE               (SUBR)
ACET-SS-ZOOM-EXTENTS          (SUBR)
ACET-STR-COLLATE              (EXRXSUBR)
        AcetUtil.chm : (acet-str-collate left right [matchCase])
ACET-STR-ENV-EXPAND           (SUBR)
ACET-STR-EQUAL                (EXRXSUBR)
        AcetUtil.chm : (acet-str-equal left right [matchCase])
ACET-STR-ESC-WILDCARDS        (SUBR)
ACET-STR-FIND                 (EXRXSUBR)
        AcetUtil.chm : (acet-str-find find string [ignoreCase [useRegExp]])
ACET-STR-FORMAT               (EXRXSUBR)
        AcetUtil.chm : (acet-str-format format [arg ...])
ACET-STR-IS-PRINTABLE         (SUBR)
ACET-STR-LIST-SELECT          (SUBR)
ACET-STR-LR-TRIM              (SUBR)
ACET-STR-M-FIND               (SUBR)
ACET-STR-REPLACE              (EXRXSUBR)
        AcetUtil.chm : (acet-str-replace find replace string [ignoreCase [useRegExp [count]]])
ACET-STR-SPACE-TRIM           (SUBR)
ACET-STR-TO-LIST              (SUBR)
ACET-STR-WCMATCH              (EXRXSUBR)
        AcetUtil.chm : (acet-str-wcmatch string pattern [matchCase])
ACET-SYS-BEEP                 (EXRXSUBR)
        AcetUtil.chm : (acet-sys-beep sound)
ACET-SYS-COMMAND              (EXRXSUBR)
        AcetUtil.chm : (acet-sys-command shell-command)
ACET-SYS-CONTROL-DOWN         (SUBR)
ACET-SYS-FOREGROUND           (EXRXSUBR)
        AcetUtil.chm : (acet-sys-foreground)
ACET-SYS-KEYSTATE             (EXRXSUBR)
        AcetUtil.chm : (acet-sys-keystate keycode)
ACET-SYS-LASTERR              (EXRXSUBR)
        AcetUtil.chm : (acet-sys-lasterr)
ACET-SYS-LMOUSE-DOWN          (SUBR)
ACET-SYS-PROCID               (EXRXSUBR)
        AcetUtil.chm : (acet-sys-procid)
ACET-SYS-SHIFT-DOWN           (SUBR)
ACET-SYS-SLEEP                (EXRXSUBR)
        AcetUtil.chm : (acet-sys-sleep msecs)
ACET-SYS-SPAWN                (EXRXSUBR)
        AcetUtil.chm : (acet-sys-spawn flags command [argument ...])
ACET-SYS-TERM                 (EXRXSUBR)
        AcetUtil.chm : (acet-sys-term processID)
ACET-SYS-WAIT                 (EXRXSUBR)
        AcetUtil.chm : (acet-sys-wait processID [time])
ACET-SYSVAR-RESTORE           (SUBR)
ACET-SYSVAR-SET               (SUBR)
ACET-TABLE-NAME-LIST          (SUBR)
ACET-TABLE-PURGE              (SUBR)
ACET-TEMP-SEGMENT             (SUBR)
ACET-TJUST                    (SUBR)
ACET-TJUST-GROUP-CODES        (SUBR)
ACET-TJUST-KEYWORD            (SUBR)
ACET-UCS-CAPTURE-VIEWPORTS    (SUBR)
ACET-UCS-CMD                  (SUBR)
ACET-UCS-GET                  (SUBR)
ACET-UCS-RESTORE-VIEWPORTS    (SUBR)
ACET-UCS-SET                  (SUBR)
ACET-UCS-SET-Z                (SUBR)
ACET-UCS-TO-OBJECT            (SUBR)
ACET-UI-DRAG                  (SUBR)
ACET-UI-ENTSEL                (SUBR)
ACET-UI-FENCE-SELECT          (SUBR)
ACET-UI-GET-LONG-NAME         (SUBR)
ACET-UI-GETCORNER             (SUBR)
ACET-UI-GETFILE               (SUBR)
ACET-UI-M-GET-NAMES           (SUBR)
ACET-UI-MESSAGE               (EXRXSUBR)
        AcetUtil.chm : (acet-ui-message message [caption [type]])
ACET-UI-PICKDIR               (EXRXSUBR)
        AcetUtil.chm : (acet-ui-pickdir [message [startDir [caption]]])
ACET-UI-POLYGON-SELECT        (SUBR)
ACET-UI-PROGRESS              (EXRXSUBR)
        AcetUtil.chm : (acet-ui-progress [label [max]])
ACET-UI-PROGRESS-DONE         (SUBR)
ACET-UI-PROGRESS-INIT         (SUBR)
ACET-UI-PROGRESS-SAFE         (SUBR)
ACET-UI-SINGLE-SELECT         (SUBR)
ACET-UI-STATUS                (EXRXSUBR)
        AcetUtil.chm : (acet-ui-status [message [caption]])
ACET-UI-TABLE-NAME-CHECK-FLAGS(SUBR)
ACET-UI-TABLE-NAME-FORMAT     (SUBR)
ACET-UI-TABLE-NAME-GET        (SUBR)
ACET-UI-TABLE-NAME-GET-CMD    (SUBR)
ACET-UI-TABLE-NAME-GET-CMD-LIST(SUBR)
