Author Topic: printing dwf files  (Read 6345 times)
ELOQUINTET
printing dwf files
« on: October 04, 2004, 12:47:19 PM »
who here has experience with printing dwf files? we just received a bunch of architecturals but when i try to print them all that prints out is blanks sheets about 48 x 11 after ihave specified 48 x 36. It seem like some kind of cut method error to me but i can't figure out how to solve it. I just want to print these out in a large enough size to read for bidding so how can this be easily done. i have no experience with dwf's.
M-dub
printing dwf files
« Reply #1 on: October 04, 2004, 12:57:25 PM »
I print them all the time (from DrawingSearcher) and it's a little less than perfect, but I've never had the problem you're mentioning.  Are you printing them from Acad?
ELOQUINTET
printing dwf files
« Reply #2 on: October 04, 2004, 01:04:18 PM »
no trying to use dwf viewer how do you view and print dwf's from searcher mdub?
hendie
printing dwf files
« Reply #3 on: October 04, 2004, 01:08:20 PM »
depending upon the viewer you have... don't use the "Print" from the menu.
You have to right-click on the dwf and use the "Print" option from there.
I think the problem has been fixed on later viewers
M-dub
printing dwf files
« Reply #4 on: October 04, 2004, 01:08:26 PM »
Well, the drawing pops up in DWF Viewer, but that's where they are generated from.
Did you try 'Force All Geometry to Black'?
Do you have the latest version?  I believe Autodesk just released an update.
M-dub
printing dwf files
« Reply #5 on: October 04, 2004, 01:09:35 PM »
Quote from: hendie
Oh yeah, forgot that part....Good Tip, Hendie
ELOQUINTET
printing dwf files
« Reply #6 on: October 04, 2004, 01:11:16 PM »
i was thinking it could be an internal thing like a driver issue or something. i'm using the latest viewer #5 and just tried your method but nothing is printing out  :?
M-dub
printing dwf files
« Reply #7 on: October 04, 2004, 01:12:02 PM »
You don't have to, but could you send me one of the files by any chance?
ELOQUINTET
printing dwf files
« Reply #8 on: October 04, 2004, 01:14:18 PM »
they are trying to tell me here to insert each one into autocad then scale them up and i have about 50 of them. i'm thinkin it will be fasterfor now and in the long run  to learn the proper way, correct  :wink:
ELOQUINTET
printing dwf files
« Reply #9 on: October 04, 2004, 01:15:14 PM »
sure mdub it's on the way
M-dub
printing dwf files
« Reply #10 on: October 04, 2004, 01:16:01 PM »
If you can get one to print properly in Acad, try the Batchplot utility...
ELOQUINTET
printing dwf files
« Reply #11 on: October 04, 2004, 01:20:31 PM »
it's the cutting and pasting and scaling up that i'd like to avoid. i tried doing one using this method and it took forever. there's also an issue of our plotter being 36" wide so i'd have to rotate the ole. the lineweights on the one i printed also came out real screwy in acad. basically i'd rather not do it that way.
hendie
printing dwf files
« Reply #12 on: October 04, 2004, 01:25:00 PM »
can you actually see the DWF correctly in the viewer ?
M-dub
printing dwf files
« Reply #13 on: October 04, 2004, 01:26:00 PM »
Well, I don't know...I had no problems plotting it out in DWF Viewer.
Can you post a screenshot of your 'print' dialog box?
ELOQUINTET
printing dwf files
« Reply #14 on: October 04, 2004, 01:26:31 PM »
yeah it looks fine i was just seeing that. they are using a bold font for all text which views ok in the viewer but in acad it's big blobs
