Author Topic: Reactor...  (Read 7508 times)
Andrea
Reactor...
« on: February 28, 2005, 12:09:59 PM »
I'm trying understand reactor...
does anyone can give me some samples with the
vlr-commandWillStart
vlr-commandEnded
vlr-commandCancelled
thanks.
Keep smile...
nivuahc
Reactor...
« Reply #1 on: February 28, 2005, 12:25:43 PM »
Sure Andrea, be glad to!
Check out this link. It has quite a bit of really great information about reactors and how they work.
Andrea
Reactor...
« Reply #2 on: February 28, 2005, 02:58:20 PM »
ok...I have made this...
for test..
but the alert box apear 4 times...WHY ???
(vlr-command-reactor
nil '((:vlr-commandWillStart . startCommand))
(defun startCommand (calling-reactor startcommandInfo /)
  ;thecommandstart drgName newname)
(setq thecommandstart (nth 0 startcommandInfo))
(if (= thecommandstart "PLINE")
 (alert "The PLINE command was activated")
 (setq thecommandstart NIL)
any HELP ??
Keep smile...
Serge J. Gianolla
Reactor...
« Reply #3 on: February 28, 2005, 05:12:52 PM »
Tiens, au lieu de te casser la tete; regarde ici
http://www.theswamp.org/phpBB2/viewtopic.php?t=2745&highlight=reactors
Andrea
Reactor...
« Reply #4 on: February 28, 2005, 07:20:55 PM »
Quote from: Serge J. Gianolla
Serge !!  Bon sens,,  j'étais en train de t'écrire quand j'ai vu ton post..
depuis le temp que j'essai de trouver le pourquoi du comment.....ouf !!
Je ne sais plus comment t'appeler maintenant....
Proffesseur, Maître,....ou tout simplement Dieu !! 8)
un GROS merci....
Keep smile...
nivuahc
Reactor...
« Reply #5 on: February 28, 2005, 07:32:08 PM »
Wow, Andrea, that's an awful lot of praise you threw out there!
Should I have answered you in French?
Serge J. Gianolla
Reactor...
« Reply #6 on: February 28, 2005, 09:38:16 PM »
Ne soyons pas chauvin, nivuahc! :D  :lol:
Glad you enjoyed the other link. Reactors are great... when they behave!!! :oops:
Serge J. Gianolla
Reactor...
« Reply #7 on: February 28, 2005, 09:48:27 PM »
Pas besoin de m'appeler, je viens tout seul. <<Marrant non! :P
daron
Reactor...
« Reply #8 on: February 28, 2005, 10:06:31 PM »
French??? You might try Italian, if you want them to understand it.
Andrea
Reactor...
« Reply #9 on: March 01, 2005, 09:15:31 AM »
Daron,....
ITALIAN
Parlo anche Italiano...e tù ?
in fatto...sono nato a Roma.
 8)
ENGLISH
ok now i've discover something..
The code work only with AutoCAD 2004 and Higher..
In 2002..this code is not reset back the layer..
WHY ?
FRENCH
Je ne sais pas trop pourquoi ce foutu code ne fonctionne pas bien en 2002
il ne retourne pas à la couche précédente.
Keep smile...
SMadsen
Reactor...
« Reply #10 on: March 01, 2005, 09:27:53 AM »
Hmmm, maybe I should start writing in Danish?
[sarcasm]But then I would probably not receive any help in an english speaking forum, would I now?[/sarcasm]
Andrea
Reactor...
« Reply #11 on: March 01, 2005, 09:33:50 AM »
ok...maybe to much work than i can't see..
but i have this code..to anable reactor...
(defun c:HTz ()
 (if (CC_find_env);;detect if some variable is set
  (SDC_readSfile);;read other variables
  (setq BC1r T11r
           BC1 T11
  );;redefine some variables
  (loadreactortype);;<---HERE LOAD REACTOR NOT WORKING
);;progn
);;if
(command "_DTEXT")
);;end HTz
(defun loadreactortype ()
;;(alert "Reactor loaded")
(vlr-command-reactor nil '((:vlr-commandWillStart . startCommand)))
(vlr-command-reactor nil '((:vlr-commandEnded . endCommand)))
(vlr-command-reactor nil '((:vlr-commandCancelled . cancelCommand)))
(vlr-command-reactor nil '((:vlr-commandFailed . failedCommand)))
Also i have made tests with alertbox....and the alertbos is shown..
but the reactor is not active..
why ? :cry:  (i'm tired)
Keep smile...
Reactor...
« Reply #12 on: March 01, 2005, 09:54:39 AM »
Quit using "COMMAND" In reacor apps!
daron
Reactor...
« Reply #13 on: March 01, 2005, 10:30:20 AM »
To add to 7's comment. While it's bad to use command in reactors, it's even worse to use a command line that errors out to user control and doesn't take control back. Autocad needs to have control in order to react.
SMadsen
Reactor...
« Reply #14 on: March 01, 2005, 10:40:42 AM »
Se7en, the COMMAND is not within a callback so it's perfectly legal.
Andrea, the code you posted gives no clue to the problem, except that CC_FIND_ENV probably returns nil so that LOADREACTORTYPE will never be called.
When you get it working, I hope you are aware of the fact that the way it is written, it will add reactors each time C:HTZ is called (which can become very unpleasant).
