Author Topic: Cell styles in TableStyle...  (Read 22935 times)
Andrey Bushman
Re: Cell styles in TableStyle...
« Reply #60 on: July 26, 2010, 10:28:36 AM »
2010 64bit btw...
Thank you.
But "acdb18.dll" reference to concrete AutoCAD version.
May be it better (extension method):
   public static class AcadTableStyle
        /// <summary>
        /// Extended method for TableStyle class.
        /// </summary>
        /// <param name="tableStyle">TableStyle object (source)</param>
        /// <param name="cellStyleName">Cell Style name</param>
        public static void AddCellStyle(this TableStyle tableStyle, string cellStyleName)
            Document dwg = acad.DocumentManager.MdiActiveDocument;
            Editor ed = dwg.Editor;
            try
                if (tableStyle.CellStyles.Contains(cellStyleName)) throw new System.Exception("TableStyle has CellStyle with it name already!");
                TableStyle ts = tableStyle;
                IAcadTableStyle2 ts2 = (IAcadTableStyle2)((AcadApplication)acad.AcadApplication).ActiveDocument.ObjectIdToObject((int)ts.ObjectId.OldIdPtr);
                using (Transaction t = dwg.TransactionManager.StartTransaction())
                    lock (dwg.LockDocument())
                        ts.UpgradeOpen();
                        ts2.CreateCellStyle(cellStyleName);
                        t.Commit();
            catch (System.Exception e)
                ed.WriteMessage(string.Format("{0}{1}{0}", "\n", e.Message));
? I do not confirm, but I ask.
Testing:
using System;
using System.Runtime.InteropServices;
using acadApp = Autodesk.AutoCAD.ApplicationServices.Application;
[assembly: CommandClass(typeof(CellStyles.MyCommands))]
namespace CellStyles
    public class MyCommands
        [CommandMethod("q1", CommandFlags.Modal)]
        public void TestMethod()
            Document doc = acadApp.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            Database db = doc.Database;
            using (Transaction tr = doc.TransactionManager.StartTransaction())
                DBDictionary tsd = (DBDictionary)tr.GetObject(db.TableStyleDictionaryId, OpenMode.ForRead);
                foreach (DBDictionaryEntry item in tsd)
                    TableStyle ts = (TableStyle)tr.GetObject(item.Value, OpenMode.ForRead);
                    ed.WriteMessage(string.Format("{0}Table style name: '{1}'", Environment.NewLine, ts.Name));
                    ed.WriteMessage(string.Format("{0}(TableStyle.CellStyles.IsReadOnly ='{1}')",
                        Environment.NewLine, ts.CellStyles.IsReadOnly));
                    //Print all cell style names of table style
                    PrintCellStylesInfo(ts);
                    string stName = "MyStyle";// name for my new cell style
                    ed.WriteMessage(string.Format("{0}Before modify: Cell Styles Count: {1}",
                        Environment.NewLine, ts.CellStyles.Count));
                    ts.UpgradeOpen();
                    [color=red]ts.AddCellStyle(stName);[/color][color=green]//Extension method[/color]
                    //AcDbTable.createCellStyle(ts.UnmanagedObject, stName);
                    ed.WriteMessage(string.Format("{0}After modify: Cell Styles Count: {1}{0}",
                    ts.SetCellClass(CellClass.Label, stName);
                    ed.WriteMessage(string.Format("{0}{1}{0}", "\nAfter modify:", new string('*', 30)));
                tr.Commit();
        private void PrintCellStylesInfo(TableStyle ts)
            foreach (var cs in ts.CellStyles)
                ed.WriteMessage(string.Format("{0}CellStyle Type: '{1}'; CellStyle.ToString: {2}",
                                Environment.NewLine, cs.GetType(), cs.ToString()));
« Last Edit: July 26, 2010, 10:38:16 AM by Hwd »
Glenn R
« Reply #61 on: July 26, 2010, 10:37:47 AM »
Maybe, but you're still using COM and that's version dependent as well. Personally, I would use the DLLImport option over COM. Alexander Rivilis had a good implementation for multiple versions shown here.
Andrey Bushman
« Reply #62 on: July 26, 2010, 10:40:24 AM »
Thank you!