ACET-UI-TABLE-NAME-GET-DLG    (SUBR)
ACET-UI-TABLE-NAME-GET-ENAME  (SUBR)
ACET-UI-TABLE-NAME-GET-IS-VALID(SUBR)
ACET-UI-TABLE-NAME-GET-ITEM-LIST(SUBR)
ACET-UI-TABLE-NAME-GET-PICKIT (SUBR)
ACET-UI-TABLE-NAME-OBJECT-DATA(SUBR)
ACET-UI-TXTED                 (EXRXSUBR)
        AcetUtil.chm : (acet-ui-txted [text [caption [note]]])
ACET-UNDO-BEGIN               (SUBR)
ACET-UNDO-END                 (SUBR)
ACET-UNDO-INIT                (SUBR)
ACET-UNDO-RESTORE             (SUBR)
ACET-UTIL-VER                 (EXRXSUBR)
        AcetUtil.chm : (acet-util-ver)
ACET-VAR-GETVAR               (EXRXSUBR)
ACET-VAR-SETVAR               (EXRXSUBR)
ACET-VBALOAD                  (SUBR)
ACET-VIEWPORT-FROZEN-LAYER-LIST(SUBR)
ACET-VIEWPORT-FROZEN-LAYER-LIST-SET(SUBR)
ACET-VIEWPORT-LOCK-SET        (SUBR)
ACET-VIEWPORT-NEXT-PICKABLE   (SUBR)
ACET-VIEWPORT-VPFREEZE        (SUBR)
ACET-WMFIN                    (SUBR)
ACET-XDATA-GET                (SUBR)
ACET-XDATA-SET                (SUBR)
ACET-XREF-CPROJECT-PATH       (SUBR)
ACET:OLD-ERROR                (SUBR)
ACETAI_FFILE                  (SUBR)
ACETAI_NOFILE                 (SUBR)
ACETAUTOARXACEDLOAD           (SUBR)
ACETAUTOARXLOAD               (SUBR)
ACETAUTOLOAD                  (SUBR)
ACETAUTONATIVELOAD            (SUBR)
« Last Edit: November 29, 2006, 11:08:01 PM by Kerry Brown »
« Reply #2 on: November 28, 2006, 09:21:17 PM »
List 3 ..
BNS_ADD_LAYERSTATE            (SUBR)
BNS_ANNOTATION_SS             (SUBR)
BNS_BLINK_AND_SHOW_OBJECT     (SUBR)
BNS_BLK_MATCH                 (SUBR)
BNS_BLKTBL_MATCH              (SUBR)
BNS_C_DELETE_LAYERSTATE       (SUBR)
BNS_C_EXPORT_LAY              (SUBR)
BNS_C_IMPORT_LAY              (SUBR)
BNS_C_RENAME_LAYERSTATE       (SUBR)
BNS_C_RESTORE_LAYERSTATE      (SUBR)
BNS_C_SAVE_LAYERSTATE         (SUBR)
BNS_D_LAYERSTATE              (SUBR)
BNS_DD_LMAN                   (SUBR)
BNS_DL                        (SUBR)
BNS_DLG_DL                    (SUBR)
BNS_DLG_EDIT                  (SUBR)
BNS_DLG_EXPORT                (SUBR)
BNS_DLG_IMPORT                (SUBR)
BNS_DLG_RENAME                (SUBR)
BNS_DLG_RL                    (SUBR)
BNS_DLG_SL                    (SUBR)
BNS_EXPORT                    (SUBR)
BNS_FILTER_MATCH              (SUBR)
BNS_GET_ATT                   (SUBR)
BNS_GET_CUR_LMANMODE          (SUBR)
BNS_GET_LA_STATUS             (SUBR)
BNS_GET_LAYERSTATES           (SUBR)
BNS_GET_LAYERSTATES_ALL       (SUBR)
BNS_GET_LMANMODE              (SUBR)
BNS_GET_LMANMODE_CMD          (SUBR)
BNS_GET_LMANMODE_DD           (SUBR)
BNS_GET_NEXTNAME              (SUBR)
BNS_GROUPS_SEL                (SUBR)
BNS_GROUPS_UNSEL              (SUBR)
BNS_LIST_LAYERSTATES          (SUBR)
BNS_LIST_PICK                 (SUBR)
BNS_LMAN_IMPORT               (SUBR)
BNS_LMAN_LTYPEFX              (SUBR)
BNS_LMAN_RENAME               (SUBR)
BNS_LMAN_RENAME_DD            (SUBR)
BNS_LOCAL_LTYPE               (SUBR)
BNS_MOD_ATT                   (SUBR)
BNS_NEW_STATE                 (SUBR)
BNS_PRINC_LMANMODE            (SUBR)
BNS_R_LAYERSTATE              (SUBR)
BNS_REG_IT                    (SUBR)
BNS_RENAME_LAYERSTATE         (SUBR)
BNS_RL                        (SUBR)
BNS_SL                        (SUBR)
BNS_SS_MOD                    (SUBR)
BNS_TBL_MATCH                 (SUBR)
BNS_TJUST                     (SUBR)
BNS_TRUNCATE_2_VIEW           (SUBR)
BNS_VP_ON_SCREEN              (SUBR)
BNS_WARNING                   (SUBR)
BNS_WRITE_IT                  (SUBR)
« Last Edit: November 28, 2006, 09:25:42 PM by Kerry Brown »
« Reply #3 on: November 28, 2006, 09:38:58 PM »
... and the missed miscellaneous ones ...
