I'm obviously doing something wrong. The only way I can select the viewport is through qselect. After it says I have it selected (I can't tell just by looking because there's nothing showing up as being selected) I execute wblock. Source is set as "Objects" base point is "0,0,0" objects is "Retain" and I specify the file name. Click OK. I include AutoCAD Map information (not sure if this is or isn't necessary). I open the file. Nothing's there. I run qselect to attempt to get the viewport and it grabs nothing.
