Yeah, i use this method alot, saves alot of time. Like lintels for instance, save having to type in the size everytime.
Well first off you need to create a lookup parameter and action, dble click the action which will open the dialog box, this is where you input your data. the right column is the options that will appear in the drop down list. The left is for the values of the parameters that you 'attach' to the lookup. In this case you dont want to attach any parameters, you ust want to fill in the option for the drop down list (right column).
Once you have done that you need to create a attribute, in the default insert a feild, select blockplaceholder. Next select the lookup parameter in the middle column. Then select any additional formatting you want. Then go accept everything. Place the attribute. save your block and insert it again. to change what the attribute is displaying, use the drop down list then regen.
Hope this helps, let me know if you having trouble
