Author Topic: Attribute height change routine  (Read 2012 times)
TJAM51
« on: April 08, 2005, 11:50:52 AM »
How can the following routine be changed to do crossing, window, or single selevction sets? Thanks
;;;Attribute height change
(defun c:ahc ()
(setq atth(getreal "\nEnter new attribute height: "))
(command "attedit" "y" "*" "*" "*" "c" pause pause)
(while
(= 1 (logand (getvar "cmdactive") 1))
(command "h" atth "n")
);;; end while
);;; end lisp
« Reply #1 on: April 08, 2005, 12:23:29 PM »
A real quick spin on a different approach ...
(defun c:ahc ( / ss i height insert )
        (   (setq ss (ssget '((0 . "insert")(66 . 1))))
            (initget (+ 1 2 4))
            (setq height (getreal "\nNew attribute height: "))
                (foreach attribute
                    (vlax-invoke
                        (setq insert
                            (vlax-ename->vla-object
                                (ssname ss (setq i (1- i)))
                        'GetAttributes
                    (vla-put-height
                        attribute
                        height
                (vla-update insert)
Also, see this.
TJAM51
« Reply #2 on: April 08, 2005, 12:35:37 PM »
:D  :D OUTSTANDING...THANKS
« Reply #3 on: April 08, 2005, 12:36:13 PM »
My pleasure.