a dynamic list ...
ai_abort
ai_acadapp
ai_alert
ai_angle
ai_angtos
ai_apploaded
ai_aselect
ai_aselect1
ai_autossget1
ai_beep
ai_circtan
ai_circtanstart
ai_common_state
ai_dcl
ai_deselect
ai_dim_cen
ai_draworder
ai_entity_locked
ai_entsnap
ai_error
ai_ffile
ai_helpfile
ai_hideedge_alert
ai_nofile
ai_notrans
ai_num
ai_onoff
ai_popmenucfg
ai_putmenucfg
ai_refedit_alert
ai_return
ai_rootmenus
ai_rtos
ai_showedge_alert
ai_ssget
ai_sslength
ai_strltrim
ai_strrtrim
ai_strtrim
ai_table
ai_tiledvp
ai_tiledvp_chk
ai_trans
ai_transd
ai_undo_off
ai_undo_on
ai_undo_pop
ai_undo_push
ai_viewports_alert
CTOJ
DTOJ
JTOC
JTOD
JTOW
C:DATE
c:JTEST
« Last Edit: November 28, 2006, 09:46:14 PM by Kerry Brown »
LE
« Reply #4 on: November 28, 2006, 10:27:49 PM »
The expresstools function chm, I think still is available here on Jimmy B. site..
http://www.jtbworld.com/download/acetutil.zip
LE
« Reply #5 on: November 28, 2006, 10:41:50 PM »
the AI_xxxx are part (or most of them in) ai_utils.lsp
LE
« Reply #6 on: November 28, 2006, 10:42:57 PM »
CTOJ
DTOJ
JTOC
JTOD
JTOW
C:DATE
c:JTEST
Those are in the Julian.lsp no?
« Reply #7 on: November 28, 2006, 10:44:30 PM »
Yep  ;-)  that covers about 45 of them ..
« Last Edit: November 28, 2006, 10:45:36 PM by Kerry Brown »
« Reply #8 on: November 28, 2006, 10:50:03 PM »
Luis, the point I am trying to get across is that there is no documentation for the majority of the express Tools, and the functions like AI_xxxx etc ... except in the defining file .... which I believe a lot of people have never looked at.
LE
« Reply #9 on: November 28, 2006, 10:59:16 PM »
Yep
Kerry;
I noticed that... the expresstools have been like that... there was a site by Frank Whaley - I think the original author of the ET... but like always it is closed.
« Reply #10 on: November 29, 2006, 02:04:28 AM »
I believe Frank had some input Luis, but ET was a joint venture ... some contract, some xxxxxxx , some programmed by committee  etc, etc,
[edited for legal reasons :kwb]
« Last Edit: November 30, 2006, 02:10:04 AM by Kerry Brown »
qjchen
  • Best wishes to all
« Reply #11 on: November 29, 2006, 02:18:52 AM »
Can the closed website be found by "http://web.archive.org" ?
http://qjchen.mjtd.com
« Reply #12 on: November 29, 2006, 11:14:52 PM »
Lists updated.
Oak3s
« Reply #13 on: November 03, 2010, 09:25:13 PM »
  :?... :-( ... :x ... :realmad: ... :pissed: ... :ugly:
The 6 steps to working with acet-****.
Very difficult to work with. Maybe its time for me to get into C# and such to do this ARX stuff.
Dashmonkey
  • (defun sleep nil nil)
« Reply #14 on: November 04, 2010, 06:34:20 PM »
QFT!
I remember spending about 20 min trying to figure out the syntax for ACET-STR-FORMAT.
Side note: The bad thing about having a wireless mouse is that there is no cable to rip out when you're frustrated.
I didn't break it, I swear! ...ok, I broke it.
