I have a blocked out drawing (Dim Styles to be exact). If I purge out the dim styles, then re insert this drawing via the insert command, it asks me
if I want to redefine the block, I say yes, all is well.
Now, I have a macro that is started ^C^C-insert etc. etc.
The macro works fine, the drawing inserts "but" my dimstyles are not there. This is the problem.
So, is there a way to redefine the block via command line. Is it even necessary? Or, is there another problem that I don't know about?
Thank you
