Author Topic: Dynamic Intelligent Leader !  (Read 183946 times)
Andrea
Re: Dynamic Intelligent Leader !
« Reply #135 on: September 08, 2009, 02:59:51 PM »
Ich habe nicht gewusst, dass jemand hier spricht Deutsch   :-)
Ich wusste nicht, gab es zwei  :wink:
Danke Marco.
Keep smile...
Sebb77
« Reply #136 on: September 08, 2009, 03:30:29 PM »
 :-o   My goodness your creativity level is going through the roof !! Excellent as always...
You're making LISPER MAGASINE 's cover this month....again...  :-D
Seb
« Reply #137 on: September 08, 2009, 03:36:03 PM »
Andrea I get this with the latest version:
Command: dil
(T)ext/(M)text ?<M>: t
Do you want Multiple Object Selection ?(Y)es/(N)o ?<YES>: n
Text: Lee Mac
Select Object...
Pick Text location...
bad argument type: 2D/3D point: nil
Just tried clicking on a closed LWPolyline...
« Reply #138 on: September 08, 2009, 03:54:01 PM »
One thing I do notice, you write a lot of registry keys with the program, I count about 5... is this really necessary? I suppose it doesn't matter too much with todays machines, but I was always advised not to bloat the registry too much  :|
Andrea
« Reply #139 on: September 08, 2009, 04:51:40 PM »
Lee,..you'r right,
this was just to keep the Config settings..
but maybe it will be better to write on a text file ?
I think that way will be useful to share config via network and user will not loose there settings each time they change the PC.
Is that make sence ?
Seb...Thanks ! I'm glad that you like the program.  ;-)
Keep smile...
« Reply #140 on: September 08, 2009, 07:23:10 PM »
Good idea with the Text File - or maybe just one registry key with the information in a list?
alanjt
  • Standby for witty remark...
« Reply #141 on: September 08, 2009, 10:09:50 PM »
Lee,..you'r right,
excellent idea with the text file.
being able to write out all settings to an ini, etc. that could be placed on the network would be the best option.
Dropbox
alanjt
« Reply #142 on: September 08, 2009, 10:12:44 PM »
i thought you could only write strings to the registry? then you would have to comma delineate it before writing to registry and converting to list for processing, or am i wrong about the registry?
great idea to combine everything.
Dropbox
zanze02
  • Mosquito
« Reply #143 on: September 09, 2009, 03:52:15 AM »
Hi Andrea,
does not work:
  ;;Create leader point
(if (> (distance int urpoint) (distance int ulpoint))....
"urpoint" is nil and "ulpoint" is nil
into dilconfig function and createdildialog function
"(strcat (getvar "SAVEFILEPATH") "dlconfig.dcl")"
is "D:\\Tempdlconfig.dcl"
adding "\\" write the correct file name path
"(strcat (getvar "SAVEFILEPATH")"\\" "dlconfig.dcl")"
is "D:\\Temp\\dlconfig.dcl"
regards
« Reply #144 on: September 09, 2009, 07:23:55 AM »
I would vl-princ-to-string a list and write it to the registry, then read it when retrieving - but the text file seems like the best option.
Andrea
« Reply #145 on: September 09, 2009, 08:39:01 AM »
Hi....
First,..welcome to theswamp !  :-)
Hi Andrea,
does not work:
At this point,...what kind of object entity you have selected ?
some variable are local and will aways return nil at the end if they was nil
I do not understand..why you don't have the "\\" at the end...
Keep smile...
Andrea
« Reply #146 on: September 09, 2009, 08:44:04 AM »
I have think about it yesterday..
but I think that can't make big diffrence..
because I need to save the Path of the configuration text file (ini) in the registry...lol !
or maybe to another local text file who have information of the network path location...ah !
« Last Edit: September 09, 2009, 08:48:14 AM by Andrea »
Keep smile...
alanjt
« Reply #147 on: September 09, 2009, 08:51:07 AM »
have it in a support path, with additional options.
(or (findfile "blah.ini")
     (vl-registry-read
     (vl-registry-write
Dropbox
architecture68-raff
  • Strange things are afoot at the Circle-K.
« Reply #148 on: September 09, 2009, 09:16:44 AM »
Hi Andrea,
does not work:
I am getting this error too no matter what kind of object I select, but I am using Autocad 2005.  Although I don't remember what the exact reason is, I seem to recall an explanation as to why your other dynamic routines (dhatch, dcloud, etc.) will not function correctly in older versions.  Perhaps this is part of his problem?
Chicago, Illinois
ADT 2005, Revit Architecture 2009, Sketchup 7
Andrea
« Reply #149 on: September 09, 2009, 09:55:26 AM »
Hi Andrea,
does not work:
Fixed !  thanks..
was an error on local variables.  ;-)
DiLEADER 2.2.4
Keep smile...
