Author Topic: Redefining Blocks  (Read 6800 times)
ML
Redefining Blocks
« on: November 10, 2004, 08:53:57 AM »
I have a blocked out drawing (Dim Styles to be exact). If I purge out the dim styles, then re insert this drawing  via the insert command, it asks me
if I want to redefine the block, I say yes, all is well.
Now, I have a macro that is started ^C^C-insert etc. etc.
The macro works fine, the drawing inserts "but" my dimstyles are not there. This is the problem.
So, is there a way to redefine the block via command line. Is it even necessary? Or, is there another problem that I don't know about?
Thank you
Redefining Blocks
« Reply #1 on: November 10, 2004, 09:07:57 AM »
MikePerry
Re: Redefining Blocks
« Reply #2 on: November 10, 2004, 09:09:25 AM »
Hi
What exactly do you mean by "my dimstyles are not there" -
New Dimstyles simply don't load
New Dimstyles don't overwrite existing Dimstyles that share the same names
Something else
Maybe take a look at the system variable Expert when running your command macro.
Have a good one, Mike
ML
Redefining Blocks
« Reply #3 on: November 10, 2004, 01:57:49 PM »
I have a drawing that contains The DIMstyles only.
We Insert if we need the DimStyles
CADaver
Redefining Blocks
« Reply #4 on: November 10, 2004, 04:14:29 PM »
If you insert a block that already exisits in the drawing it will prompt you to redefine and you need to answer YES to get the dimstyles.  Check the command syntax and adjust your code accordingly.
ML
Redefining Blocks
« Reply #5 on: November 10, 2004, 07:08:02 PM »
Yes, I am aware of that CAD but I am inserting the wblocked (Dim Styles drawing) via a macro
It appears to be inserting just fine but the Dim Styles are not
What do you think?
MikePerry
Redefining Blocks
« Reply #6 on: November 10, 2004, 07:30:57 PM »
Hi
Could you please post your DimStyle drawing file and Macro for Inserting the DimStyle drawing file.
Does the Insertion of the DimStyles always fail, doesn't matter if you -
Insert into an existing drawing file
Insert into a new drawing file
ML
Redefining Blocks
« Reply #7 on: November 10, 2004, 07:36:32 PM »
Hey Mike
If I insert into a new drawing, it is fine. It is if the Dim Styles are not used, then purged out
Then, I re insert the Dims drawing and that is where they are not showing up
MikePerry
Redefining Blocks
« Reply #8 on: November 10, 2004, 07:51:40 PM »
Hi
Are you bringing in the DimStyle drawing file as a Block (ie Not Exploding on insertion) OR Exploding on insertion?
If as a Block, maybe look at setting system variable Expert = 2 before bringing in.
OR
Try bringing it in Pre Exploded instead.
ML
Redefining Blocks
« Reply #9 on: November 10, 2004, 08:06:02 PM »
No, I am not exploding it because there are no objects to explode but someone else recommended the expert variable, or may be you did earlier
Doesn't this expert variable do more then what we may want?
May be I will build (setvar "expert" 2) insert my block then (setvar "expert" 0)
here is how it effects blocks  --->
Suppresses the preceding prompts and "Block already defined. Redefine it?" (BLOCK) and "A drawing with this name already exists. Overwrite it?" (SAVE or WBLOCK).
Redefining Blocks
« Reply #10 on: November 10, 2004, 08:28:29 PM »
You can use this it will purge the block but leave the dims in the drawing.
This is one line so when you paste it into a botton make sure ther are no ^M; added by ACAD.
If your block dwg is in the ACAD path you don't need the path.
^C^C(COMMAND "INSERT" "DimBlock=Dim-Style.DWG" "0,0" "1" "1" "0" "._erase" (entlast) "" "._purge" "B" "DimBlock" "N")
Redefining Blocks
« Reply #11 on: November 10, 2004, 09:39:02 PM »
Mark, your latest post provides a bit more info, the block is not exploded, does not contain graphical objects and as such cannot be purged UNLESS you delete the block, which you can only do with code.
You CAN redefine the block, but only if you insert it from the hard drive file, not by simply re-inserting it. You have to provide the entire path to the file on the HD in order to redefine it.
Dent Cermak
Redefining Blocks
« Reply #12 on: November 10, 2004, 09:45:55 PM »
INSERT
BLOCK A= BLOCK B
ENTER
ENTER
ML
Redefining Blocks
« Reply #13 on: November 10, 2004, 10:58:59 PM »
Hey Keith
Thank you for the reply.
I am actually able to purge the dim styles out of the drawing but according to what you are saying, I will need to enter the entire path into the menu macro, is that correct?
Thank you
ML
Redefining Blocks
« Reply #14 on: November 10, 2004, 11:00:11 PM »
In other words
^C^C-insert;entire path including filename;
