I think this is my first time posting here. My problem involves a viewport that I cannot see the boundaries to. All layers are thawed and on, frame value is set to 3 (I don't know how because it says from 0-2). I can select the viewport by using the qselect command but even when I have it selected I cannot see the selection. I can, however, edit the attributes of said viewport in properties. I can easily just add another viewport to avoid this problem, I suppose, but I was wondering if anyone knew why I couldn't see it. Any help is appreciated. Thanks in advance.
