Author Topic: A diversion for the recreationally challenged.  (Read 35516 times)
Re: A diversion for the recreationally challenged.
« Reply #15 on: November 05, 2010, 07:22:23 AM »
I remember spending about 20 min trying to figure out the syntax for ACET-STR-FORMAT.
Side note: The bad thing about having a wireless mouse is that there is no cable to rip out when you're frustrated.
at least that one (ACET-STR-FORMAT) is listed in acetutil.chm
« Reply #16 on: November 05, 2010, 10:37:16 AM »
idea?
Everyone pick a util and write a replacement?
alanjt
  • Standby for witty remark...
« Reply #17 on: November 05, 2010, 11:41:39 AM »
idea?
I like the idea.
Dropbox
« Reply #18 on: November 05, 2010, 11:56:16 AM »
idea?
I like the idea.
My lame attempt from last year some time:
http://www.theswamp.org/index.php?topic=28895.0
Oak3s
« Reply #19 on: November 05, 2010, 04:02:12 PM »
Great idea!
I will watch :)
« Reply #20 on: November 05, 2010, 05:59:48 PM »
Was bored, so here is my quick version of acet-ss-zoom-extents  :-)
(defun swamp-ss-zoom-extents ( ss / bb )
  ;; © Lee Mac 2010
  ;; (swamp-ss-zoom-extents <SelectionSet>)
  ;; Purpose: Zooms to the Extents of a SelectionSet
  ;; Arguments:
  ;; ss: SelectionSet
  ;; Returns:
  ;; List of LowerLeft, UpperRight of SSBoundingBox
    (lambda ( i / e ll ur )
      (while (setq e (ssname ss (setq i (1+ i))))
        (vla-getBoundingBox (vlax-ename->vla-object e) 'll 'ur)
        (setq bb (cons (vlax-safearray->list ll)
                       (cons (vlax-safearray->list ur) bb))
    -1
    (lambda ( result )
      (apply 'vla-ZoomWindow (cons (vlax-get-acad-object) (mapcar 'vlax-3D-point result)))
      result
    (mapcar
      (function
        (lambda ( operation ) (apply 'mapcar (cons operation bb)))
     '(min max)
And perhaps acet-ss-to-list (yeah I'm just picking the easier ones!)
(defun swamp-ss-to-list ( ss )
  ;; © Lee Mac 2010
  ;; (swamp-ss-to-list <SelectionSet>)
  ;; Purpose: Returns list of entity names contained in a SelectionSet
  ;; Arguments:
  ;; ss: SelectionSet
  ;; Returns:
  ;; List of Entity Names
    (lambda ( i / e l )
      (reverse
          (setq l (cons e l))
    -1
Couldn't resist these three:
;; (swamp-dtor <degrees>)
;; Purpose: Converts Degrees to Radians
;; Arguments:
;; d: Real Number representing an angle in Degrees
;; Returns:
;; Real Number representing an angle in Radians
(defun swamp-dtor ( d ) (* pi (/ d 180.0)))
;; (swamp-rtod <radians>)
;; Purpose: Converts Radians to Degrees
;; Arguments:
;; r: Real Number representing an angle in Radians
;; Returns:
;; Real Number representing an angle in Degrees
(defun swamp-rtod ( r ) (* 180.0 (/ r pi)))
;; (swamp-dxf <key> <elist>)
;; Purpose: Returns the association of key in a dxf association list
;; Arguments:
;; key: integer
;; elist: dxf association list (as returned by entget)
(defun swamp-dxf ( key elist ) (cdr (assoc key elist)))
;; (swamp-ss-redraw <SelectionSet> <Mode>)
;; Purpose: Redraws the supplied SelectionSet
;; Arguments:
;; ss  : SelectionSet
;; mode: redraw mode (1=show, 2=hide, 3=highlight, 4=unhighlight)
;; Returns: nil
(defun swamp-ss-redraw ( ss mode )
    (lambda ( i / e )
        (redraw e mode)
    -1
:lol:
« Last Edit: November 05, 2010, 08:07:59 PM by Lee Mac »
Oak3s
« Reply #21 on: November 05, 2010, 06:05:11 PM »
I didnt look up what the added benefit would be to use acet-ss-zoom-extents so this question might be unreasonable but:
Could any alternatives be presented with some sort of documentation explaining what it does, returns...and maybe how...as this is the frustration with acet***...lack of documentation. At least that is my frustration.
*Edited by Oak3s 11.5.10
Thank you Lee for the documentation!!!
« Last Edit: November 05, 2010, 08:07:15 PM by Oak3s »
« Reply #22 on: November 05, 2010, 06:10:15 PM »
Haha true, I still haven't give any documentation  :lol:
Oak3s
« Reply #23 on: November 05, 2010, 06:15:57 PM »
After reading what I posted I want to just make the comment that I appreciate all the help and knowledge that has been given/shared on this forum. Lee, I have read and followed much of your material and would not want in anyway to ask for more without you and others knowing that what has been presented is a gift and received as such. By asking for more I am in no way down playing the efforts that were put forth. Thank you very much...all of you.
« Reply #24 on: November 05, 2010, 06:18:25 PM »
You're very welcome Oak3s, I'm glad that you can benefit from the stuff I post  :-)
Don't worry, I wouldn't write this stuff if I didn't enjoy it  8-)
« Last Edit: November 05, 2010, 06:27:24 PM by Lee Mac »
alanjt
« Reply #25 on: November 05, 2010, 06:25:43 PM »
Don't worry, I would write this stuff if I didn't enjoy it  8-)
lol
Dropbox
Oak3s
« Reply #26 on: November 05, 2010, 06:26:43 PM »
I caught that too.  :-D
« Reply #27 on: November 05, 2010, 06:27:49 PM »
lol
Hahahaha  :lol:
« Reply #28 on: November 05, 2010, 07:39:41 PM »
Maybe the library should have a different prefix?  Maybe instead of ' acet ' use ' swamp ', or something.   :-D
« Reply #29 on: November 05, 2010, 07:56:11 PM »
yeah,
the same with using VLA- for home built methods ... confuses me.  :|
