Author Topic: Cell styles in TableStyle...  (Read 22035 times)
pkohut
Re: Cell styles in TableStyle...
« Reply #45 on: July 26, 2010, 06:10:24 AM »
Problem solved, now I'll ask my OT question.
What software was used to annotate Kerry's and Hwd's pictures.  Can never be enough cool tools.
this
Cool, thanks.  That is on my sort list already of software to checkout. Been reading lots of good reviews about it but hadn't really seen it in action.
Glenn R
« Reply #46 on: July 26, 2010, 06:28:35 AM »
The video was a bit unclear for me.
I just looked at  the contents of  Autodesk.AutoCAD.Interop.Common for 2009
There is a public interface  IAcadTableStyle : IAcadObject
and a public interface IAcadTableStyle2 : IAcadTableStyle
ONLY the IAcadTableStyle2 has
void DeleteCellStyle(string bstrCellStyle);
void CreateCellStyle(string bstrCellStyle);
I can't test this, but perhaps try
// interop.Common.IAcadTableStyle ts = ob as interop.Common.IAcadTableStyle;
interop.Common.IAcadTableStyle2 ts = ob as interop.Common.IAcadTableStyle2;
They're Versioned COM interfaces Kerry - we've been seeing that for some years now e.g. IAcadBlock1 2 and 3, possibly more. A COM interface can't really be changed once it's 'published', so devleopers tend to 'version' them...at least that's what I remember from my C++ COM days...
Glenn R
« Reply #47 on: July 26, 2010, 06:29:43 AM »
...they version them to add the 'new' features of the underlying objects they want to expose...
« Reply #48 on: July 26, 2010, 06:56:46 AM »
Yes, that's what I discovered ... needed to look at the library in the Browser or Reflector to sort it out ... should have done that earlier I s'pose :)
Glenn R
« Reply #49 on: July 26, 2010, 06:58:57 AM »
You could probably apply the technique TT showed a couple of years ago here, about using PInvoke on an arx object. It was to do with the default indexer's on Symboltables returning erased objects...you might remember it...I'll have a dig on here...
Glenn R
« Reply #50 on: July 26, 2010, 07:03:51 AM »
« Reply #51 on: July 26, 2010, 07:18:03 AM »
Andrey,
Something you may want to check before you wrap this one up.
Is the library released with AC2009 (and any service pack) the same at the SDK ObjectARX2009.
ie: are
in the interface IAcadTableStyle2 for the released version ??
« Last Edit: July 26, 2010, 07:35:30 AM by Kerry Brown »
« Reply #52 on: July 26, 2010, 07:20:11 AM »
Andrey Bushman
« Reply #53 on: July 26, 2010, 07:54:35 AM »
I do not trust PayPal - they have deceived many people (I read about it). Has the forum a electronic purse on WebMoney?
« Last Edit: July 26, 2010, 08:01:32 AM by Hwd »
« Reply #54 on: July 26, 2010, 08:02:47 AM »
I don't know of anyone at theSwamp who has been deceived.
Perhaps an Administrator would like to move this discussion to a more suitable location.
Andrey Bushman
« Reply #55 on: July 26, 2010, 08:19:54 AM »
I am afraid to enter of my confidential data (data of my card) on page www.paypal.com
But I can do remittance on WebMoney electronic purse.
Ok. I learn as do it safe today.
« Last Edit: July 26, 2010, 08:24:10 AM by Hwd »
« Reply #56 on: July 26, 2010, 08:29:04 AM »
Andrey,
I'll forward this on to Mark who is the site owner ... he should be able to answer your question.
I wasn't suggesting that you had to make a donation, and that's not the reason I became involved in your problem.
I posted that comment because I know that a lot of people will be looking at that thread over the next few months and donations are always appreciated because they help keep this place operating.
Thanks and Regards,
Bryco
« Reply #57 on: July 26, 2010, 09:03:29 AM »
Thanks Oleg.
Glenn R
« Reply #58 on: July 26, 2010, 09:38:58 AM »
A quicky for 2010:
using System;
using System.Runtime.InteropServices;
using acadApp = Autodesk.AutoCAD.ApplicationServices.Application;
[assembly: CommandClass(typeof(CellStyles.MyCommands))]
namespace CellStyles
    public class MyCommands
        [CommandMethod("q1", CommandFlags.Modal)]
        public void TestMethod()
            Document doc = acadApp.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            Database db = doc.Database;
            using (Transaction tr = doc.TransactionManager.StartTransaction())
                DBDictionary tsd = (DBDictionary) tr.GetObject(db.TableStyleDictionaryId, OpenMode.ForRead);
                foreach (DBDictionaryEntry item in tsd)
                    TableStyle ts = (TableStyle)tr.GetObject(item.Value, OpenMode.ForRead);
                    ed.WriteMessage(string.Format("{0}Table style name: '{1}'", Environment.NewLine, ts.Name));
                    ed.WriteMessage(string.Format("{0}(TableStyle.CellStyles.IsReadOnly ='{1}')",
                        Environment.NewLine, ts.CellStyles.IsReadOnly));
                    //Print all cell style names of table style
                    PrintCellStylesInfo(ts);
                    string stName = "MyStyle";// name for my new cell style
                    ed.WriteMessage(string.Format("{0}Before modify: Cell Styles Count: {1}",
                        Environment.NewLine, ts.CellStyles.Count));
                    ts.UpgradeOpen();
                    AcDbTable.createCellStyle(ts.UnmanagedObject, stName);
                    ed.WriteMessage(string.Format("{0}After modify: Cell Styles Count: {1}{0}",
                    ts.SetCellClass(CellClass.Label, stName);
                    ed.WriteMessage(string.Format("{0}{1}{0}", "\nAfter modify:", new string('*', 30)));
                tr.Commit();
        private void PrintCellStylesInfo(TableStyle ts)
            foreach (var cs in ts.CellStyles)
                ed.WriteMessage(string.Format("{0}CellStyle Type: '{1}'; CellStyle.ToString: {2}",
                                Environment.NewLine, cs.GetType(), cs.ToString()));
    public static class AcDbTable
        // Acad::ErrorStatus createCellStyle(const ACHAR* pszCellStyle);
        [System.Security.SuppressUnmanagedCodeSecurity]
        [DllImport("acdb18.dll", CallingConvention = CallingConvention.ThisCall, CharSet = CharSet.Unicode,
           EntryPoint = "?createCellStyle@AcDbTableStyle@@QEAA?AW4ErrorStatus@Acad@@PEB_W@Z")]
        public static extern ErrorStatus createCellStyle(IntPtr tableStyle, string name);
Glenn R
« Reply #59 on: July 26, 2010, 09:39:30 AM »
2010 64bit btw...
