Author Topic: Cell styles in TableStyle...  (Read 22934 times)
LE3
Re: Cell styles in TableStyle...
« Reply #15 on: July 25, 2010, 12:01:43 PM »
just tried (have been a long time, since I did something for a table object)... using a Kean existing sample in his site, I can modify the cells with an existing cell type.
http://through-the-interface.typepad.com/through_the_interface/2008/11/creating-a-cust.html
tb.Cells[i, j].Style = "Header";
Have not tried to add a new one, but guess that has to be based on an existing one and change it from there...
Bryco
« Reply #16 on: July 25, 2010, 01:15:56 PM »
With this one can add a cellstyle, delete a cellstyle, set the textstyle for a cellstyle.
It requires you to add some textstyles and a tablestyle
1) Apparantly it is impossible (whatever you do don't actually try it)
2) It probably is no use to the OP , as it is in no way what he wanted.
3) Who wants to use interop anyway.
       [CommandMethod("tts")]
        public static void TableStyleTest()
            Document doc = acadApp.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            Database db = doc.Database;
            string tableStyleName = "YourTableStyle";
                TableStyle tableStyle;
                DBDictionary dic = tr.GetObject(db.TableStyleDictionaryId, OpenMode.ForRead) as DBDictionary;
                foreach (DictionaryEntry eDict in dic)
                    tableStyle = tr.GetObject
                        ((ObjectId)eDict.Value, OpenMode.ForRead) as TableStyle;
                    if (tableStyle.Name == tableStyleName)
                        tableStyle.UpgradeOpen();
                        ArrayList ca = tableStyle.CellStyles;
                        interop.AcadApplication Ap = (interop.AcadApplication)acadApp.AcadApplication;
                        object ob = Ap.ActiveDocument.ObjectIdToObject( tableStyle.ObjectId.OldId);
                        interop.Common.IAcadTableStyle ts = ob as interop.Common.IAcadTableStyle;
                        TextStyleTable textstyletable=tr.GetObject
                            (db.TextStyleTableId,OpenMode.ForRead) as TextStyleTable;
                        object ob2 = Ap.ActiveDocument.ObjectIdToObject(textstyletable.ObjectId.OldId);
                        interop.Common.IAcadTextStyles tss = ob2 as interop.Common.IAcadTextStyles;
                        if(ca.Contains("U1")) ts.DeleteCellStyle("U1");
                        ts.CreateCellStyle("U1");
                        ts.SetCellClass("U1", 1);
                        if (ca.Contains("U2")) ts.DeleteCellStyle("U2");
                        ts.CreateCellStyle("U2");
                        ts.SetCellClass("U2", 2);
                        if (ca.Contains("U3")) ts.DeleteCellStyle("U3");
                        ts.CreateCellStyle("U3");
                        ts.SetCellClass("U3", 3);
                        ed.WriteMessage(tss.Item("User1").ObjectID.ToString());
                        if(textstyletable.Has("User1"))
                            ts.SetTextStyleId("U1", tss.Item("User1").ObjectID);
                        if (textstyletable.Has("User2"))
                            ts.SetTextStyleId("U2", tss.Item("User2").ObjectID);
                        if (textstyletable.Has("User3"))
                            ts.SetTextStyleId("U3", tss.Item("User3").ObjectID);
                tr.Commit();
        } // end TableStyleTest
Andrey Bushman
« Reply #17 on: July 25, 2010, 01:57:30 PM »
                tr.Commit();
Bryco,
Look my previous message: "Reply #11 on: Today at 05:05:31 am".
I ask again:
Out whence in your code this methods: SetCellClass, CreateCellStyle, SetTextStyleId and DeleteCellStyle?
I even show screen (may be it was more understandable):
Is it your extension methods?
Why you use OldId property in your code?
« Last Edit: July 25, 2010, 02:04:34 PM by Hwd »
Andrey Bushman
« Reply #18 on: July 25, 2010, 02:12:15 PM »
I know about this topic, and I read it before my topic was created. You can read my message in Kean Walmsley comments (July 22, 2010 at 04:40 PM).
« Reply #19 on: July 25, 2010, 02:47:31 PM »
Hwd,
I tested Bryco's code here on Acad2010 and it works fine. So, what version are you trying to use this with?
