Author Topic: Setting variables in a file opened by a routine?  (Read 4697 times)
Brick_top
« on: November 23, 2011, 06:48:33 AM »
Hi there,
I would like to set new variables in a file I open with a routine.
I know I can "copy" variables from a drawing to another using vl-propagate. But how do I create new ones?
And how do I propagate more than one variable? vl-propagate only seems to propagate one variable?
thanks.
ElpanovEvgeniy
  • Moscow (Russia)
Re: Setting variables in a file opened by a routine?
« Reply #1 on: November 23, 2011, 06:56:11 AM »
(setq a 1
      b 2
      c 3
(mapcar (function vl-propagate) '(a b c))
Brick_top
« Reply #2 on: November 23, 2011, 06:56:50 AM »
Nice! thanks a lot!
« Reply #3 on: November 23, 2011, 07:05:52 AM »
(foreach sym '(a b c) (vl-propagate sym))
Brick_top
« Reply #4 on: November 23, 2011, 07:15:01 AM »
how about the other question? in case I explained my self correctly
thanks for the alternative lee
« Reply #5 on: November 23, 2011, 07:15:58 AM »
Creating a new variable:
(setq a 1)
Brick_top
« Reply #6 on: November 23, 2011, 07:18:26 AM »
lets see if I can explain my self better.
I have a routine I run in a drawing.
That routine opens another drawing, and now I want to set new variables in that drawing.
« Reply #7 on: November 23, 2011, 07:24:22 AM »
Set the variables in the active drawing and propagate them?
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #8 on: November 23, 2011, 07:58:00 AM »
If you do not have a large amount of data you can use the setenv/getenv
Brick_top
« Reply #9 on: November 23, 2011, 08:58:46 AM »
Well in the way I'm seeing things right now I don't know how to do that because of what I want to do because there are variables that need to be set differently in the "other" drawing.
What I want to do is save notes in each drawing (as xrecords) I have and then have a "master" drawing with all the notes so I can later search all the notes of all the projects. Problem is the xrecord "name?" is diferent in the master drawing.
For example I name the notes in all the projects as "Note 1" "Note 2" "Note 3" etc.. every project will start in number 1. But the "master" drawing where I'll have all the notes stored will only have one "Note 1".
« Last Edit: November 23, 2011, 09:02:30 AM by Brick_top »
Brick_top
« Reply #10 on: November 23, 2011, 09:03:18 AM »
I need to check the xrecords in the "opened by the routine" file to set the new name of the next xrecord.
At least this is what I'm thinking
Brick_top
« Reply #11 on: November 23, 2011, 09:08:12 AM »
This is what I'm doing to check the number of the note, and set the number of the next one.
(setq a (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= 3 (car x)))(entget (namedobjdict))))
         b (vl-remove-if-not '(lambda (x) (= "Nota" (substr x 1 4))) a)
         titl2 (strcat "Nota" " " (itoa (+ 1 (length b))))
   );setq
Brick_top
« Reply #12 on: November 25, 2011, 04:49:23 AM »
I gave up the ideia, I just run another routine in the opened file to set the new variables.
FreeBird
« Reply #13 on: November 27, 2011, 06:10:12 AM »
I have an idea, DBX or vl-propagate + s::startup
Brick_top
« Reply #14 on: November 28, 2011, 05:18:27 AM »
will the s::startup function define functions for every drawing?
