Author Topic: AutoCAD LT and add-ons - Limitations?  (Read 3157 times)
Matt__W
  • I like my water diluted.
« on: October 17, 2016, 08:22:02 AM »
I know AutoCAD LT can't utilize LSP, but is it able to use add-ons such as DLLs or custom ARX applications? Just trying to get a better understanding of the limitations of LT.
Autodesk Expert Elite
Matt__W
Re: AutoCAD LT and add-ons - Limitations?
« Reply #1 on: October 17, 2016, 08:25:29 AM »
Okay, so I found this comparison matrix and under DOCUMENTATION AND FILES there aren't any checks next to API, Autodesk Exchange Apps. But I seem to recall something years ago that would allow a user to run LSP within LT. Are there commercially available add ons that will work inside of LT?
Matt__W
« Reply #2 on: October 17, 2016, 08:47:45 AM »
Another question... since LT doesn't support LSP, is there a function/arx/whatever similar to ACAD.lsp/ACADDOC.lsp?? Is there a way to customize what happens upon starting/opening a drawing?
ChrisCarlson
« Reply #3 on: October 17, 2016, 08:57:33 AM »
Macro's and DIESEL is still supported but beyond that, I would suggest ponying up for a full edition.
rkmcswain
« Reply #4 on: October 17, 2016, 09:16:10 AM »
...or going with one of the AutoCAD clones out there, that does support lisp and other customization.
rkmcswain
« Reply #5 on: October 17, 2016, 09:21:39 AM »
Quote from: Matt__W
There was, but quite frankly, using one of the AutoCAD clones today, is simply a better choice than trying to work around the limitations of LT.
Matt__W
« Reply #6 on: October 17, 2016, 01:33:25 PM »
Okay. Cool. Thank you for the information.
