Author Topic: Invisible viewport  (Read 14070 times)
Matt__W
  • I like my water diluted.
Re: Invisible viewport
« Reply #60 on: January 12, 2015, 10:27:39 AM »
Autodesk Expert Elite
Rob...
« Reply #61 on: January 12, 2015, 10:28:16 AM »
Should I move the one's I've alredy put on defpoints off of there?  :sick:
I wouldn't go back and "fix" every file, but I would change the layer in all active files.
CAD Tech
tedg
« Reply #62 on: January 12, 2015, 10:38:50 AM »
Good point, that's sort of what I was thinking, if you needed to go back into those drawings, you could change it then.
And some built-in code (acaddoc.lsp) would make it happen automagically.
Windows 10 Pro 64bit, AutoCAD 2023, REVIT 2023
Bethrine
« Reply #63 on: January 12, 2015, 10:52:21 AM »
I already fixed the one's I am working on (active files). I will fix the ones I open as I go too. Thank you all!! ^-^
http://autocad.wikia.com/wiki/Defpoints_Layer
Awesome! So I can rename Defpoints to Viewport and it will automagically (I like that term) seperate all defpoints to a new Defpoints layer?
« Last Edit: January 12, 2015, 10:58:29 AM by Bethrine »
« Reply #64 on: January 12, 2015, 11:31:50 AM »
NOT  unless you are using IntelliiCAD
tedg
« Reply #65 on: January 12, 2015, 12:31:40 PM »
[SNIP]
I can't take credit for that, I stole the word from "Black Box" and I've seen others use it too.
Bethrine
« Reply #66 on: January 12, 2015, 12:33:15 PM »
 :cry:
