Author Topic: Setting variables in a file opened by a routine?  (Read 4627 times)
shawndoe
Re: Setting variables in a file opened by a routine?
« Reply #15 on: December 16, 2011, 04:22:33 PM »
It's a bit late, but I have a routine that also opens a new drawing from another and I found that (vl-bb-set/ref) is a much better option.  Vl-propogate dumps global variables in the new drawing which may cause problems.  I'm also under the impression that you can't access vl-propogate variables until after the S::STARTUP has finished.
Have a good one.
Shawndoe
GDF
« Reply #16 on: December 16, 2011, 05:12:10 PM »
I use vl-registry-write and vl-registry-read.
Example: setting globals for dialog box controls.
(defun ARCH:SETDIALMODE  (key /)
  (vl-registry-write
    "HKEY_CURRENT_USER\\Software\\Arch Program\\Controls\\Dialog\\Display"
    key)
  (setq ARCH#DIAL
         (vl-registry-read
           "HKEY_CURRENT_USER\\Software\\Arch Program\\Controls\\Dialog\\Display"))
  (princ))
TimSpangler
  • CAD Naked!!
« Reply #17 on: December 16, 2011, 06:35:54 PM »
setcfg / getcfg  8-)
ACA 2015 - Windows 7 Pro
BlackBox
« Reply #18 on: December 17, 2011, 12:38:22 AM »
  8-)
FTFY :wink:
** Note - the LISP functions are now hyperlinked to the help documentation.
« Last Edit: December 17, 2011, 04:12:51 AM by RenderMan »
« Reply #19 on: December 17, 2011, 03:43:09 AM »
I quit using setcfg and getcfg some years ago after I realized that it was causing the config file to grow and you have to manually remove orphaned entries.
Use the registry and then you can programmatically delete the keys after you no longer need them.
TimSpangler
  • CAD Naked!!
« Reply #20 on: December 17, 2011, 09:24:34 AM »
The registry is a great option also.
As long as you keep reusing the same cfg there is no issue with file bloat.  Just another way.  :kewl:
(i.e. "AppData/Vars/var1")
There are also the setenv / getenv variables.
*This was for you RenderMan :angel:
All great options as long as the limitations are taken into account.
BlackBox
« Reply #21 on: December 17, 2011, 06:07:02 PM »
 :-P
