Author Topic: Remove-if ... etal  (Read 3848 times)
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
Remove-if ... etal
« on: March 12, 2009, 12:02:06 AM »
A sort of challenge ..
(vl-directory-files .... includes  ("." ".." etc if the folder is not a root drive
To remove these strings if existing I tried these
 ... any others ??
(defun _test01 ()
  (setq bom:ParentFolder "F:\\WDT-BOM-Data"
        Folders          (vl-remove-if (function (lambda (g) (or (= g ".") (= g ".."))))
                                       (vl-directory-files bom:ParentFolder NIL -1)
(defun _test02 ()
        Folders          (vl-remove ".." (vl-remove "." (vl-directory-files bom:ParentFolder NIL -1)))
(defun _test03 ()
        Folders          (if (= "." (car (setq Folders (vl-directory-files bom:ParentFolder NIL -1))))
                           (if (= ".." (car (setq Folders (cdr Folders))))
(benchMark '((_test01) (_test02) (_test03)))
Benchmarking [M.P. 2005] .........Elapsed milliseconds for 64 iteration(s)/ relative Timing :
    (_TEST02).....796 / 1.0845 <slowest>
    (_TEST01).....766 / 1.0436
    (_TEST03).....734 / 1 <fastest>
edit: clumsy and stupid
« Last Edit: March 12, 2009, 12:34:16 AM by kdub@wdt »
Called Kerry in my other life
I live at UTC + 13.00
kdub_nz
  • SuperMod
Re: Remove-if ... etal
« Reply #1 on: March 12, 2009, 12:08:37 AM »
... and does anyone know for definite if there is ever only ONE elipsis returned or always either NONE or TWO ??
« Reply #2 on: March 12, 2009, 12:22:02 AM »
Sorry, I don't know the answer to your last question and I can't run AutoCAD right now to find out.
Untested but what if you use the member function (member g '("." "..")) in _test01 instead of the or construct? It's fewr function calls than the other variants so it might bench faster.
kdub_nz
  • SuperMod
« Reply #3 on: March 12, 2009, 12:32:21 AM »
good thought ..  close to the money :)
(defun _test04 ()
        Folders          (vl-remove-if (function (lambda (g) (member g '("." "..") )))
(benchMark '((_test01) (_test02) (_test03) (_test04)))
    (_TEST04).....797 / 1.0858 <slowest>
    (_TEST03).....781 / 1.064
    (_TEST02).....765 / 1.0422
    (_TEST01).....734 / 1 <fastest>
« Reply #4 on: March 12, 2009, 12:35:56 AM »
Great, the worst. So much for that idea <facepalm>.
kdub_nz
  • SuperMod
« Reply #5 on: March 12, 2009, 12:37:23 AM »
but it's only 'worse' by a poofteenth   :)
« Reply #6 on: March 12, 2009, 12:39:43 AM »
Worse by 8.6%. That ain't poofteenth.
« Reply #7 on: March 12, 2009, 12:55:15 AM »
If memory serves me you'll always get the "." ".." if the directory location is not the root folder, but I'm assuming vl-directory-files behavior mirrors that of the DOS dir command.
« Reply #8 on: March 12, 2009, 01:07:37 AM »
(defun _test? ()
    (setq
        Folders          (if (member ".." (setq Folders (vl-directory-files bom:ParentFolder NIL -1)))
                             (cddr Folders)
                             Folders
untested but ... if the "." ".." always appear in the noted order (and always first in the list) then the above should work.
« Last Edit: March 12, 2009, 01:11:28 AM by MP »
kdub_nz
  • SuperMod
« Reply #9 on: March 12, 2009, 01:12:47 AM »
Thanks Michael,
I'm doing an animated stepthrough at the moment so I'll try that option as soon as the process is finished.
« Reply #10 on: March 12, 2009, 01:18:21 AM »
You're welcome KB. I gotta crash here pretty quick so I won't see the results 'til tomorrow, but thanks for the opportunity to pitch a few ideas.
« Reply #11 on: March 12, 2009, 04:55:29 AM »
On the old box at home .....
(defun _test01 ()
  (setq bom:ParentFolder "F:\\_Develop"
(defun _test02 ()
(defun _test03 ()
(defun _test04 ()
(defun _test05 ()
    (setq
                             (cddr Folders)
                             Folders
(defun _test06 ()
    (setq bom:ParentFolder "F:\\_Develop")
    (if (= ".." (cadr (setq Folders (vl-directory-files bom:ParentFolder NIL -1))))
        (setq Folders (cddr Folders))
Benchmarking [M.P. 2005] .............Elapsed milliseconds for 1024 iteration(s)/ relative Timing :
    (_TEST04).....500 / 1.0684 <slowest>
    (_TEST01).....484 / 1.0342
    (_TEST02).....469 / 1.0021
    (_TEST03).....469 / 1.0021
    (_TEST05).....469 / 1.0021
    (_TEST06).....468 / 1 <fastest>
« Reply #12 on: March 12, 2009, 10:08:18 AM »
:D
« Reply #13 on: March 12, 2009, 02:19:09 PM »
Kerry,
What kind of speed does this have?
(defun subfolders (path / folder fs lst subs)
  (setq fs (vlax-create-object "Scripting.FileSystemObject"))
  (if (and (setq folder (vlax-invoke fs 'getfolder path))
           (setq subs (vlax-get folder 'subfolders))
    (vlax-for sub subs (setq lst (cons (vlax-get sub 'Path) lst)))
  (vlax-release-object fs)
  (reverse lst)
(subfolders "C:\\")
Nevermind  :ugly:
    (_TEST03)........1500 / 3.47 <fastest>
    (_TEST05)........1515 / 3.43
    (_TEST02)........1516 / 3.43
    (_TEST06)........1516 / 3.43
    (_TEST01)........1578 / 3.30
    (_TEST04)........1578 / 3.30
    (SUBFOLDERS).....5203 / 1.00 <slowest>
« Last Edit: March 12, 2009, 02:50:31 PM by ronjonp »
VovKa
  • Ukraine
« Reply #14 on: March 12, 2009, 02:36:30 PM »
(defun _test07 ()
  (setq bom:ParentFolder "C:\\Program Files")
  (if (> (strlen bom:ParentFolder) 3)
    (cddr (vl-directory-files bom:ParentFolder NIL -1))
03 and 06 do not work for the root
