Se7en, the COMMAND is not within a callback so it's perfectly legal.
Andrea, the code you posted gives no clue to the problem, except that CC_FIND_ENV probably returns nil so that LOADREACTORTYPE will never be called.
When you get it working, I hope you are aware of the fact that the way it is written, it will add reactors each time C:HTZ is called (which can become very unpleasant).