Also, I'm not sure when this was added to the .NET API, but this code (which you had asked about)
can now be condensed to:
                        interop.Common.IAcadTableStyle ts = tableStyle.AcadObject as interop.Common.IAcadTableStyle;
The reason he had used the OldId to get the COM object, is because .NET & COM use 2 different ObjectId's.
Bryco
« Reply #20 on: July 25, 2010, 02:49:28 PM »
Add the references you need. I have both Autodac and AxdbLib.
Your on your own now, I think Fox News is hiring though.
Bryco
« Reply #21 on: July 25, 2010, 02:52:47 PM »
Oh, that's good to know Jeff
LE3
« Reply #22 on: July 25, 2010, 03:13:28 PM »
Your on your own now, I think Fox News is hiring though. ???? woot?
nice solution Bryco, thanks!.... tried here via normal .net and appears to no way.
Bryco
« Reply #23 on: July 25, 2010, 03:34:32 PM »
Andrey Bushman
« Reply #24 on: July 25, 2010, 04:41:47 PM »
I use AutoCAD 2009 x64 SP3 Enu.
Thank you. When I must use OldId?
Thank you. My project has some references, and I can't add new reference on AxdbLib.
AxdbLib is AcAxDb17enures.dll?
Autodac (may be Autocad?) is acax17enu.tbl?
I show screen my problem:
Visual Studio 2010 not cry when I use other Autodesk.AutoCAD.Interop.Common.IAcadTextStyles interface methods.
But Visual Studio 2010 cry when I use methods, whish Bryco show me. Therefore I was think, what problem not in reference. I am mistaken?
I translate this suggestion, but I can't understand it.
I did not wish to offend anybody. If Bryco has taken offence - I ask excuse me.
« Reply #25 on: July 25, 2010, 11:30:34 PM »
You do not need to reference the Autodesk.AutoCAD.Interop.Common.
You need to reference the axdb17enu.tlb (the last one shown in the Browse dialog). You should be able to see this in the COM listings as "AutoCAD/ObjectDBX Common 17.0 Type Library". With this, and the AutoCAD reference you already have, these are the only 2 required to access most, in not all, AutoCAD Interop objects, methods & properties.
The OldId is used when combining the use of .NET and COM objects, just as Bryco showed for getting a .NET object's COM counterpart. That's about the extent of my ability to explain this. Perhaps some one else can do a better or more thorough job.
« Reply #26 on: July 26, 2010, 12:06:21 AM »
You'll probably need to add there using statements also.
using acadApp = Autodesk.AutoCAD.ApplicationServices.Application;
using interop = Autodesk.AutoCAD.Interop;
I think a lot of the problems associated with attempting to resolve .NET problems is not having sufficient information.
Perhaps if we posted a zipped 'Solution' of all files for others to test some of the problems could be resolved earlier.
Sometimes it takes longer to find out what is missing than it does to resolve an actual problem .... and not all of us can make time to spare to become involved.
Andrey Bushman
« Reply #27 on: July 26, 2010, 01:17:25 AM »
Thank you!
When I use Windoxs XP x86 SP3 Professional, and AutoCAD 2009 x86 SP3 Enu - then I see "AutoCAD/ObjectDBX Common 17.0 Type Library" on COM tab.
But when I use Windoxs 7 x64 Ultimate, and AutoCAD 2009 x64 SP3 Enu - then I not see "AutoCAD/ObjectDBX Common 17.0 Type Library" on COM tab.
Screen:
"AutoCAD/ObjectDBX Common 17.0 Type Library" is absent for my x64.
Thank you. Zipped 'Solution'.
« Reply #28 on: July 26, 2010, 01:45:59 AM »
OK, my apologies. It looks like the "AutoCAD/ObjectDBX Common 17.0 Type Library" actually does point to "Autodesk.AutoCAD.Interop.Common.dll", so that should have been all you needed.
I don't have plain AutoCAD 2009, nor to I have VS2010 so I can't help with the posted file. I hope someone can get this sorted out for you.
Good Luck!
« Reply #29 on: July 26, 2010, 02:40:19 AM »
The only option I have for testing on this box is MSVS2010 with AC2011.
Opened the solution,
Re-linked the references,
Set the ACAD.EXE version in Project Properties,
Built the debug dll
loaded into AutoCAD and ran without error
A piccy:
