Hi....
First,..welcome to theswamp !
Hi Andrea,
does not work:
Pick Text location...
bad argument type: 2D/3D point: nil
At this point,...what kind of object entity you have selected ?
;;Create leader point
(if (> (distance int urpoint) (distance int ulpoint))....
"urpoint" is nil and "ulpoint" is nil
some variable are local and will aways return nil at the end if they was nil
into dilconfig function and createdildialog function
"(strcat (getvar "SAVEFILEPATH") "dlconfig.dcl")"
is "D:\\Tempdlconfig.dcl"
adding "\\" write the correct file name path
"(strcat (getvar "SAVEFILEPATH")"\\" "dlconfig.dcl")"
is "D:\\Temp\\dlconfig.dcl"
I do not understand..why you don't have the "\\" at the end...
