Author Topic: PDF search For Text.  (Read 2282 times)
SDETERS
« on: May 10, 2010, 09:13:45 AM »
I want to be able to do a text search in a PDF file after I plot it from Autocad.
Is there a way do this?  I know it is an image file after it is in PDF.  Is there a magical fix to this?
I did not know the correct forum this should be in Please move if needed
M-dub
Re: PDF search For Text.
« Reply #1 on: May 10, 2010, 09:22:10 AM »
I believe that if you create the PDF directly from AutoCAD, you can do a search for files containing text just using the Windows search function.  If it's a drawing that has been SCANNED into a PDF, you're ... out of luck.
I could be wrong, though.
SDETERS
« Reply #2 on: May 10, 2010, 10:04:48 AM »
How do I create the PDf directly from Autocad?  I try to use the adobe PDF printer and I also tried the DOPDF and neither of them worked.  I may but up one of these creeks
For what it is worth I tried do to do OCR and Adobe PDF says My DPI needs to be over 72DPI but when I plot to PDF I am using 600.
Thanks for the help
« Reply #3 on: May 10, 2010, 10:11:03 AM »
you should be able to choose your PDF converter of choice as a PRINTER in autocad....
M-dub
« Reply #4 on: May 10, 2010, 10:18:39 AM »
Right, there should be a DWG to PDF.pc3 file in your list of printers.  If not, use the Add a Printer wizard and add PDF from 'Autodesk ePlot (PDF)'.
SDETERS
« Reply #5 on: May 10, 2010, 10:43:57 AM »
I have the PDF made but still unable to have searchable TExt in the PDF file.  I am using autocad 2007.
I think I am SOL.  I must be doing something wrong somwhere.
Thanks for the help
Rob...
« Reply #6 on: May 10, 2010, 10:46:36 AM »
I believe searchable PDFs from AutoCAD are a new feature in 2011.
CAD Tech
M-dub
« Reply #7 on: May 10, 2010, 11:07:49 AM »
Hmmm...
I stand corrected.  Sorry for giving you a little bit of false hope.
SDETERS
« Reply #8 on: May 10, 2010, 12:39:37 PM »
Crude  Thanks for the help all
Off to cry  :cry:
Kate M
« Reply #9 on: May 10, 2010, 01:08:45 PM »
2010, actually.
Although the fonts have to be TTF in order for the PDF to be searchable.
